HI EVERY BODY I HAVE
MEGA BOARD AND I TRY TO USE WITH LM35 TEMPERATURE BUT ANALOG PINS RETURN 1023
I TRY MY CODE WITH UNO AND WORK GOOD BUT WITH MEGA NOT WORKING
I MAKE STIMULATION IN PROTEUS AND SAME PROBLEM
THANKS
Mahmoud_Bakry:
THANKS
Stop SHOUTING !
We can read just fine without the all caps.
:o Just You Can Say I don't Know
Please post your Mega code and tell us how the LM35 is connected.
HowToPostCode
edgemoron:
HowToPostCode
this is my code and connected method with lm35 this work fine with uno but in mega cant read any analog pin
thanks
Please see reply #3
AWOL:
Please see reply #3
OK sorry i am new one.
//initializes/defines the output pin of the LM35 temperature sensor
int senpen= 0;
//this sets the ground pin to LOW and the input voltage pin to high
//main loop
int rawvoltage= analogRead(senpen);
float millivolts= (rawvoltage/1024.0) * 5000;
float celsius= millivolts/10;
Serial.print(celsius);
Serial.print(" degrees Celsius, ");
Serial.print((celsius * 9)/5 + 32);
Serial.println(" degrees Fahrenheit");
Make sure your LM35 is connected correctly, if you previously connected it backwards, you may have killed it.
http://www.ti.com/lit/ds/symlink/lm35.pdf Page 5.
edgemoron:
thanks
sorry my English so bad
i think i have bad sensor
