i want to display an animation on a boat floating on a river. The animation content is related to the boats distance from a certain point. During a show the maximum distance will be max. 500 Meters. Is this a GPS thing, or are there other possibilities? Laser could be an option, but it is expensive ( ca. 1000€ in these distances ) and depends on clear visibility -
500 meters can be handled by GPS, but maybe a sound pulse is an option (sound takes 1.5 second for 500 mtr).
Every second a short pulse and once per minute a longer sound pulse to sync ?
Celerity (speed) of sound is not a constant considering temp, humidity.
after 350 meters, it's not a 'VALID' value, it can change from few meter considering the climatical elements. if your'are working with big heat and sun, convection will change these values an they will be false.
25 years in the job of sound ingeneer...
This is not a good way of doing it to get right results !
It would have to be quite a loud noise to carry that distance, and it would have to bounce off something and return to get a distance measurement that was based on the speed of sound.
Sorry but I'm French people, I dont get all the english gramar and way of writing words as I can do it in French...
@ mxwendler
What is the accuracy you need in your measurements, smaller than 1 meter 1 meter, 5 meter, 10 meter, ...?
this is a good question.
what we want to do is ( i hope i can explain that in words ) display a loooooooooooong--seeeeenteeeence that will be shown as a projection on the boat. imagine the boat floating on a river, at the first meters showing 'lo' then 'oo' then 'oo' then ... etc. Get the idea? You would read the whole sentence if you keep watching the boat or i you could make a long-time exposure along the whole boat trip. So if i start calculating, we have 1 pixel per cm ( 500 m distance -> 50.000 cm -> 50.000 pixels sentence length as large image which will be sampled ) and to get a reasonably sharp impression, anything that jitters below 10-20cm would be perfect ---
