MERGE SD Card Sketch into led sketch
I have been racking my brains for weeks trying to do this without successs, using uno on port D I have the following SD card sketch which works in a standalone state…
#include <SD.h>
#include <SPI.h>
int CS_PIN = 10;
File file;
  initializeSD();
  createFile("test.txt");
  writeToFile("This is sample Hello World");
  closeFile();
  openFile("test.txt");
  Serial.println(readLine());
  closeFile();
void initializeSD()
  Serial.println("Initializing SD card...");
  pinMode(CS_PIN, OUTPUT);
  if (SD.begin())
    Serial.println("SD card is ready to use.");
  } else
    Serial.println("SD card initialization failed");
    return;
int createFile(char filename[])
  file = SD.open(filename, FILE_WRITE);
  if (file)
    Serial.println("File created successfully.");
    return 1;
  } else
    Serial.println("Error while creating file.");
    return 0;
int writeToFile(char text[])
  if (file)
    file.println(text);
    Serial.println("Writing to file: ");
    Serial.println(text);
    return 1;
  } else
    Serial.println("Couldn't write to file");
    return 0;
void closeFile()
  if (file)
    file.close();
    Serial.println("File closed");
int openFile(char filename[])
  file = SD.open(filename);
  if (file)
    Serial.println("File opened with success!");
    return 1;
  } else
    Serial.println("Error opening file...");
    return 0;
String readLine()
  String received = "";
  char ch;
  while (file.available())
    ch = file.read();
    if (ch == '\n')
      return String(received);
      received += ch;
  return "";
I want to drop the above Sd sketch into the sketch below relocating the wording in the sketch below “HELLO WORLD” and " Sample Text" on lines 263 and 264 onto the sd card
#define PIXELS 96*4
#define PIXEL_PORT  PORTD
#define PIXEL_DDR   DDRD
static const uint8_t onBits=0b11111110;
#define T1H  814
#define T1L  438
#define T0H  312
#define T0L  936
#define RES 500000
#define NS_PER_SEC (1000000000L)          values of derivatives
#define CYCLES_PER_SEC (F_CPU)
#define NS_PER_CYCLE ( NS_PER_SEC / CYCLES_PER_SEC )
#define NS_TO_CYCLES(n) ( (n) / NS_PER_CYCLE )
static inline void sendBitx8(  const uint8_t row , const uint8_t colorbyte , const uint8_t onBits ) {
    asm volatile (
      "L_%=: \n\r"
      "out %[port], %[onBits] \n\t"
      "mov r0, %[bitwalker] \n\t"
      "and r0, %[colorbyte] \n\t"
      "breq OFF_%= \n\t"
      "nop \n\t  "
      "out %[port], %[row]   \n\t"
      "nop \n\t nop \n\t "
      "nop \n\t "
      "out %[port], __zero_reg__ \n\t"
      "ror %[bitwalker] \n\t"
      "brcs DONE_%= \n\t"
      "nop \n\t \n\t "
      "jmp L_%= \n\t"
      "OFF_%=: \n\r"
      "brcs DONE_%= \n\t"
      "nop \n\t "
      "jmp L_%= \n\t"
      "DONE_%=: \n\t"
      [port]    "I" (_SFR_IO_ADDR(PIXEL_PORT)),
      [row]   "d" (row),
      [onBits]   "d" (onBits),
      [colorbyte]   "d" (colorbyte ),
      [bitwalker] "r" (0x80)
void show() {
  delayMicroseconds( (RES / 1000UL) + 1);
static inline void sendRowRGB( uint8_t row ,  uint8_t r,  uint8_t g,  uint8_t b ) {
  sendBitx8( row , g , onBits);    // WS2812 takes colors in GRB order
  sendBitx8( row , r , onBits);    // WS2812 takes colors in GRB order
  sendBitx8( row , b , onBits);    // WS2812 takes colors in GRB order
#define FONT_WIDTH 5
#define INTERCHAR_SPACE 1
#define ASCII_OFFSET 0x20    // ASSCI code of 1st char in font array
const uint8_t Font5x7[] PROGMEM = {
0x00,0x00,0x00,0x00,0x00,//
0x00,0x00,0xfa,0x00,0x00,// !
0x00,0xe0,0x00,0xe0,0x00,// "
0x28,0xfe,0x28,0xfe,0x28,// #
0x24,0x54,0xfe,0x54,0x48,// $
0xc4,0xc8,0x10,0x26,0x46,// %
0x6c,0x92,0xaa,0x44,0x0a,// &
0x00,0xa0,0xc0,0x00,0x00,// '
0x00,0x38,0x44,0x82,0x00,// (
0x00,0x82,0x44,0x38,0x00,// )
0x10,0x54,0x38,0x54,0x10,// *
0x10,0x10,0x7c,0x10,0x10,// +
0x00,0x0a,0x0c,0x00,0x00,// ,
0x10,0x10,0x10,0x10,0x10,// -
0x00,0x06,0x06,0x00,0x00,// .
0x04,0x08,0x10,0x20,0x40,// /
0x7c,0x8a,0x92,0xa2,0x7c,// 0
0x00,0x42,0xfe,0x02,0x00,// 1
0x42,0x86,0x8a,0x92,0x62,// 2
0x84,0x82,0xa2,0xd2,0x8c,// 3
0x18,0x28,0x48,0xfe,0x08,// 4
0xe4,0xa2,0xa2,0xa2,0x9c,// 5
0x3c,0x52,0x92,0x92,0x0c,// 6
0x80,0x8e,0x90,0xa0,0xc0,// 7
0x6c,0x92,0x92,0x92,0x6c,// 8
0x60,0x92,0x92,0x94,0x78,// 9
0x00,0x6c,0x6c,0x00,0x00,// :
0x00,0x6a,0x6c,0x00,0x00,// ;
0x00,0x10,0x28,0x44,0x82,// <
0x28,0x28,0x28,0x28,0x28,// =
0x82,0x44,0x28,0x10,0x00,// >
0x40,0x80,0x8a,0x90,0x60,// ?
0x4c,0x92,0x9e,0x82,0x7c,// @
0x7e,0x88,0x88,0x88,0x7e,// A
0xfe,0x92,0x92,0x92,0x6c,// B
0x7c,0x82,0x82,0x82,0x44,// C
0xfe,0x82,0x82,0x44,0x38,// D
0xfe,0x92,0x92,0x92,0x82,// E
0xfe,0x90,0x90,0x80,0x80,// F
0x7c,0x82,0x82,0x8a,0x4c,// G
0xfe,0x10,0x10,0x10,0xfe,// H
0x00,0x82,0xfe,0x82,0x00,// I
0x04,0x02,0x82,0xfc,0x80,// J
0xfe,0x10,0x28,0x44,0x82,// K
0xfe,0x02,0x02,0x02,0x02,// L
0xfe,0x40,0x20,0x40,0xfe,// M
0xfe,0x20,0x10,0x08,0xfe,// N
0x7c,0x82,0x82,0x82,0x7c,// O
0xfe,0x90,0x90,0x90,0x60,// P
0x7c,0x82,0x8a,0x84,0x7a,// Q
0xfe,0x90,0x98,0x94,0x62,// R
0x62,0x92,0x92,0x92,0x8c,// S
0x80,0x80,0xfe,0x80,0x80,// T
0xfc,0x02,0x02,0x02,0xfc,// U
0xf8,0x04,0x02,0x04,0xf8,// V
0xfe,0x04,0x18,0x04,0xfe,// W
0xc6,0x28,0x10,0x28,0xc6,// X
0xc0,0x20,0x1e,0x20,0xc0,// Y
0x86,0x8a,0x92,0xa2,0xc2,// Z
static inline void sendChar( uint8_t c ,  uint8_t skip , uint8_t r,  uint8_t g,  uint8_t b ) {
  const uint8_t *charbase = Font5x7 + (( c -' ')* FONT_WIDTH ) ;
  uint8_t col=FONT_WIDTH;
  while (skip--) {
      charbase++;
      col--;
  while (col--) {
      sendRowRGB( pgm_read_byte_near( charbase++ ) , r , g , b );
  col=INTERCHAR_SPACE;
  while (col--) {
    sendRowRGB( 0 , r , g , b );    // Interchar space
static inline void sendString( const char *s , uint8_t skip ,  const uint8_t r,  const uint8_t g,  const uint8_t b ) {
  unsigned int l=PIXELS/(FONT_WIDTH+INTERCHAR_SPACE);
  sendChar( *s , skip ,  r , g , b );   // First char is special case becuase it can be stepped for smooth scrolling
  while ( *(++s) && l--) {
    sendChar( *s , 0,  r , g , b );
  show();
  PIXEL_DDR |= onBits;         // Set used pins to output mode
static char jabberText[] =
      "   HELLO WORLD   "
      " Sample Text"
  const char *m = jabberText;
  while (*m) {
      for( uint8_t step=0; step<FONT_WIDTH+INTERCHAR_SPACE  ; step++ ) {
         cli();
         sendString( m , step , 0x00, 0x00 , 0x40 );
         sei();
    m++;
Just to reiterate that I want to delete the messages " HELLO WORLD " " Sample Text" and have them reside on the sd card instead, any help would be greatly appreciated
