I started Arduino programming a few days ago, because a coworker asked me if I wanted to use it to control my terrariums in a convenient way. Well, I said yes and I don’t regret it so far. Until now I used a RaspberryPi and cronjob to switch the lights, which didn’t work very well.
But now it seems I am stuck, so I hope some of you are willing to give me an advice.
My setup:
- this set: http://www.sainsmart.com/sainsmart-mega2560-board-3-5-tft-lcd-module-display-shield-kit-for-atmel-atmega-avr-16au-atmega8u2.html (Arduino Mega2560 + 3.2 TFT Touch Screen + Shield)
- a DS1307 for the timer (SDA → Analog 0, SDC → Analog 2)
- a 433MHz transmitter to control my remote sockets (The remote sockets are Elro AB440S, the transmitter is one of the billions of transmitters you can buy for about 1€/$) (Data → Pin 8)
What am I trying to do?
- automatically switch the lights in my terrariums on/off, while simulating the different seasons (no light during winter, longest during summer, etc.) → this is the main reason why I don’t want to use standard time switches, since they ususally do not allow many different times depending on the date
- print buttons on the touch screen so I can manually switch additional remote sockets (e.g. TV, PC, lights, …)
Right now, the buttons are used in case something goes wrong. So I got one button that switches everything in the terrariums on, another one that switches everything off and one that doesn’t do anything so far.
My problem:
- the timer works just fine. The lights are switched on/off as I want them to.
- BUT I can’t use the buttons. In the examples the buttons are usually implemented using an infinite while loop, but I can’t use this because the timer wouldn’t work if I did. The if-functions to switch the lights are not included in the while loop that controls the buttons, so if the while loop is infinite, the if-functions would never be reached.
I guess one of the problems is that I don’t draw the buttons during the execution of the “void loop” function. But if i do that, they are drawn continously, resulting in flickering buttons. But even if I add the “Draw Buttons” part to the "void loop"function, it doesn’t work. I can press the button, it even shows the red frame around the button while pressed, but it doesn’t execute the commands.
I included my code (with part of the timer cut out to keep it short). The important part is right at the beginning of the void loop function, where I tried to make the buttons work.
P.S, - just in advance:
- Sorry for the long post, but I wanted to make my problem as clear as possible, and I hope it worked…
- Sorry for my english, but as you may already have noticed, it’s not my mothers tongue. I am trying to improve though, so if you spot any mistakes, feel free to tell me.
(3. I hope my code is readable, I tried to keep it structured.)
//Include Libraries
#include <UTFT.h>
#include <UTouch.h>
#include <UTFT_Buttons.h>
#include <DS1307.h>
#include <RCSwitch.h>
//Initialise everything
UTFT myGLCD(ITDB32S,38,39,40,41);
UTouch myTouch(6,5,4,3,2);
UTFT_Buttons myButtons(&myGLCD, &myTouch);
DS1307 rtc(A0,A2);
RCSwitch mySwitch = RCSwitch();
Time t;
//Declare the used fonts
extern uint8_t SmallFont[];
extern uint8_t BigFont[];
//--------------Setup everything--------------
//Setup Function
myGLCD.InitLCD();
myGLCD.clrScr();
myTouch.InitTouch();
myTouch.setPrecision(PREC_LOW);
myGLCD.setFont(SmallFont);
myGLCD.setBackColor(0,0,0);
myButtons.setTextFont(BigFont);
//Draw fixed parts of date and time
myGLCD.print("|",175,215);
myGLCD.print("|",257,215);
myGLCD.drawRoundRect(140,208,315,232);
//Settings Transmitter
mySwitch.enableTransmit(8);
mySwitch.setRepeatTransmit(10);
//Status Messages
myGLCD.drawRoundRect(10,80,265,190);
myGLCD.print("Status Roehren Reptilien:",20,90);
myGLCD.print("Status Spots Reptilien:",20,110);
myGLCD.print("Status Roehren Froesche:",20,130);
myGLCD.print("Status Spot Froesche:",20,150);
myGLCD.print("Status Nachtlicht Leos:",20,170);
//Add the buttons
int off, on, other, pressed_button;
off = myButtons.addButton(10,10,90,50,"Aus");
on = myButtons.addButton(115,10,90,50,"An");
other = myButtons.addButton(220,10,90,50,"Sonst");
myButtons.drawButtons();
//--------------Loop Function--------------
t = rtc.getTime();
while (myTouch.dataAvailable()==true) {
pressed_button=myButtons.checkButtons();
if (pressed_button==off) {
roehrenrepaus();
roehrenfraus();
roehrenfraus();
spotfraus();
spotrepaus();
if (pressed_button==on) {
roehrenrepan();
roehrenfran();
roehrenfran();
spotfran();
spotrepan();
//--------------Timer--------------
//Geckos NL
if (t.hour==22 && t.min==02) {
nlleoan();
if (t.hour==1 && t.min==00) {
nlleoaus();
//January
if (t.mon==1) {
//Frogs
if (t.hour==10 && t.min==15) {
roehrenfran();
if (t.hour==20 && t.min==45) {
roehrenfraus();
if (t.hour==10 && t.min==45) {
spotfran();
if (t.hour==20 && t.min==15) {
spotfraus();
//Other terrariums
//15. - 16.
if (t.date==15 || t.date==16) {
[Cut out to keep it short]
//December
if (t.mon==12) {
if (t.hour==10 && t.min==00) {
roehrenfran();
if (t.hour==21 && t.min==00) {
roehrenfraus();
if (t.hour==10 && t.min==30) {
spotfran();
if (t.hour==20 && t.min==30) {
spotfraus();
//--------------Display Date and Time--------------
myGLCD.print(rtc.getDOWStr(FORMAT_SHORT),150,215);
myGLCD.print(rtc.getDateStr(FORMAT_SHORT),190,215);
myGLCD.print(rtc.getTimeStr(FORMAT_SHORT),270,215);
//--------------Used functions--------------
void roehrenrepan() {
myGLCD.print("An ",230,90);
mySwitch.switchOn("11000", "01000");
mySwitch.switchOn("10001", "00100");
mySwitch.switchOn("11000", "00100");
void roehrenrepaus() {
myGLCD.print("Aus",230,90);
mySwitch.switchOff("11000", "01000");
mySwitch.switchOff("10001", "00100");
mySwitch.switchOff("11000", "00100");
void spotrepan() {
myGLCD.print("An ",230,110);
mySwitch.switchOn("11000", "10000");
mySwitch.switchOn("10001", "00010");
mySwitch.switchOn("11000", "00010");
void spotrepaus() {
myGLCD.print("Aus",230,110);
mySwitch.switchOff("11000", "10000");
mySwitch.switchOff("10001", "00010");
mySwitch.switchOff("11000", "00010");
void roehrenfran() {
myGLCD.print("An ",230,130);
mySwitch.switchOn("10001", "10000");
void roehrenfraus() {
myGLCD.print("Aus",230,130);
mySwitch.switchOff("10001", "10000");
void spotfran() {
myGLCD.print("An ",230,150);
mySwitch.switchOn("10001", "01000");
void spotfraus() {
myGLCD.print("Aus",230,150);
mySwitch.switchOff("10001", "01000");
void nlleoan() {
myGLCD.print("An ",230,170);
mySwitch.switchOn("11001", "10000");
void nlleoaus() {
myGLCD.print("Aus",230,170);
mySwitch.switchOff("11001", "10000");
