Hello guys please help me for contact two codes to gather please
first code of
temperature
And
glucose.
And
Screen also
Code of Temperature
#include <Adafruit_MLX90614.h>
Adafruit_MLX90614 mlx = Adafruit_MLX90614();
void setup() { Serial.begin(9600);
Serial.println("Adafruit MLX90614 test");
if (!mlx.begin()) {
Serial.println("Error connecting to MLX sensor. Check wiring.");
while (1);
Serial.print("C = "); Serial.print(mlx.readObjectTempC()); Serial.println("C");
delay(500);}
Code of glucose
#include <Adafruit_LiquidCrystal.h>
const int analogInpin0=0;
const int analogInpin1=1;
float sensor_value1=0;
float sensor_value2=0;
int max_1=0;
int max_2=0;
int indice_max1=0;
int indice_max2=0;
int tab1[90];
int tab2[90];
int j1;
int j2;
int i1;
int i2;
// Alcohol
float MAXG1=0;
float X1=0;
// Propane
float MAXG2=0;
float X2=0;
//Result
float Y=0;
// Coeffecients safety
const float a=0.668;
const float b=0.014;
const float c=51.784;
// Coeffecients 2 des trois capteurs negligeant acetone
//const float a=0.457;
//const float b=0.014;
//const float c=54.510;
// include the library code:
// initialize the library with the numbers of the interface pins
Adafruit_LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
lcd.begin(16, 2);
while (millis() < 3000)
pinMode(13,OUTPUT);
digitalWrite(13,LOW);
digitalWrite(13,HIGH);
if(digitalRead(13==HIGH))
//Read the Alcohol max value
for(i1=0;i1<90;i1++)
tab1[i1]=analogRead(analogInpin0);
Serial.print(i1);
Serial.print(" : ");
Serial.println(tab1[i1]);
if(tab1[i1]>max_1)
max_1=tab1[i1];
indice_max1 = i1;
Serial.print("max1=");
Serial.println(max_1);
Serial.println("indice max1");
Serial.print(indice_max1);
// Read the Propane max value
for(i2=0;i2<90;i2++)
tab2[i2]=analogRead(analogInpin1);
Serial.print(i2);
Serial.println(tab2[i2]);
if(tab2[i2]>max_2)
max_2=tab2[i2];
indice_max2 = i2;
Serial.print("max2=");
Serial.println(max_2);
Serial.println("indice max2");
Serial.print(indice_max2);
MAXG1=max_1;
MAXG2=max_2;
//Alcohol
X1=(MAXG1*180)/1023;
Serial.print("X1=");
Serial.print(X1);
Serial.println("ppm");
// Propane
X2=(MAXG2*1000)/1023;
Serial.print("X2=");
Serial.print(X2);
Y=aX1+bX2+c;
Serial.print("Y=");
Serial.print(Y);
delay(5000);
lcd.print("Glycemia : ");
lcd.setCursor(0, 1);
lcd.print(Y);
lcd.print(" mg/dl");
// set the cursor to column 0, line 1
// (note: line 1 is the second row, since counting begins with 0):
// print the number of seconds since reset:
And here code of screen TPT
Code of screen
#include <Adafruit_GFX.h> // Core graphics library
#include <MCUFRIEND_kbv.h> // Hardware-specific library
MCUFRIEND_kbv tft;
#include <Fonts/FreeSans9pt7b.h>
#include <Fonts/FreeSans12pt7b.h>
#include <Fonts/FreeSerif12pt7b.h>
#include <FreeDefaultFonts.h>
#define BLACK 0x0000
#define RED 0xF800
#define GREEN 0x07E0
#define WHITE 0xFFFF
#define GREY 0x8410
void setup(void)
uint16_t ID = tft.readID();
if (ID == 0xD3D3) ID = 0x9481; //force ID if write-only display
tft.begin(ID);
tft.setRotation(1);
void loop(void)
tft.fillScreen(BLACK);
showmsgXY(20, 10, 3, NULL, "gulcose");
showmsgXY(300, 10, 3, NULL, "valu");
showmsgXY(20, 60, 3, NULL, "sys");
showmsgXY(300, 60, 3,NULL, "valu");
showmsgXY(20, 110, 3, NULL, "dis");
showmsgXY(300, 100, 3,NULL, "valu");
showmsgXY(20, 160, 3,NULL, "o2");
showmsgXY(300, 160, 3, NULL, "valu");
showmsgXY(20, 210, 3, NULL, "heart rate");
showmsgXY(300, 210, 3, NULL, "valu");
showmsgXY(20, 260, 3, NULL, "temprut");
showmsgXY(300, 260, 3, NULL, "valu");
void showmsgXY(int x, int y, int sz, const GFXfont *f, const char *msg)
int16_t x1, y1;
uint16_t wid, ht;
// tft.drawFastHLine(0, y, tft.width(), WHITE);
tft.setFont(f);
tft.setCursor(x, y);
tft.setTextColor(GREEN);
tft.setTextSize(sz);
tft.print(msg);
And here my trying with screen I know there is error
but that why I ask for help please
Coding try with screen
//scrren
MCUFRIEND_kbv tft;
#define RED 0xF800
#define GREY 0x8410
//gluu
int max_1=0;
int max_2=0;
int indice_max1=0;
int indice_max2=0;
int tab1[90];
int tab2[90];
int j1;
int j2;
int i1;
int i2;
// Alcohol
float MAXG1=0;
float X1=0;
// Propane
float MAXG2=0;
float X2=0;
//Result
float Y=0;
//temp
void setup(void)
tft.begin(ID);
tft.setRotation(1);
//glu
pinMode(13,OUTPUT);
Serial.print(i1);
if(tab1[i1]>max_1)
max_1=tab1[i1];
indice_max1 = i1;
Serial.print(i2);
if(tab2[i2]>max_2)
max_2=tab2[i2];
indice_max2 = i2;
MAXG1=max_1;
MAXG2=max_2;
//Alcohol
Serial.print(X1);
// Propane
Serial.print(X2);
Y=aX1+bX2+c;
Serial.print("Y=");
Serial.print(Y);
delay(5000);
lcd.print("Glycemia:");
lcd.print(Y);
// temp
if (!mlx.begin()) {
while (1);
void loop(void)
showmsgXY(300, 10, 3, NULL, "Y");
int16_t x1, y1;
uint16_t wid, ht;
tft.setFont(f);
tft.print(msg);
//glcuu
//temp
delay(500);}
