Hey.. Can someone let me know how this circuit works?
I can see how it works, but I can't explain it.
The (-) input is kept at a voltage above the middle with the 3k3 and 10k.
The (+) input is the middle between the output and the power (perhaps 5V or 12V).
The 'set' pulls the (+) input to ground, so the (-) input is higher, resulting in a low output and the led turns on. The low output keeps the (+) input in the middle, so that is still lower than the (-) input. The output stays low.
The 'reset' make the (-) input always lower than the (+) input, so the output goes high. If the output is high, the (+) input is always higher, so the output stays high.
Does this explanation make any sense ?
Throw it in to:
http://www.falstad.com/circuit/
I really dont understand what you said. I can understand how, but I need to know why this is used.
Should I download something from here.. I dont know where to input my ckt.
Circuit:
http://www.freeimagehosting.net/4iynj
-SaRaH-:
The "why" can be due to many factors. The person deciding how to build the circuit would evaluate all those and build the circuit a particular way. One of those factors might be, "that's the parts I have on hand". Or maybe it's a circuit to demonstrate the use of a particular component. We could speculate endlessly on this. Perhaps you could supply some context?
Clue: hysteresis
Context..errmm.. This was designed by Alan Tyger. and its called Flip-Flop Memory Op-amp.
The op-amp has a positive feed back and I know that it has something to do with hysteresis..I tried to understand, but just cant figure out how this works..
It's an RS latch (without a complementary output.) http://cs.fit.edu/~wds/classes/comp-org/Logic/sequential.pdf
I don't know who Alan Tyger is, but that circuit is as old as the hills.
It'd be better to use a dedicated comparator. A comparator can be made from an opamp, but a comparator (LM339) is better suited to the task.
oh.. Ok.. so the link which you gave me is similar to the circuit which i posted?
