Memory Leak? Shift Register Testing
So I wrote the program:
Main:
#include "zShift.h"
int main()
	init();
	zshift.init();
	uint8_t dynByte;
	while(1)
		zshift.shift(dynByte);
		HDelay(3);
		dynByte++;
zShift.h:
#ifndef _ZSHIFT_h
#define _ZSHIFT_h
#if defined(ARDUINO) && ARDUINO >= 100
	#include "Arduino.h"
#else
	#include "WProgram.h"
#endif
* Software SPI Pin Settings
#define SPIPORT		PORTB
#define SPIPINPORT	PINB	//The Port that the Pins are on.
#define LatchPin	2	//_RCLK  Shift register clock pin
#define DataPin		3	//SER DS Serial data input
#define ClockPin	5
* Macros
#define LATCHMASK	(1 << LatchPin)        //_SRCLK SS Storage register clock pin
#define MOSIMASK	(1 << DataPin)         //BIT3//DataPin	//SER DS Serial data input
#define CLOCKMASK	(1 << ClockPin)        //ClockPin//_RCLK  Shift register clock pin
#define LATCH	(SPIPINPORT &=~ LATCHMASK)		//CLR(SPIPINPORT,LatchPin)
#define unLATCH	(SPIPINPORT |= LATCHMASK)	//SET(SPIPINPORT,LatchPin)
#define PULSE	{ tggl(SPIPINPORT,ClockPin); tggl(SPIPINPORT,ClockPin); }
#define tggl(port,bit) (port)^=(1<<(bit))
class zShiftClass
 private:
 public:
	void init();
	void shift( uint8_t value );
extern zShiftClass zshift;
#endif
zShift.cpp:
#include "zShift.h"
void zShiftClass::init()
	DDRB |= ( LATCHMASK | MOSIMASK | CLOCKMASK );
	SPIPINPORT &= ~( MOSIMASK | CLOCKMASK );
void zShiftClass::shift(uint8_t value)
	LATCH;
	for (uint8_t i = 0; i <= 7; i++)
		if( !!(value&(1<<i)) == true)	//If value is not a 1, turn off MOSIMASK
		{ SPIPORT |= MOSIMASK; }
		{ SPIPORT &= ~MOSIMASK; }
		PULSE;	//Pulse the Clock
	unLATCH;
zShiftClass zshift = zShiftClass();
After the program runs through about 5 iterations it just locks up. The exact point it ends is the 5th iteration at a byte value of 13. Is there a memory leak? Why is it doing this?
Figured it out.
Changing this:
To This:
define SPIPINPORT PORTB
Fixed it. Now I just have it:
