Memory leak w/ no Strings involved
I'm trying to read data being transferred via Infrared from my smartmeter on my ESP8266 using the following sketch:
#include <ESP8266WiFi.h>
#include <ESP8266WebServer.h>
#include <ESP8266HTTPUpdateServer.h>
#include <Ticker.h>
#include <AsyncMqttClient.h>
#ifndef STASSID
#define STASSID "mySSID"
#define STAPSK  "myPassword"
#endif
#ifndef MQTT_HOST
#define MQTT_HOST IPAddress(192, 168, 0, 100)
#define MQTT_PORT 1883
#endif
#ifndef IR
#define SerialDebug Serial1
#define IR Serial
#endif
AsyncMqttClient mqttClient;
Ticker mqttReconnectTimer;
WiFiEventHandler wifiConnectHandler;
WiFiEventHandler wifiDisconnectHandler;
Ticker wifiReconnectTimer;
const char* host = "esp8266-webupdate";
const byte firstByte = 0x7E;
const byte lastByte = 0x7E;
uint8_t i;
ESP8266WebServer httpServer(80);
ESP8266HTTPUpdateServer httpUpdater;
void connectToWifi() {
  SerialDebug.println("Connecting to WiFi ...");
  WiFi.begin(STASSID, STAPSK);
void connectToMqtt() {
  SerialDebug.println("Connecting to MQTT ...");
  mqttClient.connect();
void onWifiConnect(const WiFiEventStationModeGotIP& event) {
  SerialDebug.println("Connected to Wi-Fi.");
  connectToMqtt();
void onWifiDisconnect(const WiFiEventStationModeDisconnected& event) {
  SerialDebug.println("Disconnected from Wi-Fi.");
  mqttReconnectTimer.detach();
  wifiReconnectTimer.once(2, connectToWifi);
void onMqttConnect(bool sessionPresent) {
  SerialDebug.println("Connected to MQTT.");
  SerialDebug.print("Session present: ");
  SerialDebug.println(sessionPresent);
void onMqttDisconnect(AsyncMqttClientDisconnectReason reason) {
  SerialDebug.println("Disconnected from MQTT.");
  if (WiFi.isConnected()) {
    mqttReconnectTimer.once(2, connectToMqtt);
void array_to_string(byte array[], unsigned int len, char buffer[]) {
  for (unsigned int i = 0; i < len; i++) {
    byte nib1 = (array[i] >> 4) & 0x0F;
    byte nib2 = (array[i] >> 0) & 0x0F;
    buffer[i*2+0] = nib1  < 0xA ? '0' + nib1  : 'A' + nib1  - 0xA;
    buffer[i*2+1] = nib2  < 0xA ? '0' + nib2  : 'A' + nib2  - 0xA;
  buffer[len*2] = '\0';
  SerialDebug.begin(115200);
  IR.begin(9600);
  SerialDebug.println();
  SerialDebug.println("Booting Sketch...");
  wifiConnectHandler = WiFi.onStationModeGotIP(onWifiConnect);
  wifiDisconnectHandler = WiFi.onStationModeDisconnected(onWifiDisconnect);
  mqttClient.onConnect(onMqttConnect);
  mqttClient.onDisconnect(onMqttDisconnect);
  mqttClient.setServer(MQTT_HOST, MQTT_PORT);
  connectToWifi();
  httpUpdater.setup(&httpServer);
  httpServer.begin();
  mqttClient.setWill("smartmeter/online", 0, true, "no");
  httpServer.handleClient();
  uint32_t timeout = 2000;
  int readCnt = 0;
  uint32_t start_time = millis();
  byte tempChar = 0;
  byte *readMessage;
  uint32_t messageLen = 0;
  while ((tempChar != 0x7E) && (millis() - start_time < timeout)) {
    if (IR.available()) {
      tempChar = IR.read();
  timeout = 1000;
  bool done = false;
  if (tempChar == firstByte) { // if first byte == 0x7E
    while ((millis() - start_time) < timeout && !done) {
        tempChar = IR.read(); // second byte must be 0xA0
        if(tempChar == 0xA0) {
              tempChar = IR.read(); // 3rd byte tells the legth of the message
              readMessage = new byte[tempChar+2];
              memset(readMessage, 0, tempChar+2);
              readMessage[0] = firstByte;
              readMessage[1] = 0xA0;
              readMessage[2] = tempChar;
              messageLen = ((uint32_t)(tempChar))+2;
              readCnt = 3;
              while ( readCnt < messageLen && ((millis() - start_time) < timeout)) { // minimum len 120 chars for 0x7E format
                  readMessage[readCnt] = IR.read();
                  readCnt++;
                  if(readCnt == tempChar+2 && readMessage[readCnt-1] != lastByte) { // correct len but last byte not 0x7E
                    done = true;
                    SerialDebug.printf("Wrong end byte found - %d\n", readMessage[readCnt-1]);
                  } else if(readCnt == tempChar+2) { // correct len and correct last byte
                    done = true;
                    char str[251] = "";
                    array_to_string(readMessage, readCnt, str);
                    mqttClient.publish("smartmeter/raw", 0, false, str);
  mqttClient.publish("smartmeter/online", 0, true, "yes");
  char heap[6] = "";
  itoa(ESP.getFreeHeap(), heap, 10);
  mqttClient.publish("smartmeter/freeHeap", 0, false, heap);
I'm getting the encoded HEX-data published on my MQTT Topic as desired, the outputs Length is 250 characters long (=125 Bytes) which is incorrect:
7ea07bcf000200231362b1e6e700db08534d536770075f626120000e32e62addedaede38e64c8c3173035a0a853851a28efc57f7fd76a9df59dbb152f796939328ff0f28df7f257d20b5cb2a458c4eb9188e2c1c251701c891244d859ed9c159714bb4451c090d9b1ed3bbb1fc89785ebafbf59ec4f9d540eb4c90d47e
As I found out, the ESP's heap is decreasing by 100-300 by each iteration of the loop (data is being transmitted every second via Infrared from the power-grid Smartmeter) until the ESP will eventually be rebooted by the watchdog after like 5-8 minutes.
I explicitly did not use String variables in the sketch but I legit cannot find the reason for the memory leak. Tried turning off wifi, webserver and mqtt one after each other which didn't actually made a difference.
The heap-size stays at a constant level though when there is no data being received via the Infrared serial port, so I imagine something is fishy when storing the data in the byte array "readMessage".
Anything obvious that immediately pops into someone's eye that I missed?
could one of the libraries being used have a leak?
Do you always destroy that dynamic memory?
As suggested by @DrDiettrich, the code is missing a delete[] readMessage; at the end of the if (IR.available()) { .. } block.
Yes, read on C++ new.
It is often sufficient when debugging something like this to simply allocate a buffer of sufficient length at compile time and then recycle it continuously. That, of course, is subject to design constraints, but in the end unless you're firing up multiple dynamic consumers, and need to manage memory accordingly, static memory allocation will likely take away a whole range of unpredictable error/crash sources.
Just one opinion, which was free, and possibly worth less than you paid for it.
C
If you insist in dynamic allocation, wrap the buffer in an object,
so you get destruction for free and only have to clean up in the destructor.
