Hi all, I think I need some fresh minds on my problem. I'm currently working in a code in order to make a lightning or flash detector.
I haven't tested it in real conditions so I've decided to implement 3 differents detection modes to see IRL which one is the most efficient.
For one of these mode I need to store the last measured values of the phototransistor in an array in order to compute the average value and detect a peak. For that I've set an array of 128 integer (valueHistory). Which should eat 256 bytes of memory.
When I run the program in the Arduino, the Arduino is stuck and doesn't start if the length of the array is more than 16 elements (initially I would like to store 128 values). So I think there is a memory problem.
The compilator show me this, and I guess that the 256 bytes of my array are included in the 41%:
Advanced Memory Usage is available via "PlatformIO Home > Project Inspect"
RAM: [==== ] 41.6% (used 852 bytes from 2048 bytes)
Flash: [====== ] 62.9% (used 20292 bytes from 32256 bytes)
If any of you have an idea, would be great
Here is the code:
* Boitier de commande pour le pilotage d'un appareil reflex et commande de focus sur telescope.
* Mode de detection de variation brusque de lumière via un phototransistor de type 3DU5C pour déclenchement automatique de la prise de vue en cas de détection de foudre
* Fonction de declenchement programmé pour fonction timelapse
* Composants:
* - Affichage sur Ă©cran OLED via protocole I2C
* Dev: Christian Poupounot // Date: 14 mars 2023
* Adapte du code de Florent Pin (https://forum.chasseurs-orages.com/viewtopic.php?t=6243) credits orginaux ;)
* Codage bitmap 24bits via http://javl.github.io/image2cpp/
// Inclusion Bibliothéques
#include <Arduino.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
// Hardware
// Ecran OLED
#define OLED_RESET 4
Adafruit_SSD1306 display(128,64, &Wire, OLED_RESET);
// Software
// Versionning
#define SOFTWARE_VERSION "1.11"
#define SOFTWARE_AUTHOR "Christian Poupounot"
// // 'logo-orionpx', 128x64px
// const unsigned char logo_orionpx [] PROGMEM = {
// 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
// 0x00, 0x00, 0x00, 0x00, 0xff, 0xff, 0xfd, 0xff, 0x80, 0x00, 0x0f, 0xff, 0x80, 0x00, 0x00, 0x00,
// 0x00, 0x00, 0x00, 0x00, 0xff, 0xff, 0xfe, 0xff, 0x00, 0x00, 0x1f, 0xff, 0x00, 0x00, 0x00, 0x00,
// 0x00, 0x00, 0x00, 0x00, 0xff, 0xff, 0xff, 0x7e, 0xc0, 0x00, 0x1f, 0xff, 0x00, 0x00, 0x00, 0x00,
// 0x00, 0x00, 0x00, 0x00, 0xff, 0xff, 0xff, 0xbd, 0xc0, 0x00, 0x3f, 0xfe, 0x00, 0x00, 0x00, 0x00,
// 0x00, 0x00, 0x00, 0x00, 0xff, 0xff, 0xff, 0xc3, 0xe0, 0x00, 0x3f, 0xfe, 0x00, 0x00, 0x00, 0x00,
// 0x00, 0x00, 0x00, 0x00, 0xff, 0xff, 0xff, 0xc3, 0xe0, 0x00, 0x7f, 0xfc, 0x00, 0x00, 0x00, 0x00,
// 0x00, 0x00, 0x00, 0x00, 0xff, 0xff, 0xff, 0xc7, 0xf0, 0x00, 0x7f, 0xfc, 0x00, 0x00, 0x00, 0x00,
// 0x00, 0x00, 0x00, 0x00, 0xff, 0xff, 0xff, 0xd3, 0xf0, 0x00, 0xdf, 0xf8, 0x00, 0x00, 0x00, 0x00,
// 0x00, 0x00, 0x00, 0x00, 0xff, 0xff, 0xff, 0xb1, 0xf8, 0x00, 0xdf, 0xf0, 0x00, 0x00, 0x00, 0x00,
// 0x00, 0x00, 0x00, 0x00, 0xff, 0xff, 0xff, 0xfb, 0xf8, 0x01, 0xdf, 0xf0, 0x00, 0x00, 0x00, 0x00,
// 0x00, 0x00, 0x00, 0x00, 0xff, 0xff, 0xff, 0xfb, 0xfc, 0x01, 0xff, 0xe0, 0x00, 0x00, 0x00, 0x00,
// 0x00, 0x00, 0x00, 0x00, 0xff, 0xf0, 0x03, 0xfd, 0xfc, 0x03, 0xbf, 0xe0, 0x00, 0x00, 0x00, 0x00,
// 0x00, 0x00, 0x00, 0x00, 0xff, 0xe0, 0x00, 0xfd, 0xfe, 0x03, 0xbf, 0xc0, 0x00, 0x00, 0x00, 0x00,
// 0x00, 0x00, 0x00, 0x00, 0xff, 0xe0, 0x00, 0x7d, 0xfe, 0x07, 0xbf, 0xc0, 0x00, 0x00, 0x00, 0x00,
// 0x00, 0x00, 0x00, 0x00, 0xff, 0xe0, 0x00, 0x7e, 0xff, 0x07, 0x7f, 0x80, 0x00, 0x00, 0x00, 0x00,
// 0x00, 0x00, 0x00, 0x00, 0xff, 0xe0, 0x00, 0x7e, 0xff, 0x0f, 0x7f, 0x80, 0x00, 0x00, 0x00, 0x00,
// 0x00, 0x00, 0x00, 0x00, 0xff, 0xe0, 0x00, 0x3f, 0x7f, 0x8f, 0xff, 0x00, 0x00, 0x00, 0x00, 0x00,
// 0x00, 0x00, 0x00, 0x00, 0xff, 0xf0, 0x00, 0x3f, 0x7f, 0x9f, 0xfe, 0x00, 0x00, 0x00, 0x00, 0x00,
// 0x00, 0x00, 0x00, 0x00, 0xff, 0xf0, 0x00, 0x3f, 0xff, 0xdf, 0xfe, 0x00, 0x00, 0x00, 0x00, 0x00,
// 0x00, 0x00, 0x00, 0x00, 0xff, 0xe0, 0x00, 0x3f, 0xff, 0xfe, 0xfc, 0x00, 0x00, 0x00, 0x00, 0x00,
// 0x00, 0x00, 0x00, 0x00, 0xff, 0xf0, 0x00, 0x3f, 0xbf, 0xff, 0xfc, 0x00, 0x00, 0x00, 0x00, 0x00,
// 0x00, 0x00, 0x00, 0x00, 0xff, 0xf0, 0x00, 0x7f, 0xff, 0xfd, 0xf8, 0x00, 0x00, 0x00, 0x00, 0x00,
// 0x00, 0x00, 0x00, 0x00, 0xff, 0xf0, 0x00, 0x7f, 0xdf, 0xfd, 0xf8, 0x00, 0x00, 0x00, 0x00, 0x00,
// 0x00, 0x00, 0x00, 0x00, 0xff, 0xf0, 0x00, 0xff, 0xdf, 0xfd, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00,
// 0x00, 0x00, 0x00, 0x00, 0xff, 0xf0, 0x01, 0xff, 0xef, 0xfb, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00,
// 0x00, 0x00, 0x00, 0x00, 0xff, 0xf0, 0x07, 0xff, 0xef, 0xfb, 0xe0, 0x00, 0x00, 0x00, 0x00, 0x00,
// 0x00, 0x00, 0x00, 0x00, 0xff, 0xff, 0xff, 0xff, 0xef, 0xfb, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00,
// 0x00, 0x00, 0x00, 0x00, 0xff, 0xff, 0xff, 0xff, 0xf7, 0xfb, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00,
// 0x00, 0x00, 0x00, 0x00, 0xff, 0xff, 0xff, 0xff, 0xf7, 0xfb, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00,
// 0x00, 0x00, 0x00, 0x00, 0xff, 0xff, 0xff, 0xff, 0xfb, 0x9d, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00,
// 0x00, 0x00, 0x00, 0x00, 0xff, 0xff, 0xff, 0xff, 0xfb, 0xfd, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00,
// 0x00, 0x00, 0x00, 0x00, 0xff, 0xff, 0xff, 0xff, 0xf9, 0xfe, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00,
// 0x00, 0x00, 0x00, 0x00, 0xff, 0xff, 0xff, 0xff, 0xb9, 0xfe, 0xe0, 0x00, 0x00, 0x00, 0x00, 0x00,
// 0x00, 0x00, 0x00, 0x00, 0xff, 0xff, 0xff, 0xfe, 0x7b, 0xff, 0xe0, 0x00, 0x00, 0x00, 0x00, 0x00,
// 0x00, 0x00, 0x00, 0x00, 0xff, 0xff, 0xff, 0xfc, 0x7b, 0xff, 0x70, 0x00, 0x00, 0x00, 0x00, 0x00,
// 0x00, 0x00, 0x00, 0x00, 0xff, 0xff, 0xff, 0xe0, 0xfb, 0xff, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00,
// 0x00, 0x00, 0x00, 0x00, 0xff, 0xf0, 0x00, 0x00, 0xff, 0xff, 0xf8, 0x00, 0x00, 0x00, 0x00, 0x00,
// 0x00, 0x00, 0x00, 0x00, 0xff, 0xf0, 0x00, 0x01, 0xf7, 0xff, 0xfc, 0x00, 0x00, 0x00, 0x00, 0x00,
// 0x00, 0x00, 0x00, 0x00, 0xff, 0xf0, 0x00, 0x03, 0xf7, 0xff, 0xfc, 0x00, 0x00, 0x00, 0x00, 0x00,
// 0x00, 0x00, 0x00, 0x00, 0xff, 0xf0, 0x00, 0x03, 0xf7, 0xff, 0xfe, 0x00, 0x00, 0x00, 0x00, 0x00,
// 0x00, 0x00, 0x00, 0x00, 0xff, 0xf0, 0x00, 0x07, 0xff, 0x9f, 0xfe, 0x00, 0x00, 0x00, 0x00, 0x00,
// 0x00, 0x00, 0x00, 0x00, 0xff, 0xf0, 0x00, 0x07, 0xff, 0x9f, 0xff, 0x00, 0x00, 0x00, 0x00, 0x00,
// 0x00, 0x00, 0x00, 0x00, 0xff, 0xf0, 0x00, 0x0f, 0xff, 0x0f, 0xff, 0x00, 0x00, 0x00, 0x00, 0x00,
// 0x00, 0x00, 0x00, 0x00, 0xff, 0xf0, 0x00, 0x1f, 0xff, 0x0f, 0xf7, 0x80, 0x00, 0x00, 0x00, 0x00,
// 0x00, 0x00, 0x00, 0x00, 0xff, 0xf0, 0x00, 0x1f, 0xfe, 0x07, 0xff, 0xc0, 0x00, 0x00, 0x00, 0x00,
// 0x00, 0x00, 0x00, 0x00, 0xff, 0xf0, 0x00, 0x3f, 0xfe, 0x07, 0xfb, 0xc0, 0x00, 0x00, 0x00, 0x00,
// 0x00, 0x00, 0x00, 0x00, 0xff, 0xf0, 0x00, 0x3f, 0xfc, 0x03, 0xff, 0xe0, 0x00, 0x00, 0x00, 0x00,
// 0x00, 0x00, 0x00, 0x00, 0xff, 0xf0, 0x00, 0x7f, 0xfc, 0x03, 0xfd, 0xe0, 0x00, 0x00, 0x00, 0x00,
// 0x00, 0x00, 0x00, 0x00, 0xff, 0xf0, 0x00, 0x7f, 0xf8, 0x01, 0xfc, 0x70, 0x00, 0x00, 0x00, 0x00,
// 0x00, 0x00, 0x00, 0x00, 0xff, 0xf0, 0x00, 0xff, 0xb8, 0x01, 0xfc, 0x70, 0x00, 0x00, 0x00, 0x00,
// 0x00, 0x00, 0x00, 0x00, 0xff, 0xf0, 0x01, 0xff, 0xb8, 0x00, 0xfe, 0xf8, 0x00, 0x00, 0x00, 0x00,
// 0x00, 0x00, 0x00, 0x00, 0xff, 0xf0, 0x01, 0xff, 0xf0, 0x00, 0xff, 0xfc, 0x00, 0x00, 0x00, 0x00,
// 0x00, 0x00, 0x00, 0x00, 0xff, 0xf0, 0x03, 0xff, 0x70, 0x00, 0x7f, 0xfc, 0x00, 0x00, 0x00, 0x00,
// 0x00, 0x00, 0x00, 0x00, 0xff, 0xf0, 0x03, 0xff, 0x60, 0x00, 0x7f, 0xfe, 0x00, 0x00, 0x00, 0x00,
// 0x00, 0x00, 0x00, 0x00, 0xff, 0xf0, 0x07, 0xff, 0x60, 0x00, 0x3f, 0xfe, 0x00, 0x00, 0x00, 0x00,
// 0x00, 0x00, 0x00, 0x00, 0xff, 0xf0, 0x0f, 0xff, 0xc0, 0x00, 0x3f, 0xff, 0x00, 0x00, 0x00, 0x00,
// 0x00, 0x00, 0x00, 0x00, 0xff, 0xf0, 0x0f, 0xff, 0xc0, 0x00, 0x1f, 0xff, 0x00, 0x00, 0x00, 0x00,
// 0x00, 0x00, 0x00, 0x00, 0xff, 0xf0, 0x1f, 0xff, 0x80, 0x00, 0x1f, 0xff, 0x80, 0x00, 0x00, 0x00,
// 0x00, 0x00, 0x00, 0x00, 0xff, 0xf0, 0x1f, 0xff, 0x80, 0x00, 0x0f, 0xff, 0xc0, 0x00, 0x00, 0x00,
// 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3f, 0xff, 0x00, 0x00, 0x0f, 0xff, 0xc0, 0x00, 0x00, 0x00,
// Constantes de réglage
#define POTENTIOMETER_MAX 940 // Valeur maximum du potentiometre
#define POTENTIOMETER_MIN 30 // Valeur minimum du potentiometre
#define SENSIBILITY_MAX 100 // Sensibilité maximum réglable
#define SENSIBILITY_MIN 3 // Sensibilité minimum réglable
#define HISTORY_DEPTH 16 // Profondeur de la matrice d'historique des valeurs (default 64)
#define VALUE_MAX 960 // Valeur maximum donnée par le phototransistor
#define DEBOUNCE_TIME 10 // Nb de millisecondes pour debouncer les boutons
#define TIMELAPSE_GAP 10 // Nb de minutes par défaut du timelapse
#define TIMELAPSE_MAX 1440 // Durée maximum du timelapse en minutes
// Config I/O
const int triggerPIN = 11; // Commande de l'optocoupleur pour le déclenchement
const int prefocusPIN = 12; // Commande de l'optocoupleur pour le focus
const int transistorPIN = A0; // Entrée analogique du phototransistor
const int potoPIN = A1; // Entrée analogique du potentiometre
* A4 - Ecran OLED
* A5 - Ecran OLED
const int greenLedPIN = 5; // Pin Led verte
const int redLedPIN = 4; // Pin Led rouge
const int buttonModePIN = 2; // Bouton Mode (PULL-DOWN)
const int buttonSetPIN = 3; // Bouton Set (PULL-DOWN)
// Variables globales
byte shutterMode = 0; // 0=Mode orage / 1=mode timelapse / 2=remote
byte detectionMode = 0; // 0=Mode variation / 1=mode moyenne / 2=mode fixe
bool displaySplash = true;
bool initFinished = false;
int potentiometerValue = 0;
int sensibility = 0;
float ratioScreen = 0.0;
byte i;
// Variables mode orage
float ratioSensibility = 0.0;
bool samplingPhase = true; // Mode initial d'échantillonnage avant de lancer la détection
float ratioGraph = 0.0;
float thresholdValue = 0.0;
int sensorValue = 0; // Dernière valeur lue
int prevSensorValue = 0; // Précédente valeur lue
int gap = 0;
int averageValue = 0;
int nbShot = 0;
int sampleRate = 0;
int sampleNb = 0;
unsigned long int lastRate = 0;
int valueHistory[HISTORY_DEPTH];
byte indexHistory = 0;
byte indexGraph = 0;
int graphMaxPlot = 28;
int plotWidth = 1;
int yThreshold = 0;
int barHeight = 0;
// Variables mode timelapse
float ratioTimelapse = 0.0;
int timelapseGap = TIMELAPSE_GAP;
bool timelapseWIP = false;
unsigned long int lastShot = 0;
// Variables hors registres pour les interruptions
volatile boolean buttonModeWIP = false;
volatile boolean buttonSetWIP = false;
// DĂ©claration fonctions
void displayOLEDSplash();
void triggerShot();
bool readModeButton();
bool readSetButton();
void modeLightning();
void modeTimelapse();
void modeRemote();
void modeButtonISR(); // Interrupt Service Routine on button Mode
void setButtonISR(); // Interrupt Service Routine on button Set
// Initialisation
// Ouverture communication avec le PC pour debug
Serial.println("");
// Calcul ratios
ratioScreen = (float)128/POTENTIOMETER_MAX;
ratioSensibility = (float)SENSIBILITY_MAX/POTENTIOMETER_MAX;
ratioTimelapse = (float)TIMELAPSE_MAX/POTENTIOMETER_MAX;
ratioGraph = (float)graphMaxPlot/VALUE_MAX;
plotWidth = 128/HISTORY_DEPTH;
Serial.print(F("* [System] Rapport sensibilite/ecran..."));
Serial.println(ratioScreen);
Serial.print(F("* [System] Rapport sensibilite/potentiometre..."));
Serial.println(ratioSensibility);
// Initialisation de la matrice de mesure
for ( i = 0 ; i < HISTORY_DEPTH ; i++ ){ valueHistory[i] = 0; }
// Hardware init
Serial.println(F("* [System] Parametrage des entrees/sorties..."));
pinMode(triggerPIN,OUTPUT);
pinMode(prefocusPIN,OUTPUT);
pinMode(redLedPIN,OUTPUT);
pinMode(greenLedPIN,OUTPUT);
pinMode(buttonModePIN,INPUT);
pinMode(buttonSetPIN,INPUT);
digitalWrite(triggerPIN,LOW);
digitalWrite(prefocusPIN,HIGH); // Activation permanente du focus
digitalWrite(redLedPIN,LOW);
digitalWrite(greenLedPIN,LOW);
// Interruptions
Serial.println(F("* [System] Liaison des fonctions ISR et interruptions..."));
attachInterrupt(digitalPinToInterrupt(buttonModePIN), modeButtonISR , RISING);
attachInterrupt(digitalPinToInterrupt(buttonSetPIN) , setButtonISR , RISING);
// Initialisation Ecran OLED
Serial.println(F("* [I2C] Initialisation ecran OLED...0x3C"));
display.begin(SSD1306_SWITCHCAPVCC, 0x3C); // Initialise avec l'adresse I2C 0x3D (Pour le 128x64)
// Affichage du splash screen pour connaitre la version du software installé
Serial.println(F("* [System] Affichage du Splash Screen..."));
display.setTextColor(WHITE);
// Test des leds
Serial.println(F("* [System] Test LEDs..."));
digitalWrite(redLedPIN,HIGH);
digitalWrite(greenLedPIN,HIGH);
initFinished = true;
Serial.println(F("* [System] ---------- Initialisation Terminee ------------"));
// Main Block
display.clearDisplay();
// Relevé des valeurs
sensorValue = analogRead(transistorPIN);
sampleNb++;
potentiometerValue = POTENTIOMETER_MAX - analogRead(potoPIN); // On soustrait car on veut une lecture inversée de la position du potar
if (readModeButton()){
shutterMode++;
if (shutterMode >= 3){shutterMode = 0;}
display.setTextSize(2);
display.setCursor(0,0); // 9 pixels pour un char (8) + son espace (1)
switch(shutterMode){
case 0:
display.println("Mode");
display.println(" Orage");
indexHistory = 0;
nbShot = 0;
case 1:
display.println(" TimeLapse");
case 2:
display.println(" Controle");
display.setTextSize(1);
display.display();
case 0:
modeLightning();
case 1:
modeTimelapse();
case 2:
modeRemote();
display.display();
// Fonctions
// Gestion du mode orage
void modeLightning(){
// Gestion du mode de detection
if (readSetButton()){
detectionMode++;
if (detectionMode >= 3){detectionMode = 0;}
// Taille du graph en fonction du mode
if (samplingPhase){graphMaxPlot = 40;;}
else{
switch(detectionMode){
case 0: graphMaxPlot = 28; break;
case 1: graphMaxPlot = 28; break;
case 2: graphMaxPlot = 40; break;
// Calcul du taux de mesures
if (millis() - lastRate > 1000){
sampleRate = sampleNb;
sampleNb = 0;
lastRate = millis();
// Decalage axe x du curseur du graph
indexGraph++;
if (indexGraph >= HISTORY_DEPTH) {indexGraph = 0;}
display.fillRect(indexGraph*plotWidth,10,1,graphMaxPlot,WHITE);
// Historique des mesures
valueHistory[indexHistory] = sensorValue;
indexHistory++;
if (indexHistory >= HISTORY_DEPTH) {
indexHistory = 0;
samplingPhase = false; // On a un tableau complet, on peut passer au mode détection
// Affichage du graph et Calcul moyenne des mesures
for (i = 0 ; i < HISTORY_DEPTH ; i++){
averageValue += valueHistory[i];
barHeight = (int)valueHistory[i]*ratioGraph;
// display.fillRect(i*2,10,2,barHeight,WHITE);
display.fillRect(i*plotWidth,(graphMaxPlot+10)-barHeight,plotWidth,barHeight,WHITE);
averageValue = averageValue / HISTORY_DEPTH;
// Calcul seuil de detection
sensibility = SENSIBILITY_MAX - (potentiometerValue * ratioSensibility);
// Saturation du phototransistor
if(sensorValue > VALUE_MAX) {digitalWrite(redLedPIN,1);} else {digitalWrite(redLedPIN,0);}
// Detection d'un dépassement de seuil
if (!samplingPhase){
// Mode variation
case 0:
gap = sensorValue - prevSensorValue;
if(gap > sensibility){triggerShot();}
// Mode moyenne
case 1:
// Affichage du seuil de déclenchement sur le graph
yThreshold = (graphMaxPlot+10)-((averageValue + sensibility)*ratioGraph);
display.drawFastHLine(0,yThreshold,128,WHITE);
// Detection du dépassement
if(sensorValue >= (averageValue + sensibility)){triggerShot();}
// Mode fixe
case 2:
thresholdValue = (float)sensibility / 100;
thresholdValue *= VALUE_MAX;
yThreshold = (graphMaxPlot + 10)-((int)thresholdValue*ratioGraph);
if(sensorValue >= (int)thresholdValue){triggerShot();}
////////////////////// MODE ECHANTILLONAGE //////////////////////
if (samplingPhase){
// Affichage valeur courante
display.print("Valeur capteur:");
display.println(sensorValue);
display.setCursor(0,52); // 9 pixels pour un char (8) + son espace (1)
display.println("Echantillonnage...");
////////////////////// MODE DETECTION //////////////////////
else {
// Affichage du nombre de déclenchements
display.print("nbS: ");
display.println(nbShot);
display.setCursor(50,0); // 9 pixels pour un char (8) + son espace (1)
display.print("e/s: ");
display.println(sampleRate);
// Affichage bargraph sensibilité
if (detectionMode == 0 || detectionMode == 1){
display.setCursor(0,40); // 9 pixels pour un char (8) + son espace (1)
display.println("Sensibilite:");
display.drawRect(0, 50, 127, 5, WHITE);
int bar_size = (potentiometerValue * ratioScreen);
display.fillRect(0, 50, bar_size, 5, WHITE);
if (detectionMode ==1){
// Affichage sensibilité moyenne
display.setCursor(0,56); // 9 pixels pour un char (8) + son espace (1)
display.print("Valeur moyenne: ");
display.println(averageValue);
prevSensorValue = sensorValue;
// Gestion du mode TimeLapse
void modeTimelapse(){
// Demarrage / Arret du timelapse
timelapseWIP = !timelapseWIP;
lastShot = 0;
if (timelapseWIP){
if (millis() - lastShot >= timelapseGap * 60000){
triggerShot();
lastShot = millis();
display.setCursor(80,10);
display.println( timelapseGap * 60 - (millis() - lastShot) * 1000 );
display.setCursor(50,50);
display.println(" ...");
// Calcul réglage du timelapse
timelapseGap = potentiometerValue * ratioTimelapse;
display.setCursor(50,10);
display.println(timelapseGap);
display.setCursor(40,50);
display.println(" (minutes)");
// Gestion du mode Remote
void modeRemote(){
if (readSetButton()){ triggerShot(); }
display.setCursor(0,28);
display.println(" Attente...");
// Affichage du Splash screen sur l'Ă©cran OLED
void displayOLEDSplash(){
// display.clearDisplay();
// display.drawBitmap(0, 0, logo_orionpx, 128, 64, WHITE);
// display.display();
// delay(2000);
display.println("Smart");
display.println(" Shutter");
display.println("");
display.print("Firmware: v");
display.println(SOFTWARE_VERSION);
display.print(SOFTWARE_AUTHOR);
display.display();
displaySplash = false;
delay(3000);
// DĂ©clenche la prise de vue
void triggerShot(){
digitalWrite(greenLedPIN,1);
digitalWrite(triggerPIN,HIGH);
display.setTextSize(3);
display.setCursor(0,20);
display.println(" SHOT !");
display.display();
delay(300);
digitalWrite(greenLedPIN,0);
nbShot++;
// Gère l'appui sur le bouton Mode
bool readModeButton(){
int buttonState;
static bool switchingPending = false;
static long int elapseTimer;
if (buttonModeWIP) {
buttonState = digitalRead(buttonModePIN);
if (buttonState == HIGH) {
switchingPending = true;
elapseTimer = millis();
if (switchingPending && buttonState == LOW) {
if (millis() - elapseTimer >= DEBOUNCE_TIME) {
return true;
return false;
bool readSetButton(){
int buttonState;
if (buttonSetWIP) {
buttonState = digitalRead(buttonSetPIN);
return true;
return false;
// Fonctions ISR
// Action sur le bouton Set
void setButtonISR(){
Serial.print(F("* [I/O] Appui detecte sur bouton Set...["));
Serial.print(digitalRead(buttonSetPIN));
Serial.print("] - ");
if (initFinished && !buttonSetWIP && digitalRead(buttonSetPIN) == HIGH){
buttonSetWIP = true;
Serial.println("WIP");
} else { Serial.println("NOK"); }
// Action sur le bouton Mode
void modeButtonISR(){
Serial.print(F("* [I/O] Appui detecte sur bouton Mode...["));
Serial.print(digitalRead(buttonModePIN));
if (initFinished && !buttonModeWIP && digitalRead(buttonModePIN) == HIGH){
buttonModeWIP = true;
