Hi.
I'm looking after a menu manager library for 1602L CD + Keypad with resistors arrays on a analog pin.
Would you have something to offer for a noob.
I've seen MenuBackend but I'm not able to understand and use it.
Hi.
Yes I have. Is not a library but is a small example:
//// D E L E T E D ////
I'm still working on it, but you can use it if you like it.
EDIT: Maybe a thing a little more simple. Based on an earlier version of the code posted before, I create this little menu example:
#include <LiquidCrystal.h>
// select the pins used on the LCD panel
LiquidCrystal lcd(8, 9, 4, 5, 6, 7);
#define btnRIGHT 0
#define btnUP 1
#define btnDOWN 2
#define btnLEFT 3
#define btnSELECT 4
#define btnNONE 5
#define MAXMEN 5
char option_list[MAXMEN][10] = {
"OPTION 01",
"OPTION 02",
"OPTION 03",
"OPTION 04",
"OPTION 05" };
int opt1;
// read the buttons
int read_LCD_buttons() {
int adc_key_in = 0;
int adc_key_deb = 0;
adc_key_in = analogRead(0);
delay(50);
adc_key_deb = analogRead(0);
if (adc_key_in > 1000 || adc_key_in - adc_key_deb > 10) return btnNONE;
if (adc_key_in < 50) return btnRIGHT;
if (adc_key_in < 195) return btnUP;
if (adc_key_in < 380) return btnDOWN;
if (adc_key_in < 555) return btnLEFT;
if (adc_key_in < 790) return btnSELECT;
return btnNONE;
int menu1 (void) {
int opt = 0;
int current_key;
int last_key=btnSELECT;
int exit = 0;
do {
lcd.setCursor(0,1);
lcd.print(option_list[opt]);
current_key = read_LCD_buttons();
if (current_key != last_key) {
last_key = current_key;
switch (current_key) {
case btnRIGHT:
case btnUP:
if (--opt < 0) {
opt = 0;
case btnDOWN:
if (++opt >= MAXMEN) {
opt = MAXMEN-1;
case btnLEFT:
case btnSELECT:
exit = 1;
case btnNONE:
}while (!exit);
return opt;
lcd.begin(16, 2); // start the library
opt1 = menu1();
lcd.setCursor(13,0);
lcd.print("[ ]");
lcd.setCursor(14,0);
lcd.print(opt1+1);
Tell me what you think about it.
