mega + ethernet/sd shield + rfm12 possible ?
Hello,
I want to use the latest official arduino edthernet/sd shield together with the rfm12 tranceiver on the same mega2560.
All the parts seperated works (I tested the sd read/write), the rf transceiver...
But when I connect them together the sd card init fail (suppose due to multiple spi devices on the same bus).
Does anyone know a solution for this problem ?
Thanks in advance, Jeroen
Hello,
it works. So I can confirm it works, but I was mislaid. I noticed that sometimes after uploading a changed sketch, you neen to realy power of the boards (instead of just a reset).
Best regards, Jeroen.
