Merging Codes Monopoly board with RFID
Hey guys!
So I am trying to create a code so that when I scan a card against the RFID sensor it will cause my RGB LED to light up a certain color. So far we have working code that reads the card and working code that makes the LED go off as different colors but we need them merged so that when a card is scanned a specific color will go off on the LED for that card. Our goal is to make a board where the pieces are key cards and every space has a sensor so that different colored lights go off per space depending on the piece.
 * All the resources for this project: https://www.hackster.io/Aritro
 * Modified by Aritro Mukherjee
#include <SPI.h>
#include <MFRC522.h>
#define SS_PIN 10
#define RST_PIN 9
MFRC522 mfrc522(SS_PIN, RST_PIN);   // Create MFRC522 instance.
  Serial.begin(9600);   // Initiate a serial communication
  SPI.begin();      // Initiate  SPI bus
  mfrc522.PCD_Init();   // Initiate MFRC522
  Serial.println("Approximate your card to the reader...");
  // Look for new cards
  if ( ! mfrc522.PICC_IsNewCardPresent())
    return;
  // Select one of the cards
  if ( ! mfrc522.PICC_ReadCardSerial())
    return;
  //Show UID on serial monitor
  Serial.print("UID tag :");
  String content= "";
  byte letter;
  for (byte i = 0; i < mfrc522.uid.size; i++)
     Serial.print(mfrc522.uid.uidByte[i] < 0x10 ? " 0" : " ");
     Serial.print(mfrc522.uid.uidByte[i], HEX);
     content.concat(String(mfrc522.uid.uidByte[i] < 0x10 ? " 0" : " "));
     content.concat(String(mfrc522.uid.uidByte[i], HEX));
  Serial.print("Message : ");
  content.toUpperCase();
  if (content.substring(1) == "BD 31 15 2B") //change here the UID of the card/cards that you want to give access
    Serial.println("Authorized access");
    delay(3000);
 else   {
    Serial.println(" Access denied");
    delay(3000);
We are using this security tag code to scan cards
Adafruit Arduino - Lesson 3. RGB LED
int redPin = 6;
int greenPin = 5;
int bluePin = 3;
//uncomment this line if using a Common Anode LED
//#define COMMON_ANODE
  pinMode(redPin, OUTPUT);
  pinMode(greenPin, OUTPUT);
  pinMode(bluePin, OUTPUT);
  setColor(255, 0, 0);  // red
  setColor(0, 255, 0);  // green
  setColor(0, 0, 255);  // blue
  setColor(255, 255, 0);  // yellow
  setColor(80, 0, 80);  // purple
  setColor(0, 255, 255);  // aqua
void setColor(int red, int green, int blue)
  #ifdef COMMON_ANODE
    red = 255 - red;
    green = 255 - green;
    blue = 255 - blue;
  #endif
  analogWrite(redPin, red);
  analogWrite(greenPin, green);
  analogWrite(bluePin, blue);
and this one to change LED colors
If someone could merge these for us or give us any ideas it would be greatly appreciated!
kbain18:
Hey guys!
#include <SPI.h>
#define SS_PIN 10
#define RST_PIN 9
    return;
    return;
  String content= "";
  byte letter;
    delay(3000);
else  {
    delay(3000);
int redPin = 6;
int greenPin = 5;
int bluePin = 3;
  #ifdef COMMON_ANODE
    red = 255 - red;
    blue = 255 - blue;
  #endif
who is "we"?
which arduino board are you using?
which version of the Arduino IDE are you using?
Which operating system are you using? Linux, MacOSX or Windows.
You need to merge the setup() sections of the two pieces of code and then
you need to merge the loop() sections of the two pieces of code in a new logical order that fulfills the
requirement of your project.
merging the two setup() sections of code should be easy to do.
merging the two loop() sections of code will require that you write new "glue" code.
You are ideally suit to write the merged code.
You have all the hardware and the detailed knowledge of the goal of the project.
By 'we' I just meant me and a friend, We are using the Arduino Uno. This is being run on Arduino 1.6.11 if that is what you meant and then this is all on windows.
ok so I tried to stick them together and this is what I ended up with:
#include <SPI.h>
#define SS_PIN 10
#define RST_PIN 9
int redPin = 6;
int greenPin = 5;
int bluePin = 3;
String card1 = "0B 7A FE E9";
   return;
   return;
 String content= "";
 byte letter;
 if (content.substring(1) == card1) //change here the UID of the card/cards that you want to give access
   Serial.println("Red");
   delay(200);
 Serial.println("Aqua");
 #ifdef COMMON_ANODE
   red = 255 - red;
   blue = 255 - blue;
 #endif
The scanner function works but the led won't light when the card is scanned.
