Hello - I've written some code on the Teensy and converted it to work on the Mega. I need two outputs for my Midi data - USB and Serial. Both work great on the Teensy. On the Mega the serial works just great, however the USB doesn't seem to be doing anything.
I know the code is sloppy at best (I'm new at this), but it works. However, do I need to use different commands to send Midi to the USB port? Any suggestions would be great. Here's my code:
#include <Bounce2.h>
#include <MIDI.h>
#include <Wire.h>
MIDI_CREATE_DEFAULT_INSTANCE();
const int NUM_OF_BUTTONS = 12;
const int MIDI_CHAN = 1;
const int DEBOUNCE_TIME = 40;
Bounce buttons[NUM_OF_BUTTONS + 1] =
Bounce(),
Bounce(),
Bounce(),
Bounce(),
Bounce(),
Bounce(),
Bounce(),
Bounce(),
Bounce(),
Bounce(),
Bounce(),
Bounce(),
const int MIDI_MODE_NOTES = 0;
const int MIDI_MODE_CCS = 1;
int midiMode = MIDI_MODE_NOTES;
const int MIDI_NOTE_NUMS[NUM_OF_BUTTONS] = {89, 90, 91, 92, 93, 94, 95, 96, 1, 3, 5, 7};
const int MIDI_NOTE_VELS[NUM_OF_BUTTONS] = {110, 110, 110, 110, 110, 110, 110, 110, 110, 110, 110, 110};
const int MIDI_CC_NUMS[NUM_OF_BUTTONS] = {89, 90, 91, 92, 93, 94, 95, 96, 1, 3, 5, 7};
const int MIDI_CC_VALS[NUM_OF_BUTTONS] = {127, 127, 127, 127, 127, 127, 127, 127, 127, 127, 127, 127};
bool running = false;
bool toggle_state[NUM_OF_BUTTONS] = {false, false, false, false, false, false, false, false, false, false, false, false};
bool pc_sent[NUM_OF_BUTTONS] = {false, false, false, false, false, false, false, false, false, false, false, false};
LiquidCrystal_I2C lcd(0x27, 20, 4);
lcd.init();
Wire.begin();
lcd.backlight();
Serial.begin(9600); // Initialize the Serial monitor
MIDI.begin(MIDI_CHANNEL_OMNI); // Initialize MIDI
for (int i = 0; i < NUM_OF_BUTTONS + 1; i++)
pinMode(i, INPUT_PULLUP);
buttons[i].attach(i);
buttons[i].interval(DEBOUNCE_TIME);
lcd.begin(20, 4);
lcd.print("CC and PC Buttons");
Serial3.begin(31250);
for (int i = 0; i < NUM_OF_BUTTONS; i++)
buttons[i].update();
if (buttons[i].fell())
lcd.clear();
lcd.setCursor(0, 0);
lcd.print("Button: ");
lcd.print(i + 1);
lcd.print(" pressed");
if (i == 8 || i == 9 || i == 10 || i == 11) // Buttons 9, 10, 11, 12
if (!pc_sent[i])
pc_sent[i] = true;
sendProgramChange(MIDI_NOTE_NUMS[i], i);
Serial3.write(0x90 | (MIDI_CHAN - 1));
Serial3.write(MIDI_NOTE_NUMS[i]);
Serial3.write(0xB0 | (MIDI_CHAN - 1));
Serial3.write(MIDI_CC_NUMS[i]);
lcd.clear();
lcd.setCursor(1, 0);
lcd.print("PC ");
lcd.print(i + 1);
lcd.print(" Value ");
lcd.print (MIDI_NOTE_NUMS[i]);
else // Buttons 1, 2, 3, 4 ,5, 6, 7, 8
toggle_state[i] = !toggle_state[i];
if (toggle_state[i])
lcd.clear();
lcd.setCursor(0, 1);
lcd.print("CC Btn");
lcd.print(i + 1);
lcd.print(" ");
lcd.print(" Value On");
lcd.print(MIDI_NOTE_NUMS[i]);
// Send MIDI message through USB
MIDI.sendNoteOn(MIDI_NOTE_NUMS[i], MIDI_NOTE_VELS[i], MIDI_CHAN);
MIDI.sendControlChange(MIDI_CC_NUMS[i], MIDI_CC_VALS[i], MIDI_CHAN);
// Send MIDI message through Serial port
Serial3.write(MIDI_NOTE_VELS[i]);
Serial3.write(MIDI_CC_VALS[i]);
lcd.clear();
lcd.setCursor(0, 2);
lcd.print(i + 1);
lcd.print(" ");
lcd.print(" Value Off");
MIDI.sendNoteOff(MIDI_NOTE_NUMS[i], MIDI_NOTE_VELS[i], MIDI_CHAN);
MIDI.sendControlChange(MIDI_CC_NUMS[i], 0, MIDI_CHAN);
Serial3.write(0x80 | (MIDI_CHAN - 1));
Serial3.write(0);
else if (buttons[i].rose())
if (i == 0 || i == 1 || i == 2 || i == 3 || i == 4 || i == 5 || i == 6 || i == 7 || i == 8 || i == 9 || i == 10 || i == 11) // Buttons 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12
pc_sent[i] = false;
void sendProgramChange(int pc, int i)
lcd.setCursor(3, 0);
lcd.print("PC ");
lcd.print(i + 1);
MIDI.sendProgramChange(pc, MIDI_CHAN);
Serial3.write(0xC0 | (MIDI_CHAN - 1));
Serial3.write(pc);
