The first code
#ifdef AVR
#include <avr/power.h> // Required for 16 MHz Adafruit Trinket
#endif
// Digital IO pin connected to the button. This will be driven with a
// pull-up resistor so the switch pulls the pin to ground momentarily.
// On a high -> low transition the button press logic will execute.
int sensorPin=0;
boolean val =0;
#define PIXEL_PIN 9 // Digital IO pin connected to the NeoPixels.
#define PIXEL_COUNT 8 // Number of NeoPixels
// Declare our NeoPixel strip object:
Adafruit_NeoPixel strip(PIXEL_COUNT, PIXEL_PIN, NEO_GRB + NEO_KHZ800);
boolean oldState = HIGH;
int mode = 0; // Currently-active animation mode, 0-9
strip.begin(); // Initialize NeoPixel strip object (REQUIRED)
strip.show(); // Initialize all pixels to 'off'
pinMode(sensorPin, INPUT);
val =digitalRead(sensorPin);
if(val==HIGH) {
delay(20);
val = digitalRead(sensorPin);
if(val == LOW) {
if(++mode > 6) mode = 0;
switch(mode) {
case 0:
colorWipe(strip.Color( 0, 0, 0), 50);
case 1:
colorWipe(strip.Color(255, 0, 0), 50);
case 2:
colorWipe(strip.Color( 0, 255, 0), 50);
case 3:
colorWipe(strip.Color( 0, 0, 255), 50);
case 4:
theaterChase(strip.Color(127, 127, 127), 50);
case 5:
theaterChase(strip.Color(127, 0, 0), 50);
case 6:
theaterChase(strip.Color( 0, 0, 127), 50);
void colorWipe(uint32_t color, int wait) {
for(int i=0; i<strip.numPixels(); i++) {
strip.setPixelColor(i, color);
strip.show();
delay(wait);
void theaterChase(uint32_t color, int wait) {
for(int a=0; a<10; a++) {
for(int b=0; b<3; b++) {
strip.clear();
for(int c=b; c<strip.numPixels(); c += 3) {
strip.setPixelColor(c, color);
strip.show();
delay(wait);
void rainbow(int wait) {
for(long firstPixelHue = 0; firstPixelHue < 3*65536; firstPixelHue += 256) {
for(int i=0; i<strip.numPixels(); i++) { // For each pixel in strip...
int pixelHue = firstPixelHue + (i * 65536L / strip.numPixels());
strip.setPixelColor(i, strip.gamma32(strip.ColorHSV(pixelHue)));
strip.show();
delay(wait);
void theaterChaseRainbow(int wait) {
int firstPixelHue = 0;
for(int a=0; a<30; a++) {
strip.clear();
int hue = firstPixelHue + c * 65536L / strip.numPixels();
uint32_t color = strip.gamma32(strip.ColorHSV(hue)); // hue -> RGB
strip.show();
delay(wait);
firstPixelHue += 65536 / 90;
The last one
#ifdef AVR
#endif
#define PIXEL_PIN 9
int mode = 0;
int Sensor = A0;
int clap = 0;
long detection_range_start = 0;
long detection_range = 0;
boolean status_lights = false;
pinMode(Sensor, INPUT);
pinMode(13,OUTPUT);
strip.begin();
strip.show();
int status_sensor = digitalRead(Sensor);
if (status_sensor == 0)
if (clap == 0)
detection_range_start = detection_range = millis();
clap++;
else if (clap > 0 && millis()-detection_range >= 50)
clap++;
if (millis()-detection_range_start >= 400)
if (clap == 2)
if (!status_lights)
status_lights = true;
digitalWrite(13, HIGH);
else if (status_lights)
digitalWrite(13, LOW);
clap = 0;
