Menu and Sub-Menu Interferance. Rotary encoder glitch
The problem is when I enter the menu. When I scroll first it is fine. But when I press to enter the 'CODES' Sub menu nothing happens untill I scroll again??? Now I am stuck in that sub menu and can't get out. If anyone knows how to solve this I will be blessed. Also the motor is used for demontration so don't pay attention to that. And when you don't understand some code use translate some parts are written in dutch. (Maybe you also noticed but there are sub menu's in sub menu's)
// [VARIABLES] ---------------------------------------------------------------------------------------------------------------------------------------------------------
// [VARIABLES] Main Variables ---------------------------------------------------------------------------------------------------------------------------------------
#include <LiquidCrystal_I2C.h>  // Library I²C LCD
#include <RotaryEncoder.h>      // Library Rotary
#include <Keypad_I2C.h>         // Library I²C (PCF8759) Keypad
#include <Keypad.h>             // Library Keypad
#define I2CADDR 0x20            // I2C-adres van het toetsenbord
bool loggedIn = false;               // Variable voor het bepalen of u wel ben ingelogd of niet
LiquidCrystal_I2C lcd(0x27, 20, 4);  // Adres Liquid Crystal Display
// [VARIABLES] Motor Control --------------------------------------------------------------------------------------------------------------------------------------------
const int motorPin1 = 2;   // Motor control pin 1
const int motorPin2 = 13;  // Motor control pin 2
bool rotation = 0;         // Sleutel voor het bepalen van richting
// [VARIABLES] Rotary Encoder ---------------------------------------------------------------------------------------------------------------------------------
int encoderPinA = 10;  // Pin voor de encoder
int encoderPinB = 11;  // Pin voor de encoder
int switchPin = 12;    // Pin voor de draairichting van de encoder
int savedCurrentPosition = 0;
RotaryEncoder encoder(encoderPinA, encoderPinB);  // Bepaling draairichting
// [VARIABLES] Keypad -----------------------------------------------------------------------------------------------------------------------------------------
const int ROW_NUM = 4;     // Variable aantal rijen Keypad
const int COLUMN_NUM = 3;  // Variable aantal kolommen Keypad
// Matrix van de layout van de Keypad
char keys[ROW_NUM][COLUMN_NUM] = {
  { '1', '2', '3' },
  { '4', '5', '6' },
  { '7', '8', '9' },
  { '*', '0', '#' }
byte rowPins[ROW_NUM] = { 5, 0, 1, 3 };   // Aansluiting op rijpinnen van het toetsenbord
byte colmsPin[COLUMN_NUM] = { 4, 6, 2 };  // Aansluiting op kolompinnen van het toetsenbord
Keypad_I2C customKeypad(makeKeymap(keys), rowPins, colmsPin, ROW_NUM, COLUMN_NUM, I2CADDR);  // Initialiseer een instantie van de Keypad_I2C-klasse
// [VARIABLES] Main menu -------------------------------------------------------------------------------------------------------------------------------------
// Opties om te kiezen in het Menu
const char *menuOptions[] = {
  "Codes",
  "Safe",
  "Users",
  "Logboek",
  "Optie 2",
  "Logout"
int mainMenuPosition = 0;                                      // Huidige positie in hoofdmenu
int previousMainMenuPosition = 0;                              // Vorige positie in hoofdmenu ter vergelijking
int mainMenuSwitchStatus = HIGH;                               // Status van schakelknop voor navigatie hoofdmenu
int previousMainMenuSwitchStatus = HIGH;                       // Vorige status van schakelknop
int currentPosition = 0;                                       // Huidige positie binnen zichtbare menuopties
int previousPosition = 0;                                      // Vorige positie ter vergelijking
int highPosition = 4;                                          // Hoogste index van zichtbare menuopties
int lowPosition = 1;                                           // Laagste index van zichtbare menuopties
int switchStatus;                                              // Huidige status van schakelknop van de Rotary encoder
int previousSwitchStatus = HIGH;                               // Vorige status van schakelknop van de Rotary encoder
int MENU_SIZE = sizeof(menuOptions) / sizeof(menuOptions[0]);  // Totaal aantal opties in hoofdmenu
// [VARIABLES] Codes And Codes Sub Menu ----------------------------------------------------------------------------------------------------------------------
const char *accessCodes[] = {
  "1234",
  "5678",
  "9876"
char enteredPIN[5];
const char *correctPIN = "1234";
const int NUM_CODES = sizeof(accessCodes) / sizeof(accessCodes[0]);
const char *CodesmenuOptions[] = {
  "Codes",
  "Change Code",
  "Go Back"
int submenuPosition = 0;
int previousSubmenuPosition = 0;
int submenuSwitchStatus = HIGH;
int previousSubmenuSwitchStatus = HIGH;
int CODES_MENU_SIZE = sizeof(CodesmenuOptions) / sizeof(CodesmenuOptions[0]);
int submenuSize = sizeof(CodesmenuOptions) / sizeof(CodesmenuOptions[0]);
bool inSubmenu = false;
// [SETUP] -----------------------------------------------------------------------------------------------------------------------------------------------
  lcd.init();
  lcd.clear();
  lcd.backlight();
  customKeypad.begin();  // Start het toetsenbord
  lcd.begin(20, 4);
  pinMode(switchPin, INPUT_PULLUP);
  pinMode(motorPin1, OUTPUT);
  pinMode(motorPin2, OUTPUT);
  displayLoginScreen();
// [LOOP] --------------------------------------------------------------------------------------------------------------------------------------------------------------
// [LOOP] Loginscreen ------------------------------------------------------------------------------------------------------------------------------------------
void displayLoginScreen() {
  lcd.clear();
  lcd.setCursor(0, 0);
  lcd.print("Enter PIN:");
// [LOOP] Update Menu ------------------------------------------------------------------------------------------------------------------------------------------
void updateMenu() {
  lcd.clear();
  int visibleItems = 3;
  int startIndex;
  if (currentPosition >= 2) {
    startIndex = currentPosition - 2;
    startIndex = 0;
  if (startIndex + visibleItems > MENU_SIZE) {
    startIndex = MENU_SIZE - visibleItems;
  lcd.print("Menu:");
  for (int i = 0; i < visibleItems; ++i) {
    lcd.setCursor(0, i + 1);
    int index = startIndex + i;
    if (index == currentPosition) {
      lcd.print(">");
      lcd.print(" ");
    lcd.print(menuOptions[index]);
// [LOOP] Update Sub Menu ---------------------------------------------------------------------------------------------------------------------------------------
void updateSubMenu() {
  lcd.clear();
  int startIndex;
  if (submenuPosition >= 2) {
    startIndex = submenuPosition - 2;
    startIndex = 0;
  if (startIndex + visibleItems > CODES_MENU_SIZE) {
    startIndex = CODES_MENU_SIZE - visibleItems;
  lcd.print("Codes Menu:");
    if (index == submenuPosition) {
      lcd.print(">");
      lcd.print(" ");
    lcd.print(CodesmenuOptions[index]);
// [LOOP] Codes ------------------------------------------------------------------------------------------------------------------------------------------------------------------------------
void CodesMenu() {
  int previousMainMenuPosition = currentPosition;  // Store the current position in the main menu
  updateSubMenu();
  while (true) {
    encoder.tick();
    int encoderDelta = encoder.getPosition() - previousSubmenuPosition;
    submenuSwitchStatus = digitalRead(switchPin);
    if (encoderDelta != 0 || submenuSwitchStatus == LOW && previousSubmenuSwitchStatus == HIGH) {
      submenuPosition += encoderDelta;
      if (submenuPosition < 0) {
      } else if (submenuPosition >= CODES_MENU_SIZE) {
        submenuPosition = CODES_MENU_SIZE - 1;
      lcd.clear();
      updateSubMenu();
    if (submenuSwitchStatus == LOW && previousSubmenuSwitchStatus == HIGH) {
      switch (submenuPosition) {
        case 0:
          // Handle Codes option
        case 1:
          // Handle Change Code option
        case 2:
          currentPosition = previousMainMenuPosition;  // Restore the previous position in the main menu
          updateMenu();  // Go back to the main menu
        default:
    previousSubmenuSwitchStatus = submenuSwitchStatus;
    previousSubmenuPosition = encoder.getPosition();
  savedCurrentPosition = currentPosition;
// [LOOP] Logout -----------------------------------------------------------------------------------------------------------------------------------------------------------------------------
void logout() {
  loggedIn = false;     // Set login status to false
  currentPosition = 0;  // Reset menu position
  lcd.clear();          // Clear LCD
  lcd.print("Logging Out ...");
  delay(1500);
  lcd.clear();
  displayLoginScreen();  // Display login screen
// [LOOP] Main Menu Selection Menu --------------------------------------------------------------------------------------------------------------------------------------------------------------------------
void performAction() {
  if (currentPosition == 0) {
    currentPosition = savedCurrentPosition;
  switch (currentPosition) {
    case 0:  // Codes option selected
      CodesMenu();  // Display codes submenu
    case 1:  // Kluis option selected
    case 2:  // Gebruikers option selected
    case 3:  // Optie 1 option selected
    case 4:  // Optie 2 option selected
    case 5:      // logout option selected
      logout();  // Logout
      digitalWrite(2, HIGH);
      digitalWrite(13, LOW);
      delay(3000);
      digitalWrite(2, LOW);
    default:
// [LOOP] Main Loop --------------------------------------------------------------------------------------------------------------------------------------------------------------------------------
  if (!loggedIn) {
    char customKey = customKeypad.getKey();
    static char enteredPIN[5] = { 0 };
    if (customKey != NO_KEY && strlen(enteredPIN) < 4) {
      lcd.setCursor(strlen(enteredPIN), 1);
      lcd.print('*');
      enteredPIN[strlen(enteredPIN)] = customKey;
      enteredPIN[strlen(enteredPIN) + 1] = '\0';
    if (strlen(enteredPIN) == 4) {
      if (strcmp(enteredPIN, "1234") == 0) {
        lcd.clear();
        lcd.print("PIN Correct");
        delay(2000);
        memset(enteredPIN, 0, sizeof(enteredPIN));
        loggedIn = true;
        rotation = 1;
        updateMenu();
        lcd.clear();
        lcd.print("PIN Incorrect");
        delay(2000);
  } else {  // If logged in, handle menu navigation
    if (loggedIn && rotation == 1) {
      digitalWrite(13, HIGH);
      delay(3000);
      rotation = 0;
    // Code voor het bewegen van de cursor in het Main Menu
    encoder.tick();
    int encoderDelta = encoder.getPosition() - previousPosition;
    switchStatus = digitalRead(switchPin);
    if (encoderDelta != 0) {
      currentPosition += encoderDelta;
      if (currentPosition < 0) {
      } else if (currentPosition >= MENU_SIZE) {
        currentPosition = MENU_SIZE - 1;
      lcd.clear();
      updateMenu();
    if (switchStatus == LOW && previousSwitchStatus == HIGH) {
      performAction();
    previousSwitchStatus = switchStatus;
    previousPosition = encoder.getPosition();
This codeversion prints to the serial monitor whenever the dgbc-used variables changed its value
This will help to understand what is going on in your code
// MACRO-START * MACRO-START * MACRO-START * MACRO-START * MACRO-START * MACRO-START *
// a detailed explanation how these macros work is given in this tutorial
// https://forum.arduino.cc/t/comfortable-serial-debug-output-short-to-write-fixed-text-name-and-content-of-any-variable-code-example/888298
#define dbg(myFixedText, variableName) \
  Serial.print( F(#myFixedText " "  #variableName"=") ); \
  Serial.println(variableName);
#define dbgi(myFixedText, variableName,timeInterval) \
    static unsigned long intervalStartTime; \
    if ( millis() - intervalStartTime >= timeInterval ){ \
      intervalStartTime = millis(); \
      Serial.println(variableName); \
#define dbgc(myFixedText, variableName) \
    static long lastState; \
    if ( lastState != variableName ){ \
      Serial.print( F(#myFixedText " "  #variableName" changed from ") ); \
      Serial.print(lastState); \
      Serial.print( F(" to ") ); \
      lastState = variableName; \
#define dbgcf(myFixedText, variableName) \
    static float lastState; \
// MACRO-END * MACRO-END * MACRO-END * MACRO-END * MACRO-END * MACRO-END * MACRO-END *
  { '1', '2', '3' },
  { '4', '5', '6' },
  { '7', '8', '9' },
  { '*', '0', '#' }
  "Codes",
  "Safe",
  "Users",
  "Logboek",
  "Optie 2",
  "Logout"
  "1234",
  "5678",
  "9876"
char enteredPIN[5];
  "Codes",
  "Change Code",
  "Go Back"
  lcd.init();
  lcd.clear();
  lcd.backlight();
  lcd.begin(20, 4);
  lcd.clear();
void updateMenu() {
  lcd.clear();
  int startIndex;
    startIndex = 0;
  lcd.print("Menu:");
      lcd.print(">");
      lcd.print(" ");
  lcd.clear();
  int startIndex;
    startIndex = 0;
      lcd.print(">");
      lcd.print(" ");
void CodesMenu() {
  updateSubMenu();
  while (true) {
    encoder.tick();
    dbgc("01", encoderDelta);
    dbgc("02", submenuSwitchStatus);
      dbgc("03", submenuPosition);
      dbgc("04", submenuPosition);
      lcd.clear();
      updateSubMenu();
    dbgc("05", submenuPosition);
        case 0:
        case 1:
        case 2:
          dbgc("06", currentPosition);
        default:
    dbgc("07", previousSubmenuSwitchStatus);
    dbgc("08", previousSubmenuPosition);
  dbgc("09", savedCurrentPosition);
void logout() {
  delay(1500);
  lcd.clear();
      logout();  // Logout
      delay(3000);
    default:
  if (!loggedIn) {
      lcd.print('*');
        lcd.clear();
        delay(2000);
        loggedIn = true;
        rotation = 1;
        updateMenu();
        lcd.clear();
        delay(2000);
      delay(3000);
      rotation = 0;
    encoder.tick();
      lcd.clear();
      updateMenu();
      performAction();
best regards Stefan
This pin " const int motorPin1 = 2; // Motor control pin 1
and this is same? byte colmsPin[COLUMN_NUM] = { 4, 6, 2 }; // Aansluiting op kolompinnen van het toetsenbord
If yes, this is a problem....
Are you using UNO...?]
That is the conformation for the pins for a pin extender PCF8574. The keypad is connected to that pin extender to reduce pins because we will also connect a RFID and a EEPROM. And we are using a NANO.
But thanks for the reply and for pointing this out we will change the commentary for this part.
Regards
