menu system behaving erratic.
Hi, Having a problem with my homebrewed menu system.
I used freetronics lcd sample code as starting point. up and down buttons are supposed to flick through the screens but sometimes i get gibberish or two lines of key commands instead on 1 label and 1 key comand line and occasionly a proper screen. It will eventually be menu for my trigger box code rebuild. keys are analog - off-board copy of the lcd’s onboard button system (as onboard buttons were too small)
  Example code for the Freetronics LCD & Keypad Shield:
    http://www.freetronics.com/products/lcd-keypad-shield
  by Marc Alexander, 7 September 2011
  This example code is in the public domain.
  Includes
#include <Wire.h>
#include <LiquidCrystal.h>   // include LCD library
  Defines
// Pins in use
#define BUTTON_ADC_PIN           A0  // A0 is the button ADC input
#define LCD_BACKLIGHT_PIN         3  // D3 controls LCD backlight
// ADC readings expected for the 5 buttons on the ADC input
#define RIGHT_10BIT_ADC           0  // right
#define UP_10BIT_ADC            145  // up
#define DOWN_10BIT_ADC          329  // down
#define LEFT_10BIT_ADC          505  // left
#define SELECT_10BIT_ADC        741  // right
#define BUTTONHYSTERESIS         10  // hysteresis for valid button sensing window
//return values for ReadButtons()
#define BUTTON_NONE               0  //
#define BUTTON_RIGHT              1  //
#define BUTTON_UP                 2  //
#define BUTTON_DOWN               3  //
#define BUTTON_LEFT               4  //
#define BUTTON_SELECT             5  //
//some example macros with friendly labels for LCD backlight/pin control, tested and can be swapped into the example code as you like
#define LCD_BACKLIGHT_OFF()     digitalWrite( LCD_BACKLIGHT_PIN, LOW )
#define LCD_BACKLIGHT_ON()      digitalWrite( LCD_BACKLIGHT_PIN, HIGH )
#define LCD_BACKLIGHT(state)    { if( state ){digitalWrite( LCD_BACKLIGHT_PIN, HIGH );}else{digitalWrite( LCD_BACKLIGHT_PIN, LOW );} }
  Variables
byte buttonJustPressed  = false;         //this will be true after a ReadButtons() call if triggered
byte buttonJustReleased = false;         //this will be true after a ReadButtons() call if triggered
byte buttonWas          = BUTTON_NONE;   //used by ReadButtons() for detection of button events
  Init the LCD library with the LCD pins to be used
LiquidCrystal lcd( 8, 9, 4, 5, 6, 7 );   //Pins for the freetronics 16x2 LCD shield. LCD: ( RS, E, LCD-D4, LCD-D5, LCD-D6, LCD-D7 )
  setup()
  Called by the Arduino framework once, before the main loop begins
   //button adc input
   pinMode( BUTTON_ADC_PIN, INPUT );         //ensure A0 is an input
   digitalWrite( BUTTON_ADC_PIN, LOW );      //ensure pullup is off on A0
   //lcd backlight control
   digitalWrite( LCD_BACKLIGHT_PIN, HIGH );  //backlight control pin D3 is high (on)
   pinMode( LCD_BACKLIGHT_PIN, OUTPUT );     //D3 is an output
   //set up the LCD number of columns and rows:
   lcd.begin( 16, 2 );
   //Print some initial text to the LCD.
   lcd.setCursor( 0, 0 );   //top left
   //          1234567890123456
   lcd.print( "Freetronics 16x2" );
   lcd.setCursor( 0, 1 );   //bottom left
   //          1234567890123456
   lcd.print( "Btn:" );
  loop()
  Arduino main loop
   byte button;
   byte timestamp;
   //get the latest button pressed, also the buttonJustPressed, buttonJustReleased flags
   button = ReadButtons();
   //blank the demo text line if a new button is pressed or released, ready for a new label to be written
   if( buttonJustPressed || buttonJustReleased )
     lcd.setCursor( 4, 1 );
     lcd.print( "            " );
   //show text label for the button pressed
   switch( button )
      case BUTTON_NONE:
      case BUTTON_RIGHT:
         lcd.print( "RIGHT" );
      case BUTTON_UP:
         lcd.print( "UP" );
      case BUTTON_DOWN:
         lcd.print( "DOWN" );
      case BUTTON_LEFT:
        lcd.print( "LEFT" );
     case BUTTON_SELECT:
        lcd.print( "SELECT-FLASH" );
        //SELECT is a special case, it pulses the LCD backlight off and on for demo
        delay( 150 );
        digitalWrite( LCD_BACKLIGHT_PIN, HIGH );   //leave the backlight on at exit
        delay( 150 );
        /* an example of LCD backlight control via macros with nice labels
        LCD_BACKLIGHT_OFF();
        delay( 150 );
        LCD_BACKLIGHT_ON();   //leave the backlight on at exit
        delay( 150 );
        // an example of LCD backlight control via a macro with nice label, called with a value
        LCD_BACKLIGHT(false);
        delay( 150 );
        LCD_BACKLIGHT(true);   //leave the backlight on at exit
        delay( 150 );
      default:
   // print the number of seconds since reset (two digits only)
   timestamp = ( (millis() / 1000) % 100 );   //"% 100" is the remainder of a divide-by-100, which keeps the value as 0-99 even as the result goes over 100
   lcd.setCursor( 14, 1 );
   if( timestamp <= 9 )
      lcd.print( " " );   //quick trick to right-justify this 2 digit value when it's a single digit
   lcd.print( timestamp, DEC );
   //debug/test display of the adc reading for the button input voltage pin.
   lcd.setCursor(12, 0);
   lcd.print( "    " );          //quick hack to blank over default left-justification from lcd.print()
   lcd.setCursor(12, 0);         //note the value will be flickering/faint on the LCD
   lcd.print( analogRead( BUTTON_ADC_PIN ) );
   //clear the buttonJustPressed or buttonJustReleased flags, they've already done their job now.
   if( buttonJustPressed )
   if( buttonJustReleased )
  ReadButtons()
  Detect the button pressed and return the value
  Uses global values buttonWas, buttonJustPressed, buttonJustReleased.
byte ReadButtons()
   unsigned int buttonVoltage;
   byte button = BUTTON_NONE;   // return no button pressed if the below checks don't write to btn
   //read the button ADC pin voltage
   buttonVoltage = analogRead( BUTTON_ADC_PIN );
   //sense if the voltage falls within valid voltage windows
   if( buttonVoltage < ( RIGHT_10BIT_ADC + BUTTONHYSTERESIS ) )
      button = BUTTON_RIGHT;
   else if(   buttonVoltage >= ( UP_10BIT_ADC - BUTTONHYSTERESIS )
           && buttonVoltage <= ( UP_10BIT_ADC + BUTTONHYSTERESIS ) )
      button = BUTTON_UP;
   else if(   buttonVoltage >= ( DOWN_10BIT_ADC - BUTTONHYSTERESIS )
           && buttonVoltage <= ( DOWN_10BIT_ADC + BUTTONHYSTERESIS ) )
      button = BUTTON_DOWN;
   else if(   buttonVoltage >= ( LEFT_10BIT_ADC - BUTTONHYSTERESIS )
           && buttonVoltage <= ( LEFT_10BIT_ADC + BUTTONHYSTERESIS ) )
      button = BUTTON_LEFT;
   else if(   buttonVoltage >= ( SELECT_10BIT_ADC - BUTTONHYSTERESIS )
           && buttonVoltage <= ( SELECT_10BIT_ADC + BUTTONHYSTERESIS ) )
      button = BUTTON_SELECT;
   //handle button flags for just pressed and just released events
   if( ( buttonWas == BUTTON_NONE ) && ( button != BUTTON_NONE ) )
      //the button was just pressed, set buttonJustPressed, this can optionally be used to trigger a once-off action for a button press event
      //it's the duty of the receiver to clear these flags if it wants to detect a new button change event
      buttonJustPressed  = true;
   if( ( buttonWas != BUTTON_NONE ) && ( button == BUTTON_NONE ) )
      buttonJustReleased = true;
   //save the latest button value, for change event detection next time round
   buttonWas = button;
   return( button );
have a look here: http://liudr.wordpress.com/libraries/phi_prompt/ Why reinvent the wheel?
It looks like his system relies on buttons as digital inputs. For my project, the only digital inputs spare are analog pins, which I want to leave spare in case I need to increase the relay bank above 4 relays. The freetronics LCD I have used a voltage ladder arraingement to have 5 buttons on one analog pin (A0). as their buttons are physically too small and on the pcb, I have replicated their system with buttons mounted on my case and resisters on the prototype part of a terminal shield. I am also not using digital pin13 as that pin drives the onboard led which lights up when rebooted (and would thus trigger a flash unit) if used.
So I have basicly tried to replicate the style used on the laser printers at work which also only have a 16x2 or similar lcd. I can't understand how it's glitching unless its the buttons themselves causing multiple presses, but that wouldn't explain why sometimes I would have both lines showing the key commands.
I currently have a working system that is left button is for opt1, right for opt2, up for opt3... that works with no graphical glitches but limits me to 4 options per menu level and limited character space to list each on the 16x2 lcd. Given all the various hardware for this project has cost about NZ$150 so far, I don't want to go out and buy a bigger lcd panel for this project.
