Hey all,
So I am creating a project for school that has to take in temperature, humidity and 6 DOF sensor data. I am planning on using a Mega 2560 and using an integrated shield that has a RTC and an SD module already on it. The temperature and humidity data has to polled at 5Hz and written to the SD card, and the Accelerarion portion of the 6-DOF sensor has to sample at 4Khz. This needs to be written to the SD Card also. I am planning on using the AM2315 temperature and humidity sensor which is a digital sensor and plan on using the MPU-9250 analog sensor to collect the acceleration and gyro data. I am not sure the SD card could possibly write this data this fast and output the data with specific times from the RTC. Do you think the Mega is a good platform for this and could this data be collected and written to the SD card? If it can’t write this fast what should I try to do? I know you can store the data in the RAM and dump every so often but not entirely sure how to go about this? I want to ideally collect the data and write it without losing the ability to sample at the same time. Sorry if this is kind of all over the place, I am pretty new to arduinos and just started my first Arduino class in school. Thanks.
