mega168 no interrupt when RISING CHANGES FALLING
hi, i made a small programm wich blink a few seconds go to sleep mode the if waked up blink a few second etc…
that s my code:
include <avr/sleep.h>
int i=1;
  pinMode(2, INPUT);
  pinMode(13, OUTPUT);
  digitalWrite(2,LOW); //for pull down
void call_back()
void f_make_it_sleep()
set_sleep_mode(SLEEP_MODE_PWR_DOWN);//set sleep parameters
sleep_enable();
attachInterrupt(0,call_back,RISING);
sleep_mode();
sleep_disable();
detachInterrupt(0);
{ i++;
  digitalWrite(13,HIGH);
  delay(200);
   digitalWrite(13,LOW);
  delay(200);
  if(i==15)
   i=0;
   digitalWrite(2,LOW); //for pull down again (to be sure)
   f_make_it_sleep();
it doesn’t work neither for CHANGES or FALLING (after inversing pull down by pull up)
But it does work perfectly with LOW and the pull down in pull up…
It’s a minipro mega168 5v 16mhz
i have no more ideas…
all the 4 kind of interrupt work perfectly on my uno…
The datasheet for the atmega chip family says that only a LOW interrupt or a pin change interrupt can wake it up from power down mode.
thank s for your reply, isn't RISING a pin change interrupt?
if you put it to sleep, then your program will stop .
Do you have some external way of signalling the interrupt pin ? Like a wire with a switch, or something ?
This may be of some use: http://www.gammon.com.au/forum/?id=11497
is it possible that an external interrupt must be a low interrupt and no other interrupt, to wake it up?
victorjung: thank s for your reply, isn't RISING a pin change interrupt?
No, a pin change interrupt is a different animal, which the attachInterrupt function doesn't use. However, you can use a pin change interrupt to do the same thing you would do using a RISING interrupt.
victorjung: is it possible that an external interrupt must be a low interrupt and no other interrupt, to wake it up?
Yes if you are using the INT0 or INT1 interrupt (on the Uno), which is what the attachInterrupt function uses. No if you use a pin change interrupt.
what s exactly a pin change interrupt? i think i don't understand this... i think i am using int0 with attachinterrupt according to my code :| so it should work with rising right?
victorjung: what s exactly a pin change interrupt? i think i don't understand this... i think i am using int0 with attachinterrupt according to my code :| so it should work with rising right?
No it won't, see my earlier replies. For more on pin change interrupts, see http://playground.arduino.cc/Main/PinChangeInt.
i finally get it!!!! thanks for your patience :) so you re saying i should use pin change if i absolutely want a rising interrupt? I gonna try it one more time thanks
victorjung: so you re saying i should use pin change if i absolutely want a rising interrupt?
Yes, if you want a rising interrupt to wake up the mcu from power down mode.
