Thre Problem is I can't seem to make the "if" commands turn the circles red when either button is pushed in the menu code.
#include <Adafruit_GFX.h> // Core graphics library
#include <Adafruit_TFTLCD.h> // Hardware-specific library
#include <SD.h>
#define SD_CS 5
#define LCD_RESET A4 // Can alternately just connect to Arduino's reset pin
#define BLACK 0x0000
#define BLUE 0x001F
#define RED 0xF800
#define GREEN 0x07E0
#define CYAN 0x07FF
#define MAGENTA 0xF81F
#define YELLOW 0xFFE0
#define WHITE 0xFFFF
Adafruit_TFTLCD tft;
int8_t saved_spimode;
void disableSPI(void) {
saved_spimode = SPCR;
SPCR = 0;
void enableSPI(void) {
SPCR = saved_spimode;
const int buttonPin = 2;
const int Index = A4;
const int Select = A5;
//int sensorPin = A4;
float Matchspeed = 0.0;
float rim = 2.170;
int cycles = 0;
unsigned long revtimer;
unsigned long revtimer2;
unsigned long serialTimer;
float Speed = 0;
float distance = 0;
unsigned long AvgTime2 = 0;
unsigned long AvgTime = 0;
unsigned long TempTime = 0;
int Avgspeed =0;
int cyclecount = 0;
float speeddif = 0;
float timedif = 0;
byte A = 10;
int B = 0;
File myFile1;
File myFile2;
File myFile3;
File myFile4;
int digit;
float totalavg = 0;
float timeavg = 0;
Serial.begin (9600);
pinMode (buttonPin, INPUT);
pinMode (Index, INPUT);
pinMode (Select, INPUT);
tft.reset();
uint16_t identifier = tft.readID();
tft.begin(identifier);
Serial.print("Initializing SD card...");
if (!SD.begin(SD_CS)) {
Serial.println("initialization failed!");
return;
Serial.println("initialization done.");
disableSPI();
Background();
serialTimer =millis();
void loop ()
if (digitalRead(Index) == HIGH){
menu ();
if (digitalRead(buttonPin) == HIGH){
cycles++;
while (digitalRead(buttonPin) == HIGH);
//while (digitalRead(buttonPin) == LOW);
delay (10);
Currentspeed ();
TimeCompareText();
sendstats();
Speedtext();
for (B=1; B<26000; B+=40){
//if (cycles == B+39)
//AvgspeedW();
//if (cycles == B+19)
//TimecompareW();
if (cycles == B)
AvgspeedR();
if (cycles == B+20)
TimeR();
//if (cycles == B+21)
//TimeCompareText();
unsigned long Background() {
tft.fillScreen(WHITE);
tft.fillRect (0, 60, 240, 5, BLACK);
tft.fillRect (0, 260, 240, 5, BLACK);
//tft.setCursor(160, 190);
//tft.setTextColor(BLACK); tft.setTextSize(2);
//tft.println("km/hr");
//tft.setCursor(160, 110);
void Currentspeed () {
serialTimer = millis();
revtimer = (serialTimer);
//Serial.print(revtimer);
//Serial.println (" revtimer");
Speed = ((rim * 3600)/(revtimer - revtimer2));
//Serial.print(Speed);
//Serial.println (" Speed");
revtimer2 = (serialTimer);
//Serial.print(revtimer2);
//Serial.println (" revtimer2");
void AvgspeedR() {
enableSPI();
char AvgSR[27];
sprintf(AvgSR, "/Read/Speed/speed%03d.txt", B+39);
totalavg = 0;
File myFile1 = SD.open(AvgSR);
while (true)
if (myFile1.available() == 0)
digit = myFile1.read();
if (digit == '\n' || digit == '\r')
totalavg = totalavg * 10 + (digit - '0');
Serial.println (totalavg);
myFile1.close();
disableSPI();
void TimeR() {
enableSPI();
char TimeSR[26];
sprintf(TimeSR, "/Read/Times/time%03d.txt", B+19);
timeavg = 0;
File myFile4 = SD.open(TimeSR);
while (true)
if (myFile4.available() == 0)
digit = myFile4.read();
timeavg = timeavg * 10 + (digit - '0');
Serial.println (timeavg);
myFile4.close();
disableSPI();
void AvgspeedW() {
enableSPI();
char fileName[28];
sprintf(fileName, "/Write/Speed/speed%03d.txt", B+39);
myFile2 = SD.open(fileName, FILE_WRITE);
if (myFile2) {
AvgTime2 = (serialTimer);
Avgspeed = (1800000*rim/(AvgTime2-TempTime));
TempTime = (serialTimer);
myFile2.println(Avgspeed);
myFile2.close();
Serial.println("done.");
disableSPI();
void TimecompareW() {
enableSPI();
char Times[27];
sprintf(Times, "/Write/Times/time%03d.txt", B+19);
myFile3 = SD.open(Times, FILE_WRITE);
if (myFile3) {
myFile3.println(serialTimer/100);
myFile3.close();
disableSPI();
void sendstats() {
// Serial.print (Speed);
// Serial.println (" km/hr");
// serialTimer = millis();
// Serial.print (serialTimer/1000);
// Serial.println (" s Ride Time");
// Serial.println (distance);
Serial.println (cycles);
// Serial.println (serialTimer);
Serial.println (" ");
unsigned long Speedtext() {
if (Speed < 10 || cycles == 1)
{A = (77);
else { A=(47);
if (Speed < ((totalavg/10)-2))
{ tft.setTextColor(RED);
tft.fillTriangle (120, 240, 50, 200, 190, 200, (RED));
tft.fillRect (95, 180, 50, 20, (RED)); // x,y , x distance, y distance
tft.fillRect (50, 80, 140, 60, WHITE);
else if (Speed > ((totalavg/10)+2))
{ tft.setTextColor(BLUE);
tft.fillTriangle (120, 80, 50, 120, 190, 120, (BLUE));
tft.fillRect (95, 120, 50, 20, (BLUE)); // x,y , x distance, y distance
tft.fillTriangle (115, 90, 112, 109, 121, 107, (YELLOW));
tft.fillTriangle (115, 90, 127, 87, 121, 107, (YELLOW));
tft.fillTriangle (122, 103, 134, 101, 110, 136, (YELLOW));
tft.fillRect (50, 180, 140, 60, WHITE);
else {
tft.setCursor(A, 142);
tft.setTextSize(5);
tft.fillRect (47, 142, 146, 40, WHITE);
tft.println(Speed);
unsigned long TimeCompareText() {
timedif = (((timeavg*100)-(serialTimer))/1000);
if (timedif < 10 && timedif > 0)
{A = (151);
else if (timedif > 10)
{ A=(133);
else if (timedif <= (0-10) && timedif > -100)
{ A=(115);
else if (timedif < (0-100))
{ A=(97);
else if (timedif > 100)
{ A=(115);
else {
A=(133);
if (timedif > 0) {
tft.setCursor(10, 25);
tft.setTextColor(BLUE); tft.setTextSize(2);
tft.fillRect (10, 25, 100, 30, WHITE);
tft.println("AHEAD");
else {
tft.setTextColor(RED); tft.setTextSize(2);
tft.println("BEHIND");
tft.setCursor(A, 20);
tft.setTextSize(3);
tft.fillRect (105, 18, 120, 30, WHITE);
tft.println(timedif);
void menu (){
delay (500);
tft.fillScreen(0x62EC);
tft.fillCircle(25, 25, 10, 0x57E0);
tft.fillCircle(25, 75, 10, 0x57E0);
tft.fillCircle(25, 125, 10, 0x57E0);
//if (cycles==4) {
tft.setCursor(50, 18);
tft.println("RIDE SETTINGS");
tft.setCursor(50, 68);
tft.println("testing A");
tft.setCursor(50, 118);
tft.println("testing B");
while ((digitalRead(Index) == HIGH)|| (digitalRead(Select) == HIGH) );
if (digitalRead(Index) == HIGH) {
tft.fillCircle(25, 25, 10, RED);
if (digitalRead(Select) == HIGH) {
tft.fillCircle(25, 75, 10, RED);
delay (5000);
Background();
return ;
