messenger library and processing
hej all,
i am trying to send data from processing to arduino with the messenger library...
when running my processing example sketch, that was supplied with the library, the sketch never starts.... :-?
i just get
Stable Library
Native lib Version = RXTX-2.1-7
Java lib Version = RXTX-2.1-7
Opening: /dev/ttyUSB0
Opening the Serial port forces the Diecimila to reboot...
...so wait till the Arduino boots and send out a message..
also, if i quit the processing sketch and try again, i get an extra error in the console:
Stable Library
RXTX Warning: Removing stale lock file. /var/lock/LCK..ttyUSB1
Opening: /dev/ttyUSB1
...so wait till the Arduino boots and send out a message...
so i never get out of this loop, and get the done waiting msg
while (port.available() == 0 ) {}; // Wait till Arduino boots
println("Done waiting.");
the only thing i changed in the code is the baud rate (to 2400)
what am i doing wrong?
what message is it that the arduino is supposed to send?
i am running this on ubuntu 9.04, arduino 0017 and processing 1.0.3
below is my arduino code
#include <Messenger.h>
// Instantiate Messenger object with the default separator (the space character)
Messenger message = Messenger();
// Create the callback function
void messageReady() {
  // Loop through all the available elements of the message
  while ( message.available() ) {
    Serial.print(message.readChar() );
  // Initiate Serial Communication
  Serial.begin(2400);
  // Attach the callback function to the Messenger
  message.attach(messageReady);
  Serial.println("im ready");
  // The following line is the most effective way of using Serial and Messenger's callback
  while ( Serial.available() )  message.process(Serial.read () );
and the processing code is here
import processing.serial.*;
Serial port;                         // The serial port
String message = null;               // Incomming messages
String elements[] = null;            // Message elements
int values[] = {0,0,0,0,0,0};        // Values of the analog pins
  size(420,150); //La taille de notre fenêtre
  frameRate(30);
  stroke(255);
  println("Opening: "+Serial.list()[0]);
  port = new Serial(this, Serial.list()[0], 2400);
  println("Opening the Serial port forces the Diecimila to reboot...");
  println("...so wait till the Arduino boots and send out a message...");
  port.write(13);    // Clear messages still hanging out in th buffer;
  port.write("50");    // Send the desired sampling rate as ASCII characters: 33 milliseconds
  port.write(13);    // End the message with a carriage return;
void draw() {
  background(0);
  fill(255);
  while (port.available() > 0) {
   message = port.readStringUntil(13); // Read message until a carriage return
   if (message != null) {
     println(message);
    elements = splitTokens(message);
    for (int i =0; i < elements.length && i < 6; i++ ) {
      values[i] = int(elements[i]);
  for (int i =0; i < 6; i++ ) {
     rect(12+(i*((width-24)/6.0)),25,((width-24)/6.0)-4,map(values[i],0,1024,0,100)); //
I think the Arduino doesn't reboot. At least, mine doesn't reboot the same.
I solved it by removing the while loop :
Don't forget to print a carriage return to when you reply from Arduino.
  //added
  Serial.print(13,BYTE);
That made it work for me.
Still I'm having some errors, so I'm figuring out some things too.
But at least this might got you started on the good road.
I made a matching Messenger library for Processing, so if anybody needs it just send me a message. It will be included in the next release of Messenger
