Hi there! Hope you can help me understand what i'm doing wrong...
I've merged 2 different codes together using an 'else' statement...one that fades the leds randomly and one that is sound-reactive. Both codes work well independently of each other, but once merged....I'm getting flickers in the led fade code. Can you help me understand how to merge these 2 codes together cleanly, so that the fading LEDs aren't flickering?
I used /////////" " to indicate whether the code underneath corresponds to the fade code or the sound-reactive code.
Thanks in advance for your help
////////////// fade specs
#include <LEDFader.h>
#define LED_NUM 6
// 6 LEDs (perhaps 2 RGB LEDs)
LEDFader leds[LED_NUM] = {
LEDFader(3),
LEDFader(5),
LEDFader(6),
LEDFader(9),
LEDFader(10),
LEDFader(11)
////////////// sound reactive specs
const byte totalLeds=11;
int incomingAudio[30]={};
int averageAudio=0;
int ticker=1;
byte peak=1;
void setup(){
for(byte i=0;i<=totalLeds;i++)
pinMode(2+i, OUTPUT); // define LEDs
void loop(){
////////////////// fade code
// Update all LEDs and start new fades if any are done
for (byte i = 0; i < LED_NUM; i++) {
LEDFader *led = &leds[i];
led->update();
// Set new fade
if (led->is_fading() == false) {
int duration = random(1000, 3000); // between 1 - 3 seconds
// Up
if (led->get_value() == 0) {
byte color = random(100, 255); //100,255
led->fade(color, duration);
// Down
else {
led->fade(0, duration); //0
else{
////////////////// sound reactive code
incomingAudio[ticker%30]=analogRead(A5); // put in the mic reading at A5 into a spot in the array
digitalWrite(2+peak,LOW); // turn off the peak LED (sort of "PWM" to make it dimmer than usual)
if(ticker%30==0){ // read our averages every 30 'ticks'
for(byte i=0;i<30;i++)averageAudio+=incomingAudio[i];
averageAudio/=30; // put our average reading into this variable
for(byte i=0;i<=totalLeds;i++){
digitalWrite(2+i,LOW); // turn off all LEDs
for(float i=0;i<=totalLeds;i++){ // This loop basically turns on as many LEDs as there is 'loudness' into the mic
if(i>averageAudio/90-2)break; // NOTE: tweak around with this line to change how the LEDs respond to different values
// I've messed around with it and found that this seems to work well for 11 LEDs or so
if(peak<i)peak=i; // This sets the 'peak' LED to the highest value it sees
digitalWrite(2+i,HIGH);
averageAudio=0; // reset the average
if(ticker>90*5){ticker=1;if(peak>0)peak--;} // this basically determines the speed at which the peak LED falls back down, and resets the ticker so it doesn't overflow
digitalWrite(2+peak,HIGH);
ticker++;
You can try making each section of code its own function and then call the function. something like...
#define LED_NUM 6
LEDFader(3),
LEDFader(5),
LEDFader(6),
LEDFader(9),
LEDFader(10),
LEDFader(11)
int averageAudio=0;
int ticker=1;
byte peak=1;
void ledfade()
led->update();
// Set new fade
// Up
// Down
else {
void soundreact()
ticker++;
void setup(){
ledfade();
soundreact();
Doing things this way as helped me numerous times. Google "severalthingsatonce" and you will see more examples similar to what I pasted above.
Bill
You seem to have several unmatched comment delimiters. Your code is a mess.
It looks like you are trying to interleave the two actions without any sort of plan.
Have a look at how the code is organized in planning and implementing a program - especially the use of functions.
Notice that the functions are called from loop() and each function only does a little piece of its business on each call so as to make time available for the other functions.
That is also the principle of several things at a time
...R
yeah like the others are saying...
if /else means you do one or the other.
You need to do both at the same time, AND in the end of a display cycle control the duration.
The flicker/crap you are seeing is likely your sound work that flickers into life for a brief moment... It has no delays it seems. In fact you colud try to remove the if/else and run them back to back to see how they superpose.
I suspect since you pass delays to your LED functions that the main loop is rather slow repeating itself, so it might not be much better. Try to add a 100 ms delay to the main loop at the end to see what's going on.
