Es sieht danach aus, dass sich der Thread in eine Richtung bewegt, in der ich mich endgültig nicht mehr auskenne. Ich bin aus diesem Thread also erstmal weg.
Gruß
Gregor
Gruß
Gregor
Hier mal ein Beispiel wie man es machen kann.
Client
#include <ESP8266WiFi.h>
const char* ssid = "........"; //Zugangsdaten deines Routers einfügen
const char* password = "........";
const char* host = "192.168.179.21"; // IP des Server
unsigned long previousMillis = 0;
Serial.begin(250000);
delay(10);
Serial.print("Connecting to ");
Serial.println(ssid);
WiFi.begin(ssid, password);
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected");
Serial.println("IP address: ");
float Temp = 17.8;
byte Schaltstellung = 0;
if (currentMillis - previousMillis >= 5000) {
Schaltstellung = !Schaltstellung;
Temp = Temp + 0.1;
Serial.print("connecting to ");
Serial.println(host);
// Use WiFiClient class to create TCP connections
WiFiClient client;
const int httpPort = 80;
if (!client.connect(host, httpPort)) {
Serial.println("connection failed");
return;
// We now create a URI for the request
String url = "/ClientSend?Temperatur=";
url += Temp;
url += "&Schalter=";
url += Schaltstellung;
Serial.print("Requesting URL: ");
Serial.println(url);
// This will send the request to the server
client.print(String("GET ") + url + " HTTP/1.1\r\n" +
"Host: " + host + "\r\n" +
"Connection: close\r\n\r\n");
unsigned long timeout = millis();
while (client.available() == 0) {
if (millis() - timeout > 5000) {
Serial.println(">>> Client Timeout !");
client.stop();
return;
// Read all the lines of the reply from server and print them to Serial
while (client.available()) {
String line = client.readStringUntil('\r');
Serial.print(line);
Serial.println("closing connection");
Server
#include <ESP8266WebServer.h>
String Content;
ESP8266WebServer server(80);
void handleRoot() {
server.send(200, "text/plain", Content);
void handleNotFound() {
String message = "File Not Found\n\n";
message += "URI: ";
message += server.uri();
message += "\nMethod: ";
message += (server.method() == HTTP_GET) ? "GET" : "POST";
message += "\nArguments: ";
message += server.args();
message += "\n";
for (uint8_t i = 0; i < server.args(); i++) {
message += " " + server.argName(i) + ": " + server.arg(i) + "\n";
server.send(404, "text/plain", message);
void setup(void) {
Serial.println("");
// Wait for connection
Serial.print(".");
Serial.println("");
Serial.print("Connected to ");
Serial.print("IP address: ");
server.on("/", handleRoot);
server.on("/ClientSend", []() {
String Temperatur = server.arg("Temperatur");
String Schaltstellung = server.arg("Schalter");
Serial.print("Temperatur: "); Serial.println(Temperatur);
Serial.print("Schalter: "); Serial.println(Schaltstellung);
Content = "Temperatur: " + Temperatur + " C - Schalter: " + Schaltstellung;
server.send(204);
server.onNotFound(handleNotFound);
server.begin();
Serial.println("HTTP server started");
void loop(void) {
server.handleClient();
Oder doch lieber UDP?
Gruß Fips
Der Overhead ist bei UDP wesentlich geringer, als mit HTTP.
Gruß Tommy
Tommy56:
Der Overhead ist bei UDP wesentlich geringer, als mit HTTP.Gruß Tommy
Ist vollkommen klar.
Ich musste das mal bauen, weil ich es bis jetzt auch noch nie gemacht habe.
Und wenn es schon mal funktioniert, zeige ich das als weitere Möglichkeit zur Kommunikation.
Gruß Fips
Das war auch keinesfalls gegen Deinen Beitrag gerichtet. Sorry, wenn das so rüber kam.
Gruß Tommy
Tommy56:
Das war auch keinesfalls gegen Deinen Beitrag gerichtet. Sorry, wenn das so rüber kam.Gruß Tommy
Ja Nee ist schon klar.
Abwohl das den TO egal sein dürfte, Hauptsache es kommt was an.
Wahrscheinlich hat er es ja schon selbst hinbekommen.
Gruß fips
Dank eurer Hilfe hab ich es fast geschafft. Ich hab den Datenaustausch per HTTP gemacht, das funktioniert erstmal. Das Projekt von Tommy per UDP muß ich mir noch näher anschauen, aber mir fehlen einfach noch paar Basics. Den vom Client gesendeten String hab ich auch erfolgreich wieder im Serversketch zerlegen können. Den Schaltzustand, also 0 oder 1, habe ich genau wie die Temperatur, nach dem zerlegen jeweils als char. Jetzt will ich einen Ausgang schalten, wenn der Schaltzustand =1 ist.
Folgendes habe ich geschrieben:
//Variable schaltzustand wurde aus dem Client-String extrahiert und ist vom Typ char
int relais = 12;
pinMode(relais, OUTPUT);
{void loop(){
const char* vergleich =1;
if (schaltzustand == vergleich){
digitalWrite(relais = HIGH);
digitalWrite(relais = LOW);
Serial.println(schaltzustand);
Serial.println(vergleich);
Ist schaltzustand 1, sollte doch der Ausgang relais auf High gehen, macht er aber nicht. Das kann doch nur was ganz simples sein. Im SM wird mir für schaltzustand und vergleich eine 1 angezeigt.
computerpap:
Folgendes habe ich geschrieben:Ist schaltzustand 1, sollte doch der Ausgang relais auf High gehen, macht er aber nicht. Das kann doch nur was ganz simples sein. Im SM wird mir für schaltzustand und vergleich eine 1 angezeigt.
Wiso von String nach char??
if (Schaltstellung == "0") {
digitalWrite(relais, HIGH);
Serial.println("Relais aus");
else {
digitalWrite(relais, LOW);
Serial.println("Relais an");
server.send
Ich habe es mit so nen billigen blauen Relais getestet.
Macht bei mir immer schön klick klack.
Gruß Fips
UDP mal ganz einfach
Client
#include <WiFiUdp.h>
const char* addr = "192.168.176.26"; // IP vom Server
unsigned int port = 4097; // Udp Port vom Server
WiFiUDP Udp;
float Temp = 16.8;
Serial.printf("Connecting to %s ", ssid);
while (WiFi.status() != WL_CONNECTED)
Serial.print(".");
Serial.println(" connected");
Temp = Temp + 0.1;
Udp.beginPacket(addr, port);
Udp.print(Schaltstellung);
Udp.print(" ");
Udp.print(Temp);
Udp.endPacket();
Server
const char* ssid = "FRITZ!Box 7580 CY";
const char* password = "28042987665003400230";
char incomingPacket[10]; // Puffer für eingehende Pakete
unsigned int localUdpPort = 4097; // Lokaler Port für UDP-Pakete
int Relais = 12;
String Content;
WiFiUDP Udp;
void handleRoot() {
message += "URI: ";
message += "\n";
void setup(void) {
pinMode(Relais, OUTPUT);
digitalWrite(Relais, HIGH);
Serial.println("");
Serial.print(".");
Serial.println("");
server.begin();
Udp.begin(localUdpPort);
Serial.printf("Now listening at IP %s, UDP port %d\n", WiFi.localIP().toString().c_str(), localUdpPort);
void loop(void) {
UdpPacket();
void UdpPacket() {
int packetSize = Udp.parsePacket();
if (packetSize)
Serial.printf("Received %d bytes from %s, port %d\n", packetSize, Udp.remoteIP().toString().c_str(), Udp.remotePort());
int len = Udp.read(incomingPacket, 10);
if (len > 0) incomingPacket[len] = 0;
Serial.printf("UDP packet contents: %s\n", incomingPacket, 10);
char Temperatur[7];
strcpy(Temperatur, incomingPacket + 2);
Content = Temperatur;
int Schaltzustand = atoi(incomingPacket );
if (Schaltzustand == 0) {
Content += " C Relais aus";
else {
digitalWrite(Relais, LOW);
Content += " C Relais an";
und auch das Relais ist mit drin
Gruß Fips
Für was hast Du den HTTP-server noch mit drin? Der wird doch nicht gebraucht und verwirrt nur.
Gruß Tommy
Tommy56:
Für was hast Du den HTTP-server noch mit drin? Der wird doch nicht gebraucht und verwirrt nur.Gruß Tommy
Im Eingangspost war von einen Server die Rede. Von Udp stand da noch nix.
Für mich ist das so, wenn wir schonmal online sind, bietet es sich doch an die Werte auch gleich noch im Browser anzeigen zu können.
OK,
davon hat er nichts geschrieben. Aber auch nicht was er mit der Temperatur vor hat(LCD, Browser oder gar nichts.
Gruß Fips
Ja, die Infos sind etwas mager. Nur wenn Du das als
titulierst, sollte auch nur UDP drin sein, sonst könnte noch jemand denken, den HTTP-Server braucht man dazu.
Gruß Tommy
OK
habs geändert.
Gruß Fips
computerpap:
Das sind ja mal gute Neuigkeiten. Ich nehme an, dass inzwischen auch das funktioniert, was das „fast geschafft“ zum „geschafft“ macht.
computerpap:
Dann würde ich das mit UDP bleiben lassen. Mag sein, dass das die Übertragung noch ein Byte oder zwei schlanker macht, aber wenn es per HTTP funktioniert, funktioniert es (was IMO die Hauptsache ist).
Gruß
Gregor
Temperatur soll nur auf einen Display angezeigt werden.
Klar bin ich erstmal froh, dass alles soweit läuft, aber UDP ist für meine Zwecke definitiv eine Alternative. Ich hatte mich für HTTP entschieden, weil ich im Netz da die meisten Beispiele gefunden habe.
Nochmals vielen Dank an alle die mir hier wirklich sehr konstruktiv geholfen haben.
MfG
conputerpap
@Derfips, bei deinen Server_UDP-Sketch hagelt es nur Fehlermeldungen, mit denen ich nichts so richtig anfangen kann. Daraufhin hab ich die Arduino-IDE komplett deinstalliert, sämtliche Ordner und Dateien die bei der Deinstallation übrig geblieben sind gelöscht. Die IDE neuinstalliert und nur über den Boardverwalter die ESP-Module hinzugefügt, alles ist praktisch jungfräulig. Die Fehlermeldungen sind aber geblieben.
Arduino: 1.8.3 (Windows 10), Board: "NodeMCU 1.0 (ESP-12E Module), 80 MHz, 115200, 4M (3M SPIFFS)"
In file included from C:\Users\Andreas\Documents\Arduino\ESP_Server_UDP\ESP_Server_UDP.ino:1:0:
C:\Users\Andreas\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.2.0\libraries\ESP8266WebServer\src/ESP8266WebServer.h:64:30: error: expected ')' before 'addr'
ESP8266WebServer(IPAddress addr, int port = 80);
C:\Users\Andreas\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.2.0\libraries\ESP8266WebServer\src/ESP8266WebServer.h:88:3: error: 'WiFiClient' does not name a type
WiFiClient client() { return _currentClient; }
C:\Users\Andreas\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.2.0\libraries\ESP8266WebServer\src/ESP8266WebServer.h:135:22: error: 'WiFiClient' has not been declared
bool _parseRequest(WiFiClient& client);
C:\Users\Andreas\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.2.0\libraries\ESP8266WebServer\src/ESP8266WebServer.h:138:19: error: 'WiFiClient' has not been declared
bool _parseForm(WiFiClient& client, String boundary, uint32_t len);
C:\Users\Andreas\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.2.0\libraries\ESP8266WebServer\src/ESP8266WebServer.h:141:27: error: 'WiFiClient' has not been declared
uint8_t _uploadReadByte(WiFiClient& client);
C:\Users\Andreas\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.2.0\libraries\ESP8266WebServer\src/ESP8266WebServer.h:151:3: error: 'WiFiServer' does not name a type
WiFiServer _server;
C:\Users\Andreas\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.2.0\libraries\ESP8266WebServer\src/ESP8266WebServer.h:153:3: error: 'WiFiClient' does not name a type
WiFiClient _currentClient;
C:\Users\Andreas\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.2.0\libraries\ESP8266WebServer\src/ESP8266WebServer.h: In member function 'size_t ESP8266WebServer::streamFile(T&, const String&)':
C:\Users\Andreas\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.2.0\libraries\ESP8266WebServer\src/ESP8266WebServer.h:129:10: error: '_currentClient' was not declared in this scope
return _currentClient.write(file, HTTP_DOWNLOAD_UNIT_SIZE);
C:\Users\Andreas\Documents\Arduino\ESP_Server_UDP\ESP_Server_UDP.ino: In function 'void setup()':
ESP_Server_UDP:36: error: 'WiFi' was not declared in this scope
ESP_Server_UDP:40: error: 'WL_CONNECTED' was not declared in this scope
Mehrere Bibliotheken wurden für "WiFiUdp.h" gefunden
Benutzt: C:\Users\Andreas\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.2.0\libraries\ESP8266WiFi
Nicht benutzt: D:\Programme\Arduino\libraries\WiFi
exit status 1
Dieser Bericht wäre detaillierter, wenn die Option
"Ausführliche Ausgabe während der Kompilierung"
in Datei -> Voreinstellungen aktiviert wäre.
Angemeckert wird die Zeile "WiFi.begin(ssid, password);
Derfips:
OK
habs geändert.Gruß Fips
Wo denn? Der HTTP-Server ist noch drin.
Gruß Tommy
Welche ESP8266 - Lib hast Du installiert?
In Deinen Fehlermeldungen sind Zeilen, die sind nicht im Beispiel von "DerFips".
Gruß Tommy
esp8266 by ESP8266 Community
Version 2.2.0
Das klingt ok, obwohl die 2.3.0 aktuell ist. Das sollte es nicht sein.
Fehlermeldungen immer von oben anfangen zu bearbeiten.
Dort steht:
Diese Zeile gibt es im Code von Fips nicht. Du hast also nicht seinen Sketch.
Gruß Tommy
