the IDE displays the following at the end of the compile (two separate compiles)
Using library SPI at version 1.0 in folder: C:\Users\Willem\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\2.1.3\libraries\SPI
Using library LiquidCrystal_I2C-master at version 1.1.4 in folder: C:\Users\Willem\Documents\Arduino\libraries\LiquidCrystal_I2C-master
Using library Wire at version 1.0 in folder: C:\Users\Willem\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\2.1.3\libraries\Wire
"C:\\Users\\Willem\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-size" -A "C:\\Users\\Willem\\AppData\\Local\\Temp\\arduino-sketch-290FF54C0C4263285D3AA5E61335C346/1614_UNO_SPI.ino.elf"
Sketch uses 7226 bytes (22%) of program storage space. Maximum is 32768 bytes.
Global variables use 522 bytes (25%) of dynamic memory, leaving 1526 bytes for local variables. Maximum is 2048 bytes.
Compilation complete.
Using library Wire at version 2.0.6 in folder: C:\Users\Willem\AppData\Local\Arduino15\packages\megaTinyCore\hardware\megaavr\2.5.11\libraries\Wire
Using library EEPROM at version 2.1.3 in folder: C:\Users\Willem\AppData\Local\Arduino15\packages\megaTinyCore\hardware\megaavr\2.5.11\libraries\EEPROM
"C:\\Users\\Willem\\AppData\\Local\\Arduino15\\packages\\DxCore\\tools\\avr-gcc\\7.3.0-atmel3.6.1-azduino4b/bin/avr-size" -A "C:\\Users\\Willem\\AppData\\Local\\Temp\\arduino-sketch-384A7D8EC12911DB1150CD68BDF26096/Interrupt_1614.ino.elf"
Sketch uses 4768 bytes (29%) of program storage space. Maximum is 16384 bytes.
Global variables use 211 bytes (10%) of dynamic memory, leaving 1837 bytes for local variables. Maximum is 2048 bytes.
we get the following at the end of the same compiles
No memory usage information. Can we please have the previous memory usage information displayed again. (Or am I doing something funny?)
