Hey,
Have a quick question. Is it possible to do serial on two ports at the same time? I need to have the Mega talk to the PC on TX pin 1 and also hav ethe Mega talk to a Serial LCD on say pin 18, while also sending PWM signals to Pins 9-12 using the Servo.h library. My issue is this. When program runs. Screen just flashes wildly and servos just jitter. Part of my issue might be power. Screen needs 6v and 4 servos need 4.5v-6v. So I will try that with higher supplied voltage. But I think I still have serial conficts as well.
Do I need to delcare serial definitions for TX to PC since by default it sees serial traffic anyway on pins 1 and 2?
Code flow. LCD displays via serial . Enter x, from PC input Via USB serial port user enters x value. Value moves servo and loop. Seems like it should work.
Hope it makes sense.
Regards,
MadDawg
