MegaServo.h read servo position
hi, i’m new to programming and microcontroller so i got myself a arduino mega to learn, oh and english isn’t my native language so…sry about my writing style :wink:
about my problem:
how do i read the position from a servo, can someone change this testcode for me so that i understand it?
i want to move a servo to random positions and if the servo has reached a specific position (in this case 90°) a led should light up
#include <MegaServo.h>
MegaServo servo1;
int y = 0;
long x;
int LED = 13;
void setup(){
servo1.attach(10);
void loop(){
x = random(180);
servo1.write(x);
// add read servopositioncode here please and save position in y
if (y == 90){
            digitalWrite(LED, HIGH);}
           else {
thx for your help
fujii
edit:
i also don’t understand the “read_us” and “attached” function, would be nice if someone can write a little examplecode ::slight_smile:
The methods are:
MegaServo - Class for manipulating servo motors connected to Arduino pins.
attach(pin ) - Attaches a servo motor to an i/o pin.
attach(pin, min, max ) - Attaches to a pin setting min and max values in microseconds
default min is 544, max is 2400
write(unsigned int) - Sets the servo pulse width in microseconds or degrees. (0-200 as degrees, greater values are uS)
read() - Gets the last written servo pulse width as an angle between 0 and 180.
read_us() - Gets the last written servo pulse width in microseconds.
attached() - Returns true if there is a servo attached.
detach() - Stops an attached servos from pulsing its i/o pin.
MegaServo servo1;
int y = 0;
long x;
int LED = 13;
void setup(){
servo1.attach(10);
void loop(){
x = random(180);
servo1.write(x);
y = servo1.read(); // Gets the last written servo pulse width as an angle between 0 and 180.
if (y == 90){
           else {
Ahh now i get it. I allways wrote something like:
servo1.read(y)
thank you :slight_smile:
