memory
Hello team,
I am beginning with Arduino tools.
I would like to use the Arduino micro for a project. It uses an ATmega32u4 with a Flash Memory 32 KB of which 4 KB used by bootloader. So I am wondering about the program space . Please, is there any Arduino mini USB key I can use to increase the program space for my embedded software?
Thank you,
Aubin
As far as I know, code can only be executed from internal flash memory. For beginner-level projects you're probably not going to run out.
Just to back up BulletMagnet83 definitively:- No, this is not possible. If, as a beginner, you fill up the memory you are doing something very wrong.
Thanks a lot for your help :) It seems like I underestimated the 32 KB d├ędicated to program space.
