Presently Leonardo but Mega in 3 days...
I have this from examples. works fine. USB CONNECTION. NOT SERIAL!!!
- Do not know how to change it to (edit) C2 (for organ pedals for virtual organ via GrandOrgue) C2 and 36 ?
- Do not know how to generalize this to play 25 or 32 notes up from (edit) C2. Continuous NOT MATRIX. NOT SERIAL. Pins 2-12, 14- etc etc...
maybe something like for (int x = 0; x <= 127; x ++) {
if (x > 12 && x < 15) { // create jump in values
continue;
but how to insert that???
THANKS!!!
ex_02_button.ino
This is an example of the "Digital" class of the MIDI_controller library.
Connect a push buttons to digital pin 2. Connect the other pin of the button to the ground,
a pull-up resistor is not necessary, because the internal one will be used.
This button will play MIDI note C4 when pressed.
Map it in your DAW or DJ software.
Written by tttapa, 08/09/2017
https://github.com/tttapa/MIDI_controller
#include <MIDI_Controller.h> // Include the library
const uint8_t velocity = 0b1111111; // Maximum velocity (0b1111111 = 0x7F = 127)
const uint8_t C4 = 60; // Note number 60 is defined as middle C in the MIDI specification
// Create a new instance of the class 'Digital', called 'button', on pin 2, that sends MIDI messages with note 'C4' (60) on channel 1, with velocity 127
Digital button(2, C4, 1, velocity);
void setup() {}
// Refresh the button (check whether the button's state has changed since last time, if so, send it over MIDI)
MIDI_Controller.refresh();
