Mega Display bleibt weiß - Sketch überprüfen?
Heute wars soweit. Mein Display + Shield ist endlich angekommen. Hab das ganze angesteckt und wollte den Beispielsketch UTouch Button Test ausprobieren:
// UTouch_ButtonTest
// Copyright (C)2015 Rinky-Dink Electronics, Henning Karlsen. All right reserved
// web: http://www.RinkyDinkElectronics.com/
// This program is a quick demo of how create and use buttons.
// This program requires the UTFT library.
// It is assumed that the display module is connected to an
// appropriate shield or that you know how to change the pin
// numbers in the setup.
#include <UTFT.h>
#include <UTouch.h>
// Initialize display
// Set the pins to the correct ones for your development board
// Standard Arduino Uno/2009 Shield            : <display model>,19,18,17,16
// Standard Arduino Mega/Due shield            : <display model>,38,39,40,41
// CTE TFT LCD/SD Shield for Arduino Due       : <display model>,25,26,27,28
// Teensy 3.x TFT Test Board                   : <display model>,23,22, 3, 4
// ElecHouse TFT LCD/SD Shield for Arduino Due : <display model>,22,23,31,33
// Remember to change the model parameter to suit your display module!
UTFT    myGLCD(ITDB32S,38,39,40,41);
// Initialize touchscreen
// Standard Arduino Uno/2009 Shield            : 15,10,14, 9, 8
// Standard Arduino Mega/Due shield            :  6, 5, 4, 3, 2
// CTE TFT LCD/SD Shield for Arduino Due       :  6, 5, 4, 3, 2
// Teensy 3.x TFT Test Board                   : 26,31,27,28,29
// ElecHouse TFT LCD/SD Shield for Arduino Due : 25,26,27,29,30
UTouch  myTouch( 6, 5, 4, 3, 2);
// Declare which fonts we will be using
extern uint8_t BigFont[];
int x, y;
char stCurrent[20]="";
int stCurrentLen=0;
char stLast[20]="";
**   Custom functions   **
void drawButtons()
// Draw the upper row of buttons
  for (x=0; x<5; x++)
    myGLCD.setColor(0, 0, 255);
    myGLCD.fillRoundRect (10+(x*60), 10, 60+(x*60), 60);
    myGLCD.setColor(255, 255, 255);
    myGLCD.drawRoundRect (10+(x*60), 10, 60+(x*60), 60);
    myGLCD.printNumI(x+1, 27+(x*60), 27);
// Draw the center row of buttons
  for (x=0; x<5; x++)
    myGLCD.fillRoundRect (10+(x*60), 70, 60+(x*60), 120);
    myGLCD.drawRoundRect (10+(x*60), 70, 60+(x*60), 120);
    if (x<4)
      myGLCD.printNumI(x+6, 27+(x*60), 87);
  myGLCD.print("0", 267, 87);
// Draw the lower row of buttons
  myGLCD.fillRoundRect (10, 130, 150, 180);
  myGLCD.drawRoundRect (10, 130, 150, 180);
  myGLCD.print("Clear", 40, 147);
  myGLCD.fillRoundRect (160, 130, 300, 180);
  myGLCD.drawRoundRect (160, 130, 300, 180);
  myGLCD.print("Enter", 190, 147);
  myGLCD.setBackColor (0, 0, 0);
void updateStr(int val)
  if (stCurrentLen<20)
    stCurrent[stCurrentLen]=val;
    stCurrent[stCurrentLen+1]='\0';
    stCurrentLen++;
    myGLCD.setColor(0, 255, 0);
    myGLCD.print(stCurrent, LEFT, 224);
    myGLCD.setColor(255, 0, 0);
    myGLCD.print("BUFFER FULL!", CENTER, 192);
    myGLCD.print("            ", CENTER, 192);
// Draw a red frame while a button is touched
void waitForIt(int x1, int y1, int x2, int y2)
  myGLCD.drawRoundRect (x1, y1, x2, y2);
  while (myTouch.dataAvailable())
    myTouch.read();
**  Required functions  **
// Initial setup
  myGLCD.InitLCD();
  myGLCD.clrScr();
  myTouch.InitTouch();
  myTouch.setPrecision(PREC_MEDIUM);
  myGLCD.setFont(BigFont);
  myGLCD.setBackColor(0, 0, 255);
  drawButtons();
  while (true)
    if (myTouch.dataAvailable())
      myTouch.read();
      x=myTouch.getX();
      y=myTouch.getY();
      if ((y>=10) && (y<=60))  // Upper row
        if ((x>=10) && (x<=60))  // Button: 1
          waitForIt(10, 10, 60, 60);
          updateStr('1');
        if ((x>=70) && (x<=120))  // Button: 2
          waitForIt(70, 10, 120, 60);
          updateStr('2');
        if ((x>=130) && (x<=180))  // Button: 3
          waitForIt(130, 10, 180, 60);
          updateStr('3');
        if ((x>=190) && (x<=240))  // Button: 4
          waitForIt(190, 10, 240, 60);
          updateStr('4');
        if ((x>=250) && (x<=300))  // Button: 5
          waitForIt(250, 10, 300, 60);
          updateStr('5');
      if ((y>=70) && (y<=120))  // Center row
        if ((x>=10) && (x<=60))  // Button: 6
          waitForIt(10, 70, 60, 120);
          updateStr('6');
        if ((x>=70) && (x<=120))  // Button: 7
          waitForIt(70, 70, 120, 120);
          updateStr('7');
        if ((x>=130) && (x<=180))  // Button: 8
          waitForIt(130, 70, 180, 120);
          updateStr('8');
        if ((x>=190) && (x<=240))  // Button: 9
          waitForIt(190, 70, 240, 120);
          updateStr('9');
        if ((x>=250) && (x<=300))  // Button: 0
          waitForIt(250, 70, 300, 120);
          updateStr('0');
      if ((y>=130) && (y<=180))  // Upper row
        if ((x>=10) && (x<=150))  // Button: Clear
          waitForIt(10, 130, 150, 180);
          stCurrent[0]='\0';
          stCurrentLen=0;
          myGLCD.setColor(0, 0, 0);
          myGLCD.fillRect(0, 224, 319, 239);
        if ((x>=160) && (x<=300))  // Button: Enter
          waitForIt(160, 130, 300, 180);
          if (stCurrentLen>0)
            for (x=0; x<stCurrentLen+1; x++)
              stLast[x]=stCurrent[x];
            stCurrent[0]='\0';
            stCurrentLen=0;
            myGLCD.fillRect(0, 208, 319, 239);
            myGLCD.print(stLast, LEFT, 208);
            myGLCD.print("BUFFER EMPTY", CENTER, 192);
Nun hab ich schon etwas gegoogelt… den Hinweis “deprecated Version” kann man erstmal missachten, wenn dieser nach dem kompilieren erscheint. Also sollte ja soweit eigentlich alles funktionieren. Einen wirklichen Error habe ich nämlich nicht.
Mein Problem ist, dass der Aptotec 3.2" Display absolut weiß bleibt. Egal welchen Sketch ich versuche. Die Pins im Sketch müssten ja stimmen. Kanns sein, dass mein Programmer falsch eingestellt ist für ein Mega2560? Benutze den AVRISP mkII.
Welches Display hast Du? Bitte Link Grüße Uwe
http://www.amazon.de/Aptotec-3-2-TFT-Touchdisplay-Arduino-Schwarz/dp/B00YQ08U70
Mit dem dazugehörenden Display Shield von Aptotec:
http://www.amazon.de/Apto-TFT-Shield-Arduino-Mega2560-Blau/dp/B00Y0XV1KG/ref=pd_bxgy_23_2?ie=UTF8&refRID=153MY835MRQ9C95ND82F
Was mir grade noch eingefallen ist: Ich wußte bisher nicht, was ich mit dem SD Slot anfangen soll im LCD. Kann es sein, dass dort ein Treiber oder die UTFT.h Datei auf einer SD gespeichert, reingesteckt werden soll?
Im Zusammenhang mit dem TFT kann man darauf Bilder speichern (was bei UTFT aber nur mit extra Libraries unterstützt wird). Aber man kann den Slot auch unabhängig davon nutzen, z.B. als Daten-Logger der für Konfigurationsdateien.
