Menu bar above sketch missing
The menu bar above a sketch (File Edit Sketch Tools Help) is not there while running from the Arduino web. If I run arduino.exe from my local drive it is there. I looked at old posts on the topic but did not find a solution. I would appreciate any help.
Hi @sichaudhuri. This is normal and expected. Although Arduino Web Editor and Arduino IDE have a somewhat similar user interface, they are not intended to be identical. The menu bar UI paradigm standard in desktop applications is not common in web pages.
If there is something you are trying to achieve in Arduino Web Editor that makes you think the menu bar is needed, please provide a detailed description of that and we will help you out.
