How many here are using MegunoLink for creating User Interface Panel for your Arduino Hardware developments as well as distribute it ?
Thanks and regards Rainer
Nobody ? I am just asking in order to know if we can help each other in developing User Interfaces with this Software.
I know manu ise VB, C#, etc. but for me those langiages are liked a closed book to me.
I have nothing to do with the Company. I am a user as anybody else here
Yesterday I fiddled for around one or two hours and finally managed to getit going. I set up a voltage divider and wanted to read the outcoming voltage. As said it took some while but finally I got it going.
Hope we can start a bit of interaction here as the MegunoLink Software seems to be easy for non programmers as I found out yesterday.
Later in the afternoon I will post my sketch and some screenshots.
regards Rainer
Interesting software, but since I know other programming languages, I am not that keen on learning a new one.
Good to know it is available.
I have and use MegunoLink, every now and then.
As far as using it for a 'User Interface Panel', all my projects are stand alone.
I don’t have a need to use the software as a User Interface Panel per se.
I understand.
What do you mean by stand alone ?
regards Rainer
Standalone, as in not connected to a PC to run, generally.
Example:
I have made several clocks using a Pro Mini an RTC and neopixels.
They function by themselves and do not need to be connected to a PC to function.
larryd:
Example:
I have made several clocks using a Pro Mini an RTC and neopixels.They function by themselves and do not need to be connected to a PC to function.
Thank you. So you just plug in an external power supply and the Arduino starts to work and somewhere, I guess a LED display gives me the info.
In my case I have to options. No display at all just by blinking LED I am signalizing what my hardware is doing and this when I connect it o a battery (that would be a stand alone) and if I plug in a USB cable then I want to have a User Interface where the User can interact with my hardware.
regards Rainer
Im trying it now for a project and having difficulty with it. it works, but somehow i am getting an "Unknown command" error. I am told the code is fine, but it just isn't sending or working with an integer from a number selector box.
