Is there a function I can call to see how much memory is left in RAM?
No.
But this might help a few people:
Free Memory detection
From Arduino Cookbook
Modified by WillR March 22, 2011
Did I improve it or change it?
Good Question!
// external variables from build process
//String mystring[] = "testing";
//unsigned long myVal;
} //end setup
Serial.print("Free Memory: ");
Serial.print(memoryFree());
Serial.println(" ");
} //end loop
extern unsigned long __bss_end;
extern void *__brkval;
int memoryFree()
// long myValue;
int freeValue;
freeValue = 0;
if ((unsigned long)__brkval == 0)
freeValue = ((unsigned long)&freeValue) - ((unsigned long)&__bss_end);
// Serial.println("here and there");
freeValue = ((unsigned long)&freeValue) - ((unsigned long)__brkval);
// Serial.println("here 2");
return freeValue;
}//end memoryFree()
It seems to give reasonable answers.
You would also find this AVR-LIBC documentation interesting as it explains what is going on: http://avr-libc.nongnu.org/user-manual/malloc.html
This topic comes up from time to time. The last time I remember was this: http://arduino.cc/forum/index.php/topic,50924 But if you search around a bit you'll find others, including in the old forums.
That looks pretty good. And throwing in malloc (100) into the loop gives this:
Free Memory: 1834
Free Memory: 1732
Free Memory: 1630
Free Memory: 1528
Free Memory: 1426
Free Memory: 1324
Free Memory: 1222
Free Memory: 1120
Free Memory: 1018
Free Memory: 916
Free Memory: 814
Free Memory: 712
Free Memory: 610
Free Memory: 508
Free Memory: 406
Free Memory: 304
Free Memory: 202
Free Memory: 100
Free Memory: 100
Free Memory: 100
It looks like it uses 2 bytes more than the amount of memory you request (that sounds right, it has to store where the next piece of memory starts somewhere).
What a great function! Thanks so much.
I added it to the output and it shows my memory usage doesn't change between program executions. It does however show I am working with very little spare sram and therefore I can now use this number to whittle it down.
Don't thank me.
Thank this guy! ]:) http://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Ddigital-text&field-keywords=arduuion+cookbook&x=0&y=0
It has been worth every penny. I know how to do everything he points out in the book. What I did not know was how to do it efficiently on an Arduino. Nor did I really understand the C++/C paradigm.
Ignorance is not bliss. It sucks!
I think WillR intended this link: http://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Dstripbooks&field-keywords=arduino+cookbook&x=0&y=0
