Hi all...
I have been working on the master/slave I2C communication between a MEGA (master) and an UNO (slave) microcontrollers to send a very simple character from the MEGA to the UNO that will trigger a shield on the UNO to carry out its programmed portion. For now I am simply using the example provided in the Wire.h library...
MEGA as MASTER:
//Master_writer using MEGA
#include <Wire.h>
Wire.begin(); // join i2c bus (address optional for master)
byte x = 0;
Wire.beginTransmission(4); // transmit to device #4
Wire.write("x is "); // sends five bytes
Wire.write(x); // sends one byte
Wire.endTransmission(); // stop transmitting
x++;
UNO as the SLAVE
//Slave_receiver using UNO
#include <Wire.h>
Wire.begin(4); // join i2c bus with address #4
Wire.onReceive(receiveEvent); // register event
Serial.begin(9600); // start serial for output
delay(100);
// function that executes whenever data is received from master
// this function is registered as an event, see setup()
void receiveEvent(int howMany)
while(1 < Wire.available()) // loop through all but the last
char c = Wire.read(); // receive byte as a character
Serial.print(c); // print the character
int x = Wire.read(); // receive byte as an integer
Serial.println(x); // print the integer
I have a very silly question when it comes to the serial windows of each device.... Do I hit send on the MEGA then plug the UNO to the computer USB port then open its serial window to monitor the result?
I know, I know its silly but I really need to know.
Thanks.
Yesenia
