Haai All
When using bitfields with union and struct with 12 bits there seems to be an issue. The problem only occurs with the M0 board. The following code works fine on a Uno.
#define define_Serial_Debug_Port Serial
typedef union {
struct {
// Byte 0 - 1
unsigned int Var12bit1 : 12;
// Byte 1 - 2
unsigned int Var12bit2 : 12;
// Byte 3 - 4
unsigned int Var12bit3 : 12;
// Byte 4 - 5
unsigned int Var12bit4 : 12;
// Byte 6
unsigned int MsgCounter : 4;
unsigned intnibble_dummy : 4;
// Byte 7
unsigned int ChckSum : 8;
uint8_t Array[8];
} struct_Var8bytes;
struct_Var8bytes variable_Var8Bytes;
void function_ShowMem ( void )
variable_Var8Bytes.ChckSum =
variable_Var8Bytes.Array[0] +
variable_Var8Bytes.Array[1] +
variable_Var8Bytes.Array[2] +
variable_Var8Bytes.Array[3] +
variable_Var8Bytes.Array[4] +
variable_Var8Bytes.Array[5] +
variable_Var8Bytes.Array[6]
define_Serial_Debug_Port.print ( variable_Var8Bytes.Array[0], HEX );
define_Serial_Debug_Port.print ( "," );
define_Serial_Debug_Port.print ( variable_Var8Bytes.Array[1], HEX );
define_Serial_Debug_Port.print ( variable_Var8Bytes.Array[2], HEX );
define_Serial_Debug_Port.print ( variable_Var8Bytes.Array[3], HEX );
define_Serial_Debug_Port.print ( variable_Var8Bytes.Array[4], HEX );
define_Serial_Debug_Port.print ( variable_Var8Bytes.Array[5], HEX );
define_Serial_Debug_Port.print ( variable_Var8Bytes.Array[6], HEX );
define_Serial_Debug_Port.print ( variable_Var8Bytes.Array[7], HEX );
define_Serial_Debug_Port.print ( " ---- " );
define_Serial_Debug_Port.print ( variable_Var8Bytes.Var12bit1, HEX );
define_Serial_Debug_Port.print ( variable_Var8Bytes.Var12bit2, HEX );
define_Serial_Debug_Port.print ( variable_Var8Bytes.Var12bit3, HEX );
define_Serial_Debug_Port.print ( variable_Var8Bytes.Var12bit4, HEX );
define_Serial_Debug_Port.print ( variable_Var8Bytes.MsgCounter, HEX );
define_Serial_Debug_Port.print ( variable_Var8Bytes.ChckSum, HEX );
define_Serial_Debug_Port.print ( " - EOM" );
define_Serial_Debug_Port.println ( );
Serial.begin ( 115200 );
define_Serial_Debug_Port.println ( "Start run" );
variable_Var8Bytes.Var12bit1 = 0x1;
variable_Var8Bytes.Var12bit2 = 0x2;
variable_Var8Bytes.Var12bit3 = 0x3;
variable_Var8Bytes.Var12bit4 = 0x4;
function_ShowMem();
variable_Var8Bytes.Var12bit1 = 0x0ff;
variable_Var8Bytes.Var12bit2 = 0x1ff;
variable_Var8Bytes.Var12bit3 = 0x2ff;
variable_Var8Bytes.Var12bit4 = 0x3ff;
function_ShowMem();
variable_Var8Bytes.MsgCounter++;
delay ( 500 );
The screen output shows this.
Terminal Output M0:
Start run
1,20,0,0,3,40,0,0 ---- 1,2,3,4,0,64 - EOM
FF,F0,1F,0,FF,F2,3F,0 ---- FF,1FF,2FF,3FF,0,3E - EOM
1,20,0,0,3,40,0,1 ---- 1,2,3,4,1,64 - EOM
FF,F0,1F,0,FF,F2,3F,1 ---- FF,1FF,2FF,3FF,1,3E - EOM
Byte number #3 contains an extra 0x00!!
Running the same code on an Arduino Uno Shows the correct order, and no extra 0x00 byte.
Terminal Output Uno:
Start run
1,20,0,3,40,0,0,64 ---- 1,2,3,4,0,64 - EOM
FF,F0,1F,FF,F2,3F,0,3E ---- FF,1FF,2FF,3FF,0,3E - EOM
1,20,0,3,40,0,1,65 ---- 1,2,3,4,1,65 - EOM
FF,F0,1F,FF,F2,3F,1,3F ---- FF,1FF,2FF,3FF,1,3F - EOM
Changing the order of the struct/union shows its correctly??!!!
Code:
typedef union {
struct {
// Byte 0
// Byte 1 - 2
// Byte 2 - 3
// Byte 4 - 5
// Byte 5 - 6
// Byte 7
uint8_t Array[8];
} struct_Var8bytes;
function_ShowMem();
function_ShowMem();
delay ( 500 );
Terminal Output M0:
Start run
0,1,20,0,3,40,0,64 ---- 1,2,3,4,0,64 - EOM
0,FF,F0,1F,FF,F2,3F,3E ---- FF,1FF,2FF,3FF,0,3E - EOM
1,1,20,0,3,40,0,65 ---- 1,2,3,4,1,65 - EOM
1,FF,F0,1F,FF,F2,3F,3F ---- FF,1FF,2FF,3FF,1,3F - EOM
Start run
Start run
Am I doing something wrong or like there is something wrong with the compiler for the M0 when using BITFIELDS > 8.
It would be nice to have an solution for this.
Thanks for reading.
