MegaISP error (when trying to burn the bootloader)
Hi ...
I would like to ask, if someone could tell me why I have this error masage ???
avrdude: stk500_program_enable(): protocol error, expect=0x14, resp=0x50
avrdude: initialization failed, rc=-1
         Double check connections and try again, or use -F to override
         this check.
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x51
I have checked the connections, everything...but I still get this massage :(
Could someone help me ???
Thanks in advance.
Make sure you are using the correct pins. They (10 - 13) are the spi pins, and should (or probably can) not be changed.
Problem solved ... I had a bad part/resistor that didn't work. I changed the resistor and everything is done.
Thank you ...
