Well I used to be able to, but not anymore (randomly). The IDE recognizes it as Mega, and even gives me a port wihch displays it (COM5), but it won't upload. I went to file >> preferences, and turned on "show verbose output during >> compilation and upload.
Here is what I saw when trying to upload (I had to trim some because it wouldn't all fit)
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\gmeyerho\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\gmeyerho\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\gmeyerho\Documents\Arduino\libraries -fqbn=arduino:avr:mega:cpu=atmega2560 -vid-pid=0X2341_0X0042 -ide-version=10803 -build-path C:\Users\gmeyerho\AppData\Local\Temp\arduino_build_662857 -warnings=none -build-cache C:\Users\gmeyerho\AppData\Local\Temp\arduino_cache_229454 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Users\gmeyerho\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9 -prefs=runtime.tools.arduinoOTA.path=C:\Users\gmeyerho\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.1.1 -prefs=runtime.tools.avr-gcc.path=C:\Users\gmeyerho\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2 -verbose C:\Users\gmeyerho\Documents\Arduino\Encoders\Encoders.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\gmeyerho\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\gmeyerho\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\gmeyerho\Documents\Arduino\libraries -fqbn=arduino:avr:mega:cpu=atmega2560 -vid-pid=0X2341_0X0042 -ide-version=10803 -build-path C:\Users\gmeyerho\AppData\Local\Temp\arduino_build_662857 -warnings=none -build-cache C:\Users\gmeyerho\AppData\Local\Temp\arduino_cache_229454 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Users\gmeyerho\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9 -prefs=runtime.tools.arduinoOTA.path=C:\Users\gmeyerho\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.1.1 -prefs=runtime.tools.avr-gcc.path=C:\Users\gmeyerho\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2 -verbose C:\Users\gmeyerho\Documents\Arduino\Encoders\Encoders.ino
Using board 'mega' from platform in folder: C:\Users\gmeyerho\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.20
Using core 'arduino' from platform in folder: C:\Users\gmeyerho\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.20
Detecting libraries used...
"C:\Users\gmeyerho\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Users\gmeyerho\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.20\cores\arduino" "-IC:\Users\gmeyerho\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.20\variants\mega" "C:\Users\gmeyerho\AppData\Local\Temp\arduino_build_662857\sketch\Encoders.ino.cpp" -o "nul"
Generating function prototypes...
"C:\Users\gmeyerho\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Users\gmeyerho\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.20\cores\arduino" "-IC:\Users\gmeyerho\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.20\variants\mega" "C:\Users\gmeyerho\AppData\Local\Temp\arduino_build_662857\sketch\Encoders.ino.cpp" -o "C:\Users\gmeyerho\AppData\Local\Temp\arduino_build_662857\preproc\ctags_target_for_gcc_minus_e.cpp"
"C:\Program Files (x86)\Arduino\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\gmeyerho\AppData\Local\Temp\arduino_build_662857\preproc\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\Users\gmeyerho\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Users\gmeyerho\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.20\cores\arduino" "-IC:\Users\gmeyerho\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.20\variants\mega" "C:\Users\gmeyerho\AppData\Local\Temp\arduino_build_662857\sketch\Encoders.ino.cpp" -o "C:\Users\gmeyerho\AppData\Local\Temp\arduino_build_662857\sketch\Encoders.ino.cpp.o"
Compiling libraries...
Compiling core...
"C:\Users\gmeyerho\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-gcc" -c -g -x assembler-with-cpp -flto -MMD -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Users\gmeyerho\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.20\cores\arduino" "-IC:\Users\gmeyerho\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.20\variants\mega" "C:\Users\gmeyerho\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.20\cores\arduino\wiring_pulse.S" -o "C:\Users\gmeyerho\AppData\Local\Temp\arduino_build_662857\core\wiring_pulse.S.o"
"C:\Users\gmeyerho\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Users\gmeyerho\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.20\cores\arduino" "-IC:\Users\gmeyerho\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.20\variants\mega" "C:\Users\gmeyerho\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.20\cores\arduino\WInterrupts.c" -o "C:\Users\gmeyerho\AppData\Local\Temp\arduino_build_662857\core\WInterrupts.c.o"
avrdude: error reading system wide configuration file "C:\Users\gmeyerho\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9/etc/avrdude.conf"
Any ideas what is going on?
