Mega and I2C display
I'm trying to connect my brand new Arduino Mega to a MatrixOrbital display via i2c. The display is connected to pins 20/21 on the arduino and I use no (extra) pullups. The display is not powered from the arduino board, but the grounds are connected.
int main(int argc, char** argv) {
      init();
      Wire.begin();
      Wire.beginTransmission(0x5c);
      Wire.send('a');
      Wire.endTransmission();
      for(;;) {
This should print an 'a' on the display, but nothing happens. Any ideas? This is my first arduino project...
PS The manual for the display is here; I’d appreciate if you took a look to see if I missed anything obvious. http://www.matrixorbital.ca/manuals/LCDVFD_series/VFD2041/VFD2041_110.pdf
The wire library expects a 7-bit address (the rightmost bit is managed by the library) whereas the documentation you referenced list 8-bit addresses. To properly address your display you need to change your code as follows:
                Wire.beginTransmission(0x5c >> 1);
      Wire.send('a');
You may also want to change the structure of your application to match the Arduino convention (no main) as follows:
      Wire.begin();
      Wire.send('a');
The internal pullups are only about 30K, while you can get it to work most of the time the waveforms look awful. You need 4K7 pullups on both lines.
