MEGA Hardware Serial
I've read posts about using pins 18 & 19 on Arduino Mega as the Rx/Tx. I understand these are Hardware Serial ports. On the board itself they are labeled RX1&TX1.
But there are also RX2&3 & TX2&3. So if I put my GSM/GPRS module onto RX2&TX2, would it also work?
Yes. Use commands Serials.available, Serial2.read, Serial2.print, Serial2.write
You meant:
"Yes. Use commands Serial2.available, Serial2.read, Serial2.print, Serial2.write", right?
He sure did.
