here's the code
Stereo Color Organ (Receiver)
// Collin Cunningham - Makezine.com
// http://blog.makezine.com/archive/2010/11/powerleds
// - For controlling six LEDs via a serial connection
// - Listens for a six ASCII value message sent over serial,
// and parses those messages with the Arduino Messenger library:
// Arduino Playground - Messenger
// ... then uses the values to set pins 3, 5, 6, 9, 10, 11 accordingly.
// - Each message is composed of 6 ASCII values ranging from 0-255,
// values are seperated by a single space and the entire message
// completed with a carriage return.
// Example: 135 20 234 189 55 255 (carriage return == ASCII code 13)
// - Any value over 255 is redefined as a random value between 0-255
// - Values are inverted for use with 2 of SparkFun's ZXLD1360 LED Driver boards
// Inversion can be disabled by removing the second line of the processValue function:
// else { value = map(value,0,255,255,0); }
//include and initialize the Messenger library for parsing ASCII messages
#include <Messenger.h>
Messenger message = Messenger();
//define our PWM output pins
int HighL = 3;
int MidL = 5;
int LowL = 6;
int HighR = 9;
int MidR = 11;
int LowR = 10;
//create variables for our output values
int highValLeft, midValLeft, lowValLeft;
int highValRight, midValRight, lowValRight;
//set our PWM pins as outputs
pinMode(HighL, OUTPUT);
pinMode(MidL, OUTPUT);
pinMode(LowL, OUTPUT);
pinMode(HighR, OUTPUT);
pinMode(MidR, OUTPUT);
pinMode(LowR, OUTPUT);
//set them all to Low, initially
digitalWrite(HighR, LOW);
digitalWrite(MidR, LOW);
digitalWrite(LowR, LOW);
digitalWrite(HighL, LOW);
digitalWrite(MidL, LOW);
digitalWrite(LowL, LOW);
//Begin serial connection for receiving values and tell 'em we're ready
Serial.println("READY");
//associate an action for messages handled by Messenger library
message.attach(messageReady);
//when there's new serial data available,
//process it with the Messenger library
while ( Serial.available() ) { message.process( Serial.read () );}
void messageReady(){
//use values from serial data to define the output values
while (message.available()) {
highValLeft = message.readInt();
midValLeft = message.readInt();
lowValLeft = message.readInt();
highValRight = message.readInt();
midValRight = message.readInt();
lowValRight = message.readInt();
//write the above variables to the output pins
writeLEDs();
void writeLEDs(){
//write the LED values inverted for the left channel
analogWrite( HighL, processValue(highValLeft) );
analogWrite( MidL, processValue(midValLeft) );
analogWrite( LowL, processValue(lowValLeft) );
//write the LED values inverted for the right channel
analogWrite( HighR, processValue(highValRight) );
analogWrite( MidR, processValue(midValRight) );
analogWrite( LowR, processValue(lowValRight) );
int processValue(int value){
//any value over 255 is replaced with a random value between 0-255
if (value > 255) value = random(0,255);
//values under 255 are inverted for transistor output to SparkFun sku: COM-09834
return value;
