mesuring distance between 2 arduinos using gps and xbee
After amonth of intensive working with arduino i manged to get several devices working togther ... my project is mesuring distance between 2 arduinos using gps and xbee in both sides ... but sence im new arduino user it wil be great if u can help me to reduce and enhance my code...
here is my receiver code /// the transmitter is sending float variables with packet markers {} ()
#include <NewSoftSerial.h>
#include <TinyGPS.h>
#include<math.h>
#define RXPIN 2
#define TXPIN 3
#define GPSBAUD 4800
TinyGPS gps;
boolean started = false;
boolean ended = false;
char inData[24]; // Size as appropriate
byte index = 0;
float calc_dist(float flat1, float flon1, float flat2, float flon2);// function for calc. distance given lat&lon for 2 points on earth
float getlat2();// getting lat from another arduino
float getlon2();//getting lon from another arduino
#define SOP '{'// start of packet
#define EOP '}'//end of packet
NewSoftSerial uart_gps(RXPIN, TXPIN);
float getgpslat(TinyGPS &gps);
float getgpslon(TinyGPS &gps);
  Serial.begin(9600);// for xbee
   uart_gps.begin(GPSBAUD); // setup sketch for data output speed of GPS module im using em406a
  float lat1,lat2,lon1,lon2,d;
  while(uart_gps.available()>0)     // While there is data on the RX pin...
      int c = uart_gps.read();    // load the data into a variable...
      if(gps.encode(c))      // if there is a new valid sentence...
      lat1=getgpslat(gps);//getting my lat
      lat2=getlat2();// getting another arduino lat
      lon1=getgpslon(gps);
      lon2=getlon2();
       delay(5000);
      d=  calc_dist(lat1,lon1,lat2,lon2);
      Serial.print(d,5);
  float latitude, longitude;
  gps.f_get_position(&latitude, &longitude);
 return latitude;
 return longitude;
float getlat2()
   while(Serial.available() > 0)
      char inChar = Serial.read();
      if(inChar == SOP)
         started = true;
         index = 0;
         inData[index] = '\0';
      else if(inChar == EOP)
         ended = true;
         if(index < 24-1) // Array size
            inData[index++] = inChar;
   if(started && ended)
      float lat1= atof(inData);
         return lat1;
 float getlon2()
      if(inChar == '(')
         started = true;
         index = 0;
      else if(inChar == ')')
         ended = true;
      float lat2= atof(inData);
         return lat2;
  float dist_calc=0;
  float dist_calc2=0;
  float diflat=0;
  float diflon=0;
    diflat=radians(flat2-flat1);
  flat1=radians(flat1);
  flat2=radians(flat2);
  diflon=radians((flon2)-(flon1));
  dist_calc = (sin(diflat/2.0)*sin(diflat/2.0));
  dist_calc2= cos(flat1);
  dist_calc2*=cos(flat2);
  dist_calc2*=sin(diflon/2.0);
  dist_calc +=dist_calc2;
  dist_calc=(2*atan2(sqrt(dist_calc),sqrt(1.0-dist_calc)));
  dist_calc*=6371000.0; //Converting to meters
 // Serial.println(dist_calc);
  return dist_calc;
Have you noticed that except for one tiny detail, "getlat2" is identical to "getlon2"?
(please use the code box when posting code - use the # icon on the editor's toolbar)
float dist_calc=0;
float dist_calc2=0;
float diflat=0;
float diflon=0;
Why bother to go to the effort of typing all that out, when you're going to assign proper values to them in a couple of hundred nanoseconds?
i know that there is atiny defference between getlat2 and getlon2 ... but i culdnt make it other way ... maybe u can help ?
You could provide the delimiters as parameters.
