Mega and SD Library - Error
I am trying to move my Uno project to a Mega since I ran out of programming space on the Uno.
I am not able to include the SD library without the following error and I am not sure what exactly it means:
Errors:
In file included from C:\Program Files (x86)\Arduino\libraries\SD/utility/Sd2Card.h:26:0,
                 from C:\Program Files (x86)\Arduino\libraries\SD/utility/SdFat.h:29,
                 from C:\Program Files (x86)\Arduino\libraries\SD/SD.h:25,
                 from PEDv1.2.ino:6:
C:\Program Files (x86)\Arduino\libraries\SD/utility/Sd2PinMap.h:126:12: error: 'PINK' was not declared in this scope
   {&DDRK, &PINK, &PORTK, 0},  // K0 62
C:\Program Files (x86)\Arduino\libraries\SD/utility/Sd2PinMap.h:127:12: error: 'PINK' was not declared in this scope
   {&DDRK, &PINK, &PORTK, 1},  // K1 63
C:\Program Files (x86)\Arduino\libraries\SD/utility/Sd2PinMap.h:128:12: error: 'PINK' was not declared in this scope
   {&DDRK, &PINK, &PORTK, 2},  // K2 64
C:\Program Files (x86)\Arduino\libraries\SD/utility/Sd2PinMap.h:129:12: error: 'PINK' was not declared in this scope
   {&DDRK, &PINK, &PORTK, 3},  // K3 65
C:\Program Files (x86)\Arduino\libraries\SD/utility/Sd2PinMap.h:130:12: error: 'PINK' was not declared in this scope
   {&DDRK, &PINK, &PORTK, 4},  // K4 66
C:\Program Files (x86)\Arduino\libraries\SD/utility/Sd2PinMap.h:131:12: error: 'PINK' was not declared in this scope
   {&DDRK, &PINK, &PORTK, 5},  // K5 67
C:\Program Files (x86)\Arduino\libraries\SD/utility/Sd2PinMap.h:132:12: error: 'PINK' was not declared in this scope
   {&DDRK, &PINK, &PORTK, 6},  // K6 68
C:\Program Files (x86)\Arduino\libraries\SD/utility/Sd2PinMap.h:133:12: error: 'PINK' was not declared in this scope
   {&DDRK, &PINK, &PORTK, 7}   // K7 69
Error compiling.
The respective header file part:
#if defined(__AVR_ATmega1280__) || defined(__AVR_ATmega2560__)
// Mega
// Two Wire (aka I2C) ports
uint8_t const SDA_PIN = 20;
uint8_t const SCL_PIN = 21;
// SPI port
uint8_t const SS_PIN = 53;
uint8_t const MOSI_PIN = 51;
uint8_t const MISO_PIN = 50;
uint8_t const SCK_PIN = 52;
static const pin_map_t digitalPinMap[] = {
  {&DDRE, &PINE, &PORTE, 0},  // E0  0
  {&DDRE, &PINE, &PORTE, 1},  // E1  1
  {&DDRE, &PINE, &PORTE, 4},  // E4  2
  {&DDRE, &PINE, &PORTE, 5},  // E5  3
  {&DDRG, &PING, &PORTG, 5},  // G5  4
  {&DDRE, &PINE, &PORTE, 3},  // E3  5
  {&DDRH, &PINH, &PORTH, 3},  // H3  6
  {&DDRH, &PINH, &PORTH, 4},  // H4  7
  {&DDRH, &PINH, &PORTH, 5},  // H5  8
  {&DDRH, &PINH, &PORTH, 6},  // H6  9
  {&DDRB, &PINB, &PORTB, 4},  // B4 10
  {&DDRB, &PINB, &PORTB, 5},  // B5 11
  {&DDRB, &PINB, &PORTB, 6},  // B6 12
  {&DDRB, &PINB, &PORTB, 7},  // B7 13
  {&DDRJ, &PINJ, &PORTJ, 1},  // J1 14
  {&DDRJ, &PINJ, &PORTJ, 0},  // J0 15
  {&DDRH, &PINH, &PORTH, 1},  // H1 16
  {&DDRH, &PINH, &PORTH, 0},  // H0 17
  {&DDRD, &PIND, &PORTD, 3},  // D3 18
  {&DDRD, &PIND, &PORTD, 2},  // D2 19
  {&DDRD, &PIND, &PORTD, 1},  // D1 20
  {&DDRD, &PIND, &PORTD, 0},  // D0 21
  {&DDRA, &PINA, &PORTA, 0},  // A0 22
  {&DDRA, &PINA, &PORTA, 1},  // A1 23
  {&DDRA, &PINA, &PORTA, 2},  // A2 24
  {&DDRA, &PINA, &PORTA, 3},  // A3 25
  {&DDRA, &PINA, &PORTA, 4},  // A4 26
  {&DDRA, &PINA, &PORTA, 5},  // A5 27
  {&DDRA, &PINA, &PORTA, 6},  // A6 28
  {&DDRA, &PINA, &PORTA, 7},  // A7 29
  {&DDRC, &PINC, &PORTC, 7},  // C7 30
  {&DDRC, &PINC, &PORTC, 6},  // C6 31
  {&DDRC, &PINC, &PORTC, 5},  // C5 32
  {&DDRC, &PINC, &PORTC, 4},  // C4 33
  {&DDRC, &PINC, &PORTC, 3},  // C3 34
  {&DDRC, &PINC, &PORTC, 2},  // C2 35
  {&DDRC, &PINC, &PORTC, 1},  // C1 36
  {&DDRC, &PINC, &PORTC, 0},  // C0 37
  {&DDRD, &PIND, &PORTD, 7},  // D7 38
  {&DDRG, &PING, &PORTG, 2},  // G2 39
  {&DDRG, &PING, &PORTG, 1},  // G1 40
  {&DDRG, &PING, &PORTG, 0},  // G0 41
  {&DDRL, &PINL, &PORTL, 7},  // L7 42
  {&DDRL, &PINL, &PORTL, 6},  // L6 43
  {&DDRL, &PINL, &PORTL, 5},  // L5 44
  {&DDRL, &PINL, &PORTL, 4},  // L4 45
  {&DDRL, &PINL, &PORTL, 3},  // L3 46
  {&DDRL, &PINL, &PORTL, 2},  // L2 47
  {&DDRL, &PINL, &PORTL, 1},  // L1 48
  {&DDRL, &PINL, &PORTL, 0},  // L0 49
  {&DDRB, &PINB, &PORTB, 3},  // B3 50
  {&DDRB, &PINB, &PORTB, 2},  // B2 51
  {&DDRB, &PINB, &PORTB, 1},  // B1 52
  {&DDRB, &PINB, &PORTB, 0},  // B0 53
  {&DDRF, &PINF, &PORTF, 0},  // F0 54
  {&DDRF, &PINF, &PORTF, 1},  // F1 55
  {&DDRF, &PINF, &PORTF, 2},  // F2 56
  {&DDRF, &PINF, &PORTF, 3},  // F3 57
  {&DDRF, &PINF, &PORTF, 4},  // F4 58
  {&DDRF, &PINF, &PORTF, 5},  // F5 59
  {&DDRF, &PINF, &PORTF, 6},  // F6 60
  {&DDRF, &PINF, &PORTF, 7},  // F7 61
Does anyone have any ideas? This is a crappy knock-off board if that changes anything, thanks!
strange - I use the SD library with an Ethernet shield on a Mega without problems
I assume you have selected under Tools > Arduino/Genuino Mega or Mega 2560
try downloading the CardInfo program from
and see if that builds and runs
horace:
SD - Arduino Reference
I commented out the "PINK" lines in the header file and for my purposes the library is working how I need it to.
Not sure what problems could occur from commenting out those lines but so far so good.
