menu lcd button?
I have a problem in making my assignments.
My difficulty in directing the cursor button up and down on the menu.
I ask for help, take a look at my button “up” and “down” in program and you see where my mistake? thanks
#include <LiquidCrystal.h>
LiquidCrystal lcd(7,6,5,4,3,2);
int keypad_pin = A0;
int keypad_value = 0;
int keypad_value_old = 0;
char btn_push;
byte mainMenuPage = 1;
byte mainMenuPageOld = 1;
byte mainMenuTotal = 3;
    lcd.begin(20,4);
    Serial.begin(9800);
    MainMenuDisplay();
    btn_push = ReadKeypad();
    MainMenuBtn();
    if(btn_push == 'S')//enter selected menu
        WaitBtnRelease();
        switch (mainMenuPage)
            case 1:
              MenuA();
            case 2:
              MenuB();
            case 3:
              MenuC();
          MainMenuDisplay();
          WaitBtnRelease();
void MenuA(){
    lcd.clear(); lcd.setCursor(0,0); lcd.print("Inside Menu A");
    while(ReadKeypad()!= 'L')
void MenuB(){
    lcd.clear(); lcd.setCursor(0,0); lcd.print("Inside Menu B");
void MenuC(){
    lcd.clear(); lcd.setCursor(0,0); lcd.print("Inside Menu C");
    while(ReadKeypad()!= 'L'){}}
void MainMenuDisplay()
    lcd.clear();
    lcd.setCursor(3,0);
    lcd.print("weather PORTABLE");
    lcd.setCursor(3,1);
    lcd.print("CHEK ");
    lcd.setCursor(3,2);
    lcd.print("open SD Card");
    lcd.setCursor(3,3);
    lcd.print("Open DATA LOGGER");
        case 1:
          lcd.setCursor(0,1);
          lcd.print("->");
        case 2:
          lcd.setCursor(0,2);
          lcd.print("->");
        case 3:
          lcd.setCursor(0,3);
          lcd.print("->");
void MainMenuBtn()
    WaitBtnRelease();
    if(btn_push == 'U')
        mainMenuPage++;
        if(mainMenuPage > mainMenuTotal)
          mainMenuPage = 1;
    else if(btn_push == 'D')
        mainMenuPage++;
        if(mainMenuPage < mainMenuTotal)
          mainMenuPage = 1;
    if(mainMenuPage != mainMenuPageOld) //only update display when page change
        MainMenuDisplay();
        mainMenuPageOld = mainMenuPage;
char ReadKeypad()
  keypad_value = analogRead(keypad_pin);
Serial.println(keypad_value);
  if(keypad_value > 540 && keypad_value < 590)
    return 'R';
  else if(keypad_value> 600 && keypad_value < 650)
    return 'U';
  else if(keypad_value >710 && keypad_value< 835)
    return 'D';
  else if(keypad_value >470 && keypad_value < 500)
    return 'L';
  else if(keypad_value>670 && keypad_value < 700)
    return 'S';
    return 'N';
void WaitBtnRelease()
    while( analogRead(keypad_pin)>670 && analogRead(keypad_pin) < 700) {}
