MEGA + enc28j60 ... so nearly there
I've been playing with the MEGA & the ethernet sheild from Seeedstudio ...
I know this uses a different chip than the official board, but I used the instructions on this forum to hack the offical board to reasonable effect. Doing the original four pin hack (and changing the pin numbers in enc28j60.c) I went from no initialization to completion on that front, but still not joy from the examples...
enc28j60.c changes:
#define ENC28J60_CONTROL_CS   53 //10
#define SPI_MOSI                           51 //11
#define SPI_MISO                           50 //12
#define SPI_SCK                              52 //13
Changing the ping setup method to:
void setup(){
 Serial.println("Debug: /*initialize enc28j60*/");
  es.ES_enc28j60Init(mymac);
  es.ES_enc28j60clkout(2); // change clkout from 6.25MHz to 12.5MHz
  delay(10);
 Serial.println("Debug: /* Magjack leds configuration, see enc28j60 datasheet, page 11 */");
  // LEDA=green LEDB=yellow
  // 0x880 is PHLCON LEDB=on, LEDA=on
  // enc28j60PhyWrite(PHLCON,0b0000 1000 1000 00 00);
  es.ES_enc28j60PhyWrite(PHLCON,0x880);
 Serial.println("Debug: 0x990 is PHLCON LEDB=off, LEDA=off");
  // 0x990 is PHLCON LEDB=off, LEDA=off
  // enc28j60PhyWrite(PHLCON,0b0000 1001 1001 00 00);
  es.ES_enc28j60PhyWrite(PHLCON,0x990);
 Serial.println("Debug: 0x880 is PHLCON LEDB=on, LEDA=on");
 Serial.println("Debug: 0x476 is PHLCON LEDA=links status, LEDB=receive/transmit");
  // 0x476 is PHLCON LEDA=links status, LEDB=receive/transmit
  // enc28j60PhyWrite(PHLCON,0b0000 0100 0111 01 10);
  es.ES_enc28j60PhyWrite(PHLCON,0x476);
  delay(100);
 Serial.println("Debug: init the ethernet/ip layer:");
  //init the ethernet/ip layer:
  es.ES_init_ip_arp_udp_tcp(mymac,myip,80);
 Serial.println("Debug: setup done.");
Gives me the following output:
Debug: setup done.
Beforehand (before changing the pins or the c file) the code would freeze on the first piece of initialisation:
So.... I try and ping, and it times out. I have set my PC to different combinations of subnet for the same IP address to try and 'find' the correct subnet, but I have failed... I've used the other examples and these all fail...
I have the following questions for you clever people:
  • How do I specify the subnet with this library?
  • How do I determine the subnet it is set to?
  • Is it possible I've blown up the chip on the board when I connected with all pins assuming it was compatible with the MEGA?
  • Does anyone have any bright ideas?
Cheers,
Darren
Hi Darren,
Where have you specified the IP address and associated subnet? Have you attempted connecting FROM the arduino to see if the link is up and working?
-Miles [From SeeedStudio]
