error stray ' 303' in program
Did you cut and paste code from a browser window?
#define capPin A5
#define buz 9
#define pulsePin A4
#define led 10
long sumExpect = 0; // somme
cumulée de 64 sommes ignorées depuis longtemps = 0; // nombre de sommes ignorées
long diff = 0; // différence entre sum et avgsum
long pTime = 0;
long buzPeriod = 0;
void setup ()
Serial.begin (9600);
pinMode (pulsePin, OUTPUT);
digitalWrite (pulsePin, LOW);
pinMode (capPin, INPUT);
pinMode (buz, OUTPUT);
digitalWrite (buz, LOW);
pinMode (led, SORTIE);
boucle vide ()
int minval = 1023;
int maxval = 0;
long entier non signé = 0;
for (int i = 0; i <256; i ++)
// réinitialiser le condensateur
pinMode (capPin, OUTPUT);
digitalWrite (capPin, LOW);
delayMicroseconds (20);
applyPulses ();
// lire la charge du condensateur
int val = analogRead (capPin); // prend 13x8 = 104 microsecondes
minval = min (val, minval);
maxval = max (val, maxval);
somme + = val;
long unsigned int cTime = millis ();
char buzState = 0;
if (cTime <pTime + 10)
if (diff> 0)
buzState = 1;
sinon si (diff <0)
buzState = 2;
if (cTime> pTime + buzPeriod)
if (diff> 0)
buzState = 1;
sinon si (diff <0)
buzState = 2;
pTime = cTime;
if (buzPeriod> 300)
buzState = 0;
if (buzState == 0)
digitalWrite (led, LOW);
noTone (buz);
else if (buzState == 1)
tone (buz, 2000);
digitalWrite (led, HIGH);
else if (buzState == 2)
tone (buz, 500);
// soustrait les valeurs minimale et maximale pour supprimer les pics
sum- = minval;
sum- = maxval;
if (sumExpect == 0)
sumExpect = sum << 6; // définir sumExpect à la valeur attendue
long int avgsum = (sumExpect + 32) >> 6;
diff = somme-moyenne;
if (abs (diff) > 10)
sumExpect = sumExpect + sum-avgsum;
ignor = 0;
ignor ++;
if (ignor> 64)
ignor = 0;
if (diff == 0)
buzPeriod = 1000000;
sinon
buzPeriod = avgsum / (2 * abs (diff));
void applyPulses ()
for (int i = 0; i <3; i ++)
digitalWrite (pulsePin, HIGH); // prend 3,5 uS
delayMicroseconds (3);
digitalWrite (pulsePin, LOW); // prend 3,5 uS
You can not use "é" here...
There are other problems with it... white spaces are not allowed in a variable name.
Bonjour zsallam
zsallam:
Comme la question est en français :
Vous pouvez poster , en signalant que vous avez déjà posté sur le forum anglais , ici :
Français - Arduino Forum (le forum en français)
Avez-vous copié votre code directement d'un texte d'une page web ?
Dans ce cas , il est plein de caractères html (invisible à l'écran ou des espaces) qu'il faut supprimer à la main.
Pas moyen de télécharger le code ?
Cordialement,
bidouilleelec
Bonjour zsallam
Dans votre cas :
NE PAS TRADUIRE LA PAGE en français avant de copier le code.
En copiant le code de la page originale
( ici ? :PIC AVR & ARDUINO Programming | Metal Detector (Arduino based) )
ça compile.
Cordialement,
bidouilleelec
