Hi
I am trying to use menu for selecting from list samples, case 1 to 5.
#include "LiquidCrystal.h"
LiquidCrystal lcd(PA0, PA1, PA2, PA3, PA4, PA5);
int SAMPLES;
byte buttons[] = {PB11, PB12, PB13};
const byte nrButtons = 3;
int menusize = 5;
String menu[] = {
"SAMPLES 66 ",
"SAMPLES 67 ",
"SAMPLES 68 ",
"SAMPLES 69 ",
"SAMPLES 70 ",
//List 1 to 5
#define SAMPLES 66 //1
#define SAMPLES 67 //2
#define SAMPLES 68 . //3
#define SAMPLES 69 //4
#define SAMPLES 70 //5
#define SAMPLES 88
#include <libmaple/dma.h>
dma_tube_config dma_cfg;
int flag1 = 0;
int out1 = PB7;
int val1[SAMPLES];
int amp = 50;
int cnt = 0;
int time_track = 0;
float stp = 6.2831 / SAMPLES;
//float stp = 7.8539/SAMPLES;
int ret = 17;
timer_dev *dev1 = PIN_MAP[out1].timer_device;
uint8 cc_channel1 = PIN_MAP[out1].timer_channel;
void fun()
flag1++;
void timer_conf()
timer_dma_set_base_addr(dev1, TIMER_DMA_BASE_CCR2);
timer_dma_set_burst_len(dev1, 1);
timer_dma_enable_req(dev1, cc_channel1);
timer_set_reload(dev1, 102);
timer_set_prescaler(dev1, 0);
void dma_conf()
dma_init(DMA1);
/* T4C2 DMA C4 */
dma_cfg.tube_dst = &(dev1->regs.gen->DMAR);
dma_cfg.tube_dst_size = DMA_SIZE_32BITS;
dma_cfg.tube_src = val1;
dma_cfg.tube_src_size = DMA_SIZE_32BITS;
dma_cfg.tube_nr_xfers = SAMPLES;
dma_cfg.tube_flags = DMA_CFG_SRC_INC | DMA_CFG_CIRC | DMA_CFG_CMPLT_IE;
dma_cfg.tube_req_src = DMA_REQ_SRC_TIM4_CH2;
dma_cfg.target_data = 0;
ret = dma_tube_cfg(DMA1, DMA_CH4, &dma_cfg);
void dma_start()
dma_attach_interrupt(DMA1, DMA_CH4, fun);
dma_enable(DMA1, DMA_CH4);
timer_resume(dev1);
dma_enable(DMA1, DMA_CH2);//
// timer_resume(dev2);
void init_wave()
int i;
for (i = 0; i < SAMPLES; i++)
val1[i] = 50 + amp * sin(stp * i);
lcd.begin(16, 2);
pinMode(out1, PWM);
pinMode(PB13, INPUT_PULLUP);
pinMode(PB12, INPUT_PULLUP);
timer_conf();
dma_conf();
dma_start();
init_wave();
lcd.setCursor(0, 1);
lcd.print("SAMPLES = ");
lcd.setCursor(4, 1);
lcd.print(SAMPLES);
delay(100);
So far I have this.
Looking for simple menu examples, all google examples are very long.
