So, I got a new Arduino Mega (chinese clone with CH340).
I plugged the USB cable, and drivers worked perfectly (has another MEGA clone with CH340 too that works without any problem).
To test, I tried to send the 'Blink' example, and got timeout from avrdude:
avrdude: stk500v2_ReceiveMessage(): timeout
avrdude: stk500v2_getsync(): timeout communicating with programmer
An error occurred while uploading the sketch
So, I was thinking... maybe this board don't have bootloader!
Got my USBASP 2.0, and burn a new bootloader...
everything seens ok:
C:\Program Files (x86)\Arduino\hardware\tools\avr\bin>avrdude -C ..\etc\avrdude.conf -c usbasp -p m2560 -v -e -U efuse:w:0xFD:m -U hfuse:w:0xD8:m -U lfuse:w:0xFF:m
C:\Program Files (x86)\Arduino\hardware\tools\avr\bin>avrdude -C ..\etc\avrdude.conf -c usbasp -p m2560 -B 1 -v -e -U flash:w:"c:\Program Files (x86)\Arduino\hardware\arduino\avr\bootloaders\stk500v2\stk500boot_v2_mega2560.hex":i -U lock:w:0x0F:m
and everything seens to be ok (according with avrdude)
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:00:53
Copyright (c) 2007-2014 Joerg WunschSystem wide configuration file is "..\etc\avrdude.conf"
Using Port : usb
Using Programmer : usbasp
Setting bit clk period : 1.0
AVR Part : ATmega2560
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PA0
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 10 8 0 no 4096 8 0 9000 9000 0x00 0x00
flash 65 10 256 0 yes 262144 256 1024 4500 4500 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00Programmer Type : usbasp
Description : USBasp, USBasp - USB programmer for Atmel AVR controllers - fischl.deavrdude: set SCK frequency to 750000 Hz
avrdude: warning: cannot set sck period. please check for usbasp firmware update.
avrdude: AVR device initialized and ready to accept instructionsReading | ################################################## | 100% 0.04s
avrdude: Device signature = 0x1e9801 (probably m2560)
avrdude: safemode: hfuse reads as D8
avrdude: safemode: efuse reads as FD
avrdude: erasing chip
avrdude: reading input file "c:\Program Files (x86)\Arduino\hardware\arduino\avr\bootloaders\stk500v2\stk500boot_v2_mega2560.hex"
avrdude: writing flash (261406 bytes):Writing | ################################################## | 100% 0.26s
avrdude: 261406 bytes of flash written
avrdude: verifying flash memory against c:\Program Files (x86)\Arduino\hardware\arduino\avr\bootloaders\stk500v2\stk500boot_v2_mega2560.hex:
avrdude: load data flash data from input file c:\Program Files (x86)\Arduino\hardware\arduino\avr\bootloaders\stk500v2\stk500boot_v2_mega2560.hex:
avrdude: input file c:\Program Files (x86)\Arduino\hardware\arduino\avr\bootloaders\stk500v2\stk500boot_v2_mega2560.hex contains 261406 bytes
avrdude: reading on-chip flash data:Reading | ################################################## | 100% 0.27s
avrdude: verifying ...
avrdude: 261406 bytes of flash verified
avrdude: reading input file "0x0F"
avrdude: writing lock (1 bytes):Writing | ################################################## | 100% 0.02s
avrdude: 1 bytes of lock written
avrdude: verifying lock memory against 0x0F:
avrdude: load data lock data from input file 0x0F:
avrdude: input file 0x0F contains 1 bytes
avrdude: reading on-chip lock data:Reading | ################################################## | 100% 0.01s
avrdude: 1 bytes of lock verifiedavrdude: safemode: hfuse reads as D8
avrdude: safemode: Fuses OK (E:FD, H:D8, L:FF)avrdude done. Thank you.
plugged the usb again, started the arduino ide, and tried a new attempt to upload the 'blink' example on this board... but still, the same error:
any help on this?
