Can anyone help with the best way to convert the square wave signal to a dc voltage between 0v and 5v.
I've attached the datasheet for reference.
I'm trying to integrate this sensor into a old circuit that uses accelerometers that is like a voltage divider and sends the signal through a few op amps. When the sensor is flat it gives out a steady 2.5v moving it to either side will make the voltage either go up or down
