member function does not change values
I am currently programming my RGB LEDCube and therefor I create color gradients in seperate classes. Those classes are derived from colorgnt.h. I dervied rainbowgnt.h from colorgnt.h. A colorgnt has a virtual rgb8bit(24bit RGB) function that delivers the wanted values dependant on uint8_t position. But I keep getting the number 0 but it should be 255. Why?
Code:
colorgnt.h
#ifndef colorgnt_H
#define colorgnt_H
#include "LEDCube.h"
typedef struct rgb8bit {
	uint8_t r;
	uint8_t g;
	uint8_t b;
class colorgnt {
  public:
  colorgnt() {}
  virtual rgb8bit rgb(uint8_t position) {}
#endif
rainbowgnt.h
#ifndef rainbowgnt_H
#define rainbowgnt_H
#include "colorgnt.h"
class colorgnt;  //is this neccessary?
class rainbowgnt: public colorgnt {
  public:
  rainbowgnt() {}
	rgb8bit rgb;
	rgb.r = 255;  //just for testing, no rainbow
	rgb.g = 255;
	rgb.b = 255;
	return rgb;
#endif
void LEDCube::rendergradient(colorgnt gradient) {
  rgb8bit whatever;
  whatever = gradient.rgb(5);  //Should set whatever.r/g/b to 255
  Serial.println(whatever.r); //Which it doesnt... Delivers '0'
void LEDCube::test() {
	rainbowgnt gnt;  //Intializing instance of rainbowgnt
	rendergradient(gnt);  //passing the instance to the function above
can you put all of tis into a ingle compilable version?
where is the source for your LedCube class?
The problem is that for polymorphism to work in C++ you need to pass your parameters by reference or as a pointer.
In your case, you are passing colorgnt by value in rendergradient. This causes the actual object passed, rainbowgnt gnt, to be sliced into a colorgnt losing the additional stuff in rainbowgnt.
arduarn:
Thank you! Solved it
BulldogLowell:
My issue is solved now but this was what I created:
#include <FastLED.h>
#define DATA_PIN 7
#include "Arduino.h"
#define NUMLEDS 343
#ifndef colorgnt_H
#define colorgnt_H
  uint8_t r;
  uint8_t g;
  uint8_t b;
// COLORGNT CLASS
class colorgnt {
  public:
  colorgnt() {}
#endif
// RAINBOWGNT CLASS
  public:
  rainbowgnt() {}
  rgb8bit rgb;
  rgb.r = 255;
  rgb.g = 255;
  rgb.b = 255;
  return rgb;
#endif
#ifndef LEDCube_H
#define LEDCube_H
// LEDCUBE CLASS
class LEDCube
  public:
  LEDCube(){
  FastLED.addLeds<WS2811, 7>(leds, 343);
  FastLED.setBrightness(255);
  FastLED.clear();
  void rendergradient(colorgnt *gradient) {
  rgb8bit whatever;
  whatever = gradient->rgb(5);
  rainbowgnt *gnt;
  Adafruit_NeoPixel simulated = Adafruit_NeoPixel(1, 3, NEO_GRB + NEO_KHZ800);
  static const int  limit = 7;
  static const int  limitsqu = limit * limit;
  static const int  numLeds = limitsqu * limit;
  CRGB leds[numLeds];
#endif
LEDCube cube;
  pinMode(13, OUTPUT);
  cube.test();
    cube.ani1();
    cube.sticks(40, 0, true, 255, 255, 255, 20);
    for (int i = 0; i < 21; i++) {
      cube.setall(255, 255, 255);
      delay(100);
      cube.clearLEDs();
      cube.rainbow(5, 256, 'x');
      cube.rainbow(5, 256, 'y');
      cube.rainbow(5, 2 * 256, 'z');
      for (int i = 0; i < limit; i++) {
        cube.setslice('x', i, 255, 0, 0);
        FastLED.show();
        delay(100);
        cube.setslice('y', i, 0, 255, 0);
        FastLED.show();
        delay(100);
        cube.setslice('z', i, 0, 0, 255);
        FastLED.show();
        delay(100);
      cube.sticksi(28, 0, false, 0, 0, 0, 0);
Passing by reference would probably have been easier and less error prone for a beginner, but either way will work when done correctly. Note that in the following code:
  rainbowgnt *gnt;
you have passed an uninitialised pointer into rendergradient and corrupted some random piece of RAM.
rainbowgnt *gnt; only declares a pointer variable but not the storage that it points to and, since it is a local variable, it will have an undefined value inside. You need to:
  • assign a value by allocating with new
  • or take the address of a local instance, ie. rainbowgnt gnt; rendergradient(&gnt);
  • or maybe pass by reference instead.
