So I have written a program to control 6 AX-12A servos chained together with 6 potentiometers. The servos are powered by a lab power supply at 10 volts. I have connected the data wire of the servos to serial port 3 on the mega (pins 14, 15) and the program switches between transmitting and receiving to interface with the AX12A’s half duplex UART. The program works just fine for 3 servos but as I start to go past 3 everything becomes choppy and delayed. I’m not quite sure what the problem is. Any idea for a possible solution? The code is listed below:
/* This Code is used with an Arduino Mega to communicate with Dynamixel
with Dynamixel AX-12A Servo Motor. All commands use Serial 3 to write
to servo and Serial to write to pc for purpose of recieving status packets
// instruction table for Dynamixel AX-12A
#define ping_ins 1 // checked
#define read_ins 2 // checked
#define write_ins 3 // Checked
#define reg_write_ins 4 // Checked
#define action_ins 5 // Checked
#define reset_ins 6 // Checked
#define sync_write_ins 131
//registers table for Dynamixel AX-12A
#define servo_id 3
#define baud_rate 4
#define max_torque 14
#define alarm_led 17
#define alarm_shutdown 18
#define torque_enable 24
#define goal_position 30
#define moving_speed 32
// Code Begins...
int length,location,temp,checksum,N,L; // used for status packet & return packet
int old_val = 0;
int old_val2 = 0;
int old_val3 = 0;
int old_val4 = 0;
int old_val5 = 0;
int old_val6 = 0;
int present_val = 0;
int present_val2 = 0;
int present_val3 = 0;
int present_val4 = 0;
int present_val5 = 0;
int present_val6 = 0;
int id;
int analogPin = A0; // 5 Potenimeters. each 1 controls 1 motor
int analogPin2 = A1;
int analogPin3 = A2;
int analogPin4 = A3;
int analogPin5 = A4;
int analogPin6 = A5;
int value;
Serial3.begin(1000000); // Servo Communication Speed
Serial.begin(9600); // Communication speed Arduino/PC
location = goal_position;
present_val = analogRead(analogPin); // read value of A0
present_val2 = analogRead(analogPin2);
present_val3 = analogRead(analogPin3);
present_val4 = analogRead(analogPin4);
present_val5 = analogRead(analogPin5);
present_val6 = analogRead(analogPin6);
if ((present_val != old_val)||(present_val2 != old_val2)||
(present_val3 != old_val3)||(present_val4 != old_val4)||
(present_val5 != old_val5)||(present_val6 != old_val6)) //
old_val = present_val; // old_val to present_val
old_val2 = present_val2;
old_val3 = present_val3;
old_val4 = present_val4;
old_val5 = present_val5;
old_val6 = present_val6;
transmit(); //enable trasmission
// Reg_Write Instructions
reg_write_2_byte(1,location,old_val);// put location value into buffer
reg_write_2_byte(2,location,old_val2);
reg_write_2_byte(3,location,old_val3);
reg_write_2_byte(4,location,old_val4);
reg_write_2_byte(5,location,old_val5);
reg_write_2_byte(6,location,old_val6);
Action(0xFE); //execute buffer
recieve(); //enable recieving
void transmit()
bitSet(UCSR3B,3); // Sets Tx pin
bitClear(UCSR3B,4); // Clear Rx pin
bitClear(UCSR3B,7); // Disable Rx Interrupt
void recieve()
bitClear(UCSR3B,3); // Clear Tx pin
bitSet(UCSR3B,4); // Set Rx Pin
bitSet(UCSR3B,7); // Allows Rx Interrupt
//Recieve Interrupt Subroutine
void serialEvent3()
temp =Serial3.read();
Serial.print(temp,HEX); // prints incoming return packet bit
Function to reg_write to a 2 byte register
location = what register to write to
val = what value to write to register
void reg_write_2_byte(int id, int location,int val)
length = 5; // length of 2-byte instruction is 5
checksum = ~((id + length + reg_write_ins + location + (val&0xFF) + ((val&0xFF00) >> 8))%256); //Checksum Value
Serial3.write(0xFF); // Starts instruction packet
Serial3.write(id);
Serial3.write(length);
Serial3.write(reg_write_ins);
Serial3.write(location);
Serial3.write(val&0xFF); // Lower Byte
Serial3.write((val&0xFF00) >> 8); // Upper Byte
Serial3.write(checksum);
Action Function to perform Reg_Write Functions
void Action(int id)
length = 2;
checksum = ~((id + length + action_ins)%256);
Serial3.write(id); // Broadcast(0xFE) is used when sending action to two Dynamixels
Serial3.write(action_ins);
