Menu that automatically exit after a while
As I make the menu will automatically exit after a while, that is if the user leaves. Like ATMs.
Let me give an example of basic menu, it is because I want to implement in my project
#include <Keypad.h>
#include <LiquidCrystal.h>
LiquidCrystal lcd(13, 12, 11, 10, 9, 8);
//Definición de filas y columnas
const byte Filas = 4; //Cuatro filas
const byte Cols = 4; //Cuatro columnas
//Definición de los pines
byte Pins_Filas[] = {3, 2, 1, 0}; //Pines Arduino para las filas
byte Pins_Cols[] =  {4, 5, 6, 7}; // Pines Arduino para las columnas
//Definición de las teclas
char Teclas [ Filas ][ Cols ] =
  {'1', '2', '3', 'A'},
  {'4', '5', '6', 'B'},
  {'7', '8', '9', 'C'},
  {'*', '0', '#', 'D'}
Keypad kpd = Keypad(makeKeymap(Teclas), Pins_Filas, Pins_Cols, Filas, Cols);
char Teclado ()
  do {
    char Tecla = kpd.getKey();
    if (Tecla != NO_KEY)
      return Tecla;
  } while (1);
 lcd.begin(20, 4); //Configura el LCD con el numero de columas y filas. Para un LCD 16x4: 16 columnas y 4 filas.
 lcd.display(); //Enciende el display
 lcd.setCursor(0, 0); lcd.print("home"); //Imprime en la lcd
  if (Tecla == '*') {
     Menu();
void Menu(){
     lcd.clear();
     lcd.setCursor(0, 0); lcd.print("Menu 1"); //Imprime en la lcd
     lcd.setCursor(0, 1); lcd.print("Menu 2"); //Imprime en la lcd
     char kp = Teclado ();
      switch (kp) {
        case '1':
              lcd.clear();
              lcd.setCursor(0, 0); lcd.print("Submenu 1"); //Imprime en la lcd
              lcd.setCursor(0, 1); lcd.print("Submenu 2"); //Imprime en la lcd
              kp = Teclado ();
              switch (kp) {
                case '1':
                  lcd.clear();
                  delay(100);
                  lcd.clear();
                case '2':
                        lcd.clear();
                        lcd.setCursor(0, 0); lcd.print("Submenu 2"); //Imprime en la lcd
                        delay(100);
                        lcd.clear();
        case '2':
              lcd.clear();
              lcd.setCursor(0, 0); lcd.print("Menu 2"); //Imprime en la lcd
              delay(100);
              lcd.clear();
Please help
(translate.google)
Save the millis() value when a menu is first shown, then each time through loop() compare the saved value with the current value of millis(). When the required interval has elapsed exit the menu.
UKHeliBob:
Kind of?
https://www.arduino.cc/en/Tutorial/BlinkWithoutDelay
(translate.google)
Yes, using the same principle
new99:
Exactly.
But reset the exit timer each time a user has pressed a button. Otherwise you will throw him out of the process regardless he is doing nothing or being active.
I am trying to do a condition that after 3 seconds out of the Menu or Submenu.
The user will have 3 seconds, if not push anything at that time is leaves and returns to the home.
#include <Keypad.h>
char Teclado ()
  do {
      return Tecla;
  } while (1);
  if (Tecla == '*') {
     Menu();
void Menu(){
     //If user does not push anything in 3 seconds, it returns to the home
     lcd.clear();
      switch (kp) {
        case '1':
              lcd.clear();
              kp = Teclado ();
              switch (kp) {
                case '1':
                  lcd.clear();
                  delay(100);
                  lcd.clear();
                case '2':
                        lcd.clear();
                        delay(100);
                        lcd.clear();
        case '2':
              lcd.clear();
              delay(100);
              lcd.clear();
The problem here is that millis () does not increase
unsigned long interval=1000; // the time we need to wait
unsigned long previousMillis=0; // millis() returns an unsigned long.
   home();
void home(){
  if (Tecla == '*') {
     Menu();
void Menu(){
if ((currentMillis - previousMillis) >= interval) {
   previousMillis = millis();
   home();
     lcd.clear();
      switch (kp) {
        case '1':
              lcd.clear();
              kp = Teclado ();
              switch (kp) {
                case '1':
                  lcd.clear();
                  delay(100);
                  lcd.clear();
                case '2':
                        lcd.clear();
                        delay(100);
                        lcd.clear();
        case '2':
              lcd.clear();
              delay(100);
              lcd.clear();
That would be the end of the Arduino as we know it were it true, so I don't think that is the problem somehow.
What makes you think that millis() is not increasing ?
UKHeliBob:
void Menu(){
   home();
     lcd.clear();
      switch (kp) {
        case '1':
              lcd.clear();
              kp = Teclado ();
              switch (kp) {
                case '1':
                  lcd.clear();
                  delay(100);
                  lcd.clear();
                case '2':
                        lcd.clear();
                        delay(100);
                        lcd.clear();
        case '2':
              lcd.clear();
              delay(100);
              lcd.clear();
Condition not be how we do it, because the programme is waiting waiting to click a button through switch
Sorry, but I can't make sense of that.
