Hi guys, I want to record two distances in the serial monitor, save that in a micro SD on a .txt, and then open it in excel to make some graphics and statistics.
Above some stinges that i had to have:
14:38:09.954 -> Shutdown pins inited...
14:38:09.954 -> Both in reset mode...(pins are low)
14:38:09.954 -> Starting...
14:38:10.944 -> 1: 31 2: 40
14:38:11.111 -> 1: 30 2: 41
14:38:11.327 -> 1: 33 2: 42
14:38:11.459 -> 1: 30 2: 39
14:38:11.655 -> 1: 30 2: 39
14:38:11.853 -> 1: 31 2: 42
I tried with Uno R3 board, but it hasn't enough ram, so a switched to Mega R3 2560 and now it's working fine, also the wiring for both VL53L0XV2 and the card reader is correct.
At this moment, I have a sketch for lasers and a sketch for SD. Both work alone, but if I try to combine them in a single sketch, things get tough.
Any help?
Laser x2:
#include "Adafruit_VL53L0X.h"
// address we will assign if dual sensor is present
#define LOX1_ADDRESS 0x30
#define LOX2_ADDRESS 0x31
// set the pins to shutdown
#define SHT_LOX1 7
#define SHT_LOX2 6
// objects for the vl53l0x
Adafruit_VL53L0X lox1 = Adafruit_VL53L0X();
Adafruit_VL53L0X lox2 = Adafruit_VL53L0X();
// this holds the measurement
VL53L0X_RangingMeasurementData_t measure1;
VL53L0X_RangingMeasurementData_t measure2;
Reset all sensors by setting all of their XSHUT pins low for delay(10), then set all XSHUT high to bring out of reset
Keep sensor #1 awake by keeping XSHUT pin high
Put all other sensors into shutdown by pulling XSHUT pins low
Initialize sensor #1 with lox.begin(new_i2c_address) Pick any number but 0x29 and it must be under 0x7F. Going with 0x30 to 0x3F is probably OK.
Keep sensor #1 awake, and now bring sensor #2 out of reset by setting its XSHUT pin high.
Initialize sensor #2 with lox.begin(new_i2c_address) Pick any number but 0x29 and whatever you set the first sensor to
void setID() {
// all reset
digitalWrite(SHT_LOX1, LOW);
digitalWrite(SHT_LOX2, LOW);
delay(10);
// all unreset
digitalWrite(SHT_LOX1, HIGH);
digitalWrite(SHT_LOX2, HIGH);
delay(10);
// activating LOX1 and resetting LOX2
// initing LOX1
if(!lox1.begin(LOX1_ADDRESS)) {
Serial.println(F("Failed to boot first VL53L0X"));
while(1);
delay(10);
// activating LOX2
delay(10);
//initing LOX2
if(!lox2.begin(LOX2_ADDRESS)) {
Serial.println(F("Failed to boot second VL53L0X"));
while(1);
void read_dual_sensors() {
lox1.rangingTest(&measure1, false); // pass in 'true' to get debug data printout!
lox2.rangingTest(&measure2, false); // pass in 'true' to get debug data printout!
// print sensor one reading
Serial.print(F("1: "));
if(measure1.RangeStatus != 4) { // if not out of range
Serial.print(measure1.RangeMilliMeter);
Serial.print(F("Out of range"));
Serial.print(F(" "));
// print sensor two reading
Serial.print(F("2: "));
if(measure2.RangeStatus != 4) {
Serial.print(measure2.RangeMilliMeter);
// wait until serial port opens for native USB devices
while (! Serial) { delay(1); }
pinMode(SHT_LOX1, OUTPUT);
pinMode(SHT_LOX2, OUTPUT);
Serial.println(F("Shutdown pins inited..."));
Serial.println(F("Both in reset mode...(pins are low)"));
Serial.println(F("Starting..."));
setID();
read_dual_sensors();
delay(100);
SD logger:
SD card datalogger
This example shows how to log data from three analog sensors
to an SD card using the SD library.
The circuit:
analog sensors on analog ins 0, 1, and 2
SD card attached to SPI bus as follows:
created 24 Nov 2010
modified 9 Apr 2012
by Tom Igoe
This example code is in the public domain.
#include <SPI.h>
#include <SD.h>
const int chipSelect = 53;
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
Serial.print("Initializing SD card...");
// see if the card is present and can be initialized:
if (!SD.begin(chipSelect)) {
Serial.println("Card failed, or not present");
// don't do anything more:
while (1);
Serial.println("card initialized.");
// make a string for assembling the data to log:
String dataString = "";
// read three sensors and append to the string:
for (int analogPin = 0; analogPin < 3; analogPin++) {
int sensor = analogRead(analogPin);
dataString += String(sensor);
if (analogPin < 2) {
dataString += ",";
// open the file. note that only one file can be open at a time,
// so you have to close this one before opening another.
File dataFile = SD.open("datalog.txt", FILE_WRITE);
// if the file is available, write to it:
if (dataFile) {
dataFile.println(dataString);
dataFile.close();
// print to the serial port too:
Serial.println(dataString);
// if the file isn't open, pop up an error:
else {
Serial.println("error opening datalog.txt");
